Question about Stanley Bostitch 18 Gauge Brad Nailer 1 - 1/4IN - BT125K - 2
Bostitch 1850BN will not cycle. Had a piece of a brad get hung up and the piston was stuck forward. I took it all apart to remove the hung up piece of brad and free the piston. I'm afraid I didn't pay close enough attention when I removed the piston with its rod as I notice when replacing it that the driver chaft has a flat side and the oter side has a ridge down the middle. I didn't notice the rod broken or bent but after reasembling it the nailer will not shoot. I removed the piston rod and turned it over and it functioned about 4 times but didn't drive the brad deep enough and it quit working again. The piston seems to want to hang up and not cycle again. I'm not sure as to how this all goes back together as I also noticed that the metal cylinder with the plastic housing is not round and that the position it goes into the housing makes the cylinder so as not to be in a straight line with the housing. I couldn't find any marks that line up so I'm afraid I don't really know how to reassemble it so as to line it all up. The gun worked great prior to getting hung up and me trying to repair it. Now, it either will not shoot a brad or it hangs up every time.
  • Anonymous Mar 22, 2014
    I have a nr90gc which won't re cycle I've stripped it cleaned everything and checked for any damage / bent parts the piston and push rod are free moving but it still only fires once and won't recycle could it be the piston bump rubber gone hard?
  • 4,234 Answers
Check the link below for directions to a website that has complete diagrams. I suspect that a seal may be damaged and the air is not flowing correctly. I would first examine all of the orings. Also, using the diagrams as a guide, check for proper movement by hand while the gun is partially dis-assembled. Update this if you have further questions.
Dan
Link: http://www.fixya.com/support/r5812776-bostitch_nailgun_dis_assembly_assembly
Posted on Oct 01, 2010
How do I clear a jam?
Hi Gary:
SAFETY FIRST! Disconnect from air supply.
Pull trigger to make sure not "loaded"
- Here's what I would do.
1) Open magazine and remove stick of remaining nails
2) Try to remove jammed nail with pliers, pointy tool, etc.
3) Use allen wrenches to dis-mantle head until everything comes apart and jammed nail falls out.
4) re-assemble, cleaning and oiling at the same time.
Once done, re-connect to air supply and test.
Hint. A 2 inch nail can take some effort to penetrate, especially a knot in hardwood. Make sure you are using adequate pressure; that is the high end of the recommended pressure.
Cheers.
Dec 30, 2015 | Stanley Bostitch Sb-1850bn 18-gauge Brad...
How to disassemble stanley bostitch sb1850bn nailer
very carefully as springs like to FLY then hide from us . but does it need disassembled . what is it not doing , or doing wrong .
Aug 31, 2015 | Stanley Bostitch Sb-1850bn 18-gauge Brad...
I have a new Bostitch F21PL framing nail gun. I used it for the first time on Saturday and it worked flawlessly through the first half-dozen nail sticks. Then, it jammed. The culprit nail was easy to...
when you removed the jammed nail did the piston driver move back into the rear position? if not there may still be a piece of the nail holding the piston.... If the piston is stuck in the forward position with the air disconnected use a hinge punch and tap it back, reconnect air and give it a try
Sep 23, 2013 | Stanley Bostitch F21PL Nailer
How do I remove the trigger valve assembly?
i would just look on the box or go to the company website and ask them
Sep 18, 2013 | Stanley Bostitch Sb-1850bn 18-gauge Brad...
Driver stays out after firing
You probably have a worn air seal. Or perhaps some pneumatic tool oil might do the trick. A few drops in the air outlet then bumb some nails into a piece of wood.
Apr 18, 2013 | Stanley Bostitch Sb-1850bn 18-gauge Brad...
New model sb-1850bn will not operate at all. Oiled it lightly before trying to use. Air comes out around trigger.
If the air is coming out of the trigger when you try to drive a nail, most likely the driver is broken.
Bostitch nailer have a 7 year warranty on them so, take it to a Bostitch service center and have it repaired there.
Dec 16, 2010 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
My Stanley Bostitch SB-1850BN brad nailer will not sink the brad. It leaves it about an eighth of an inch above the surface. Adjusting the head using the adjustment thumbwheel does not help. Any...
You may have a broken tip or bent driver. Remove tha nails from gun and dry fire into a piece of wood. You should see a nice little indention. If you continue to hold the trigger and the nailer against wood after firing, the driver will stay in the lower position for examination. Just fire into wood and keep gun against wood while holding trigger and lean gun to side untill you see the tip. If you see broken tip or no tip order repair kit that includes driver, or driver alone from www.bostitch.com or ebay. Good luck
Sep 07, 2010 | Stanley Tools & Hardware - Others
My brad nailer will not shoot any nails. When I press the trigger, I can hear a small puff of air.
it sounds like the piston/driver might be stuck or the firing valve is malfunctioning. there are 4 screws to remove the top cap and you can see if the driver is damaged. Also before removing check to make sure there is not a nail jammed in the nose assembly. This tool is good for breaking the pin on the piston.
Oct 16, 2009 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Air allways and continually leaks forcably from the top. Bostitch
This nailgun has several parts to the headvalve that must fit together properly to seal. Go to WWW.toolpartsdirect.com for a diagram of this tool. The part called the diaphragm is source of problem. It has thin vinyl walls that will fold over when you assemble. The piston will not cause the gun to leak, just make sure that piston fits snug into the cylinder. Loose oring on piston will only cause low power or the poston may not retract all the way back up. Some piston/drivers had a plastic ring instead of an oring. The plastic ring had a secondary oring under, however not necessary. You can use rubber or plastic, just make sure that the piston is not too tight or too loose. The piston oring is the only oring in the gun that can be cut to fit. It is like a piston in a car engine. The piston rings have a gap.
Nov 23, 2008 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Stanley Bostitch 18 Gauge Brad Nailer 1 - 1/4IN - BT125K - 2 Logo
197 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
