Question about Microsoft Wireless Laser Desktop 6000 V2 Keyboard/Mouse
Keyboard is double typing - press z or c and you get both... also happening with 1 and 3 - any ideas?
Why do I get a 1 when I type a j?
Hi, this is becasue your "num lock" key is truned on. on laptops there is no numer keypad so when you press the num lock key some of the letters do double duty as numbers. Just press the num lock key again and it will turn your keyboard back to normal.
Sep 03, 2010 | Gateway Solo 9100/9150 Series Laptop...
Typing g would return me g5
Hi. Probably this already a hardware issue with your keyboard, you can double check this by updating first the keyboard driver, or try going to safe mode first to double check if this just a sotfware issue. Turn off your machine and right after you turn it on you should continously press the F8 button to how the Safemode menu, then choose safemode. On the safemode try using the keyboard if its still doing the same thing, and if yes this already a hardware issue. Last you could also try powerdraining it by removing the battery and unpluging the ac adapter then press and hold the power button for 20 seconds while the battery and ac adapter is out, after that place back the battery and plugin the ac adapter and turn on your computer and try the keyboard, if its still doing the same thing, then you should call Lenovo tech support if your machine is still under warranty and they would just replace your keyboard without any charge. This there number for LENOVO IDEAPAD: US/Canada:
Available 24/7 1-877-4LENOVO (1-877-453-6686)
Australia:
Available 24/7 1300-557-073
New Zealand:
9am-9pm Mon-Fri 0800-446-833
LENOVO THINKPAD:
US/Canada 1-800-426-7378
Australia 1-300-880-917
Hope this Helps
Jun 09, 2010 | Lenovo Keyboard
Can't type double letters can't backspace more
Push the shift key down until it beeps and it should unlock the keyboard and allow you to type normally.
Feb 08, 2010 | Dell 0Y3740 Keyboard
Doubled accent with single keystroke (using Language Bar)
It's just a glitch that may happen from time to time. The first thing is to reboot, and more likely than not it will be gone.
Dec 16, 2009 | Microsoft K5100141 Keyboard
When typing it skips line and acts as if we are using insert button
hope u r using licensed and updated antivirus (i prefer avg/kaspersky)..
check the following with steps:
howevr, did u tried reinstalling the keyboard driver..
or replacing the keyboard with a standby..
remove the mouse n see..
try reinstalling the os..
sometime it happens, if ur ram is faulty..
the last option left is ur main/mother board..
seek professional advice of ur system admin/vendor....
Oct 31, 2009 | Acer NSK8458AN Keyboard
G6000 hen pressing keyboard letter it type 4
Hi there
Does this happen with almost every key, or only certain keys? And if you press a key very quickly, does it still register it as 4 presses?
Also, please confirm the operating system on the laptop, such as XP or Vista.
Please do not rate this solution unless I have answered your question or your reply will not be returned to me. Thanks.
Aug 21, 2009 | HP Computers & Internet
Keyboard is messed up
Try looking here to see if any of the keys are set wrong.
Normal 0 If you are then go to Control Panel.
1. Click on PRINTERS.
2. When the Printer Properties come up, CLICK on KEY SETTINGS.
3. Then set up the keys by selecting the key to be setup.
Hope this helps. Bud
Dec 14, 2008 | Saitek Eclipse (PZ30AUR) Keyboard
I have a dell dimension PC and when I connect a non Dell Keyboard the PC will recognise any of (F) function keys I have tried a number of keyboards tat I know work on other PCs, reporting keyboard errors...
Try booting to Safe Mode and see if the problem still exists. Press F8 when you're on the Dell Screen and choose Safe Mode. If the problem does not happen in Safe Mode, then do this:
1. Click Start
2. Click Run
3. Type msconfig
4. Choose Diagnostic Startup
5. Restart to Normal Mode.
Nov 25, 2008 | Computers & Internet
Keyboard Stuck in Function (Fn) Mode
To unlock number lock (numlk):
Depend on comp, but try pressing (at same time)
fn + f11
or
fn + Scroll/numlk (next to f12)
or
f12 + Scroll
or
f12 + Scroll + fn
or
ctrl + Shift + Scroll
or in BIOS there is a numlk option
Aug 12, 2008 | Gateway MX6124 Notebook
Ff 301 keyboard error
1. This can happen if you have the mouse and keyboard plugged in the wrong ports. Can you double-check you are plugging the keyboard into the correct port.....
2. several keys pressed simultaneously
3. key on the keyboard is stuck (try a different keyboard and see if you get the same error.
Jul 23, 2008 | Computers & Internet
Microsoft Wireless Laser Desktop 6000 V2 Keyboard/Mouse Logo
32 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
