Question about Symbol Motorola MC9090 Mobile Computer
MC9090 cannot acquire ip address; using wireless router and DHCP
3 Suggested Answers
SOURCE: Not able to connect to MC9090 using ActiveSync 4.5
This sometimes happens when I abuse Activsync with multiple terminals. It essential dies and I have to restart the machine.
I would also check that your host PC services.
Goto Control Panel >> Administrative Tools >> Sevices.
Check
Server
Workstation
They should be started and set to automatic.
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL 01202 620955
http://www.biastechnology.com/
Posted on Dec 15, 2009
  • 3278 Answers
SOURCE: My MC9090 does not want
Hello, Raymond.
From FixYa Support:
To be certain that you set the static address correctly, the IP is set within the wireless profile.
On the radio icon in the task bar, select Wireless Profiles. This box then holds all your wireless profiles, including the default Motorola "out of box". Hold down the stylus on the screen and select "Add New" follow the prompts. When you get to IP Address from the pull down menu select static and then next this will take you to another screen where you can add your details.
Now you want to make them persist through either a cold boot or when the terminal has been left without a battery for a substantial amount of time.
This can be done 2 ways. When the profile has been set up highlight it by holding down the stylus on it and from the menu select export. This saves the registry key to the Application folder; a folder which persist through a cold boot. When it does cold boot it takes all the registry keys from the Application folder and builds 1 complete key.
The other way is to close the WLAN profile and selection options, from the pull down menu select export and save all profiles.
Hope this helps.
Posted on Aug 22, 2011
How to connect my self and make my IP address ?
you can set your laptop up to detect ip address automatically in its network settings. if you had provided the operating system it would have helped to narrow down how to do this. If you had told us how you plan to connect to the router this also would have been helpful. Are you connecting via blue cat5 ethernet cable or via wireless. If it is wireless your laptop should detect the wireless network and you can ask it to connect to it. If the wireless link is encrypted you need to log into the router via ethernet cable and look for the securirty settings on the wireless and find out what the encryption code is. Usually the router will use what is called an internal IP address range. the subnet is usually class c being 255.255.255.0 and the ip address default gateway IP address is usually either 10.0.0.1 or 198.168.0.1 and this can be put into the browser to log into the router. When you set the laptop to automatically obtain the IP address the Wireless Router has a DHCP server that manages the leases of IP addresses to computers connected to it. However if you are connecting the Wireless Router into an existing network with another router you will need to set the IP address to the next IP address eg 10.0.0.1 on existing router make second router 10.0.0.2> if you have a DCHP server on the wireless turn it off if you have a DCHP server on the existing router otherwise you have confusion as to which DHCP server to listen too on your network.Make sure the DHCP router does not allocate at least the first 10 addresses eg 10.0.0.1 to 10.0.0.10 to allow for the routers and printers on your network that may need dedicated IP addresses (Static IP addresses)
Feb 07, 2015 | D-Link dlinkgo Wireless N 150 Router...
Wrt54g2 dhcp problem
You must enable the DHCP setting on wireless router if you've configured the computer's wireless adapter to obtain an IP address automatically. If not you will get the "failed to acquire an IP address" error when you try to connect to wireless network! Also don't forget to configure big enough IP range on router's DHCP setting, because the router won't be able to assign IP to 6 computers if you only configured 5 IP space on router.
May 18, 2011 | Computers & Internet
My laptop keeps acquiring network address. Please suggest what to do ? Router --> Modem --> Desktop. Laptop is for wireless connection
For that you need to enable DHCP on router.Then your computer get ip address automatic from router.Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on DHCP enable it save settings and restart router. Let me know if you need further assistance. Thanks for using FixYa.
Nov 27, 2010 | Zyxel Prestige 320W Wireless Firewall...
My laptop wont connect to my wireless router, it just says acquiring network address all the time, it does connect to other wireless routers though?
To connect a laptop to a wireless network for accessing internet....you have two ways:-
1. DHCP (Dynamic Host Control Protocol) 2. Manual entry of settings in wireless adapter properties.
1.DHCP:- In DHCP method you dont have to enter any settings on the wireless adapter. The wireless network which you are connecting will automatically assign an IP Address to you. But to use DHCP it must be supported by your wireless network router settings.
2. Manual entry of settings in wireless adapter properties. This method is mostly used over wireless Connection in small networks connecting 2-200 computers. In this method you have to obtain the following information from your connection provider.
* IP address (Its format is "xxx.xxx.xxx.xxx") * Default gateway address (very important) * Primary and secondary DNS (If not given then you can use "8.8.8.8" as primary DNS and "8.8.4.4" as Secondary DNS...thats free DNS service from google and its very fast) * Subnet Mask (not needed mostly...automatically generated)
To enter these settings you have to rightclick the Wireless Adapter>> and select properties>>Then double click the Internet Protocol version 4(TCP/IPv4) and enter these settings. In many cases when you are using proxy server then you have yo use proxy settings also in your browser..
Hope this will help 4 sure....Cheers..:)
Sep 30, 2010 | Acer Aspire 3610 Notebook
Need basic step-by-step instructions on how to install my router.
To Configure the Router with Internet Access
Connect to one of the wireless router/access point's LAN Ethernet ports, turn off its DHCP server, and give the wireless router a static IP on your LAN:
  1. Connect a PC directly to a LAN port on the wireless router with an Ethernet cable.
  2. Power on the wireless router/access point.
  3. Reboot the PC.
  4. Log in to the wireless router though a browser. (Usually 192.168.1.1, with User Name = admin and Password = password, unless you changed them from the defaults).
  5. Go to the LAN IP menu and disable the wireless access point’s DHCP server by unchecking Use router as DHCP server.
  6. Select LAN IP, and change the IP to 192.168.1.99.
  7. Click Apply to save the settings. You will lose the connection to the wireless router/access point , since its IP changed.
  8. Log in to the wireless router/access point with the URL: http://192.168.1.99
  9. Connect one of the wireless router's Local (LAN) ports to your existing network.
This completes the wireless router/access point configuration.
  • You can now log in to the wireless router/access point at its new address of http://192.168.1.99 and configure wireless features such as WEP and Access Control List
  • UPnP, DMZ, Port Forwarding, and Port Triggering are not used on the wireless router/access point, and it doesn't matter how they are configured.
  1. Configure the LAN IP address to be within the same subnet as your PCs.
    • Take care not to use an IP address already being used.
    • Limit the number of addresses in the DHCP range and assign an IP address outside of the range to the router you want to use as the Access Point.
  2. Disable DHCP on the wireless router/access point.
  3. Connect one of the LAN ports on the wireless router/access point to a LAN port on the Router.
  4. Configure the SSID and any security settings on the wireless PCs to match the wireless router/access point's SSID and security settings.
a. SSIDs must be the same on all wireless devices. (These are case-sensitive: netGEAR is not the same as NETGEAR.)
b. Tip: Make sure the wireless PCs can connect before configuring WEP, WPA-PSK, or other wireless encryption.
Jan 02, 2010 | NetGear WGT624 Wireless Router
How to set my wrt300n router to use static ip,... i´ve have a problem whit my ps3, and want to use static ip, instead of dhcp(dynamic) should i do it before i do it on my pc and how to do it on the...
You may want to enable the DHCP reservation feature of the router.
What is DHCP Reservation and how do I configure it?
What is DHCP Reservation?
A DHCP reservation is a permanent IP address assignment. It is a specific IP address within a DHCP scope that is permanently reserved for leased use to a specific DHCP client.
You can configure a DHCP reservation in your DHCP server when you need to reserve a permanent IP address assignment. Use reservations for the DHCP enabled devices like print and file servers or other application servers which always have the fixed IP address on network.
Step 1: Access the router's web-based setup page. For instructions, click here
Step 2: When the router's web-based setup page appears, click Setup.
Step 3: Click on Basic Setup.
Step 4: Make sure that DHCP Server is Enabled. Then, click the DHCP Reservation button if you want to assign a fixed local IP address to a MAC address.
Aug 26, 2009 | Linksys WRT300N Wireless Router
Netopia 3d reach will not acquire ip address
Make sure that DHCP is turned on on the router. If it is, reset your router and try it without wep to check that it is working.
May 16, 2009 | Netopia 3-D Reach (TER/GUSB-N1)...
Acquiring Address Problem
you will need to make sure that DHCP is enabled within the routers settings as this will tell the router to assign ip addresses automatically, then go to network connections, right click on your network card>properties>TCP/IP line>properties and tick 'obtain an ip address automatically', click ok, close window and restart pc.
Sep 24, 2008 | HP PAVILION A6230N DESKTOP PC
I have a Netcomm NBPlus 4 Wireless Modem/Router and I have now bought, in addition, a D-Link DVG 1402S VOiP Router. I seem to have a problem getting the two to talk to each other prior to configuring the...
Set one of them up in bridging mode.
To get to the admin screen, check the bottom of the voip box to see if it's accessed through another IP.
If you have the voip router plugged into the Netcomm router, the IP address to access the voip is going to be assigned by your netcom. Assuming the voip router isn't serving dhcp addresses (i.e. 192.168.1.100, 192.168.101 and so on)
FYI: Be sure you don't have both routers set up as dhcp servers.
You can acquire the voip router's ip from the admin interface of your netcom router.
If you are wanting to get them to talk to each other through entirely different IP addresses (subnets), create a route in your netcom router for your voip router. Bridging mode may make things easier for you.
Going back: If you have your netcom dishing out ip addresses to wireless and cable users, and you plug in the voip router to the netcom router, your voip router will receive an ip like any other computer on the network. Thus will use the netcoms ip as the default gateway and it gets messy after that --lack of connectivity.
Nov 15, 2017 | Computers & Internet
Acquiring network address
From the PC you are trying to connect to your wireless router LAN there are two possible causes of these problem.
1. No DHCP Server Available.
2. You are using MAC Filters and the MAC is not defined in the router configuration.
Please verify this and you can easily get through it.
DHCP can be configured over your wireless router also incase you don't have DHCP Servers in your LAN / WAN. Other wise you can go for manual IP addresses.
Jan 04, 2008 | Linksys WRT300N Wireless Router
Symbol Motorola MC9090 Mobile Computer Logo
1,002 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
