Question about Maytag LAT3600A Top Load Washer
We have been getting grease spots on our clothes for some time and it is getting worse
  • 121 Answers
The mounting stem needs to be replaced. This page shows how to replace the tub seal and the mounting stem. If your washer isn’t leaking water then you only need to replace the mounting stem so all the steps are not necessary. http://appliance-repair-it.com/Maytag-tub-seal.html
Posted on Sep 14, 2010
Grease /oil spots on clothes coming from washer
This sounds like the drum bearings are starting to wear and allowing grease to infiltrate through the inner seal.Does it sound noisy on the spin cycle.
May 03, 2010 | Speed Queen AWN432 Washer
I get oil/grease spots on my laundry ffrom my
You probably have a bad seal on the back of the drum, as that bearing is the only source of grease near your clothes. Good luck.
Jan 03, 2010 | Frigidaire GLTF1670A Front Load Washer
Greasy looking spots on clothing after washing/drying.
Without seeing the spots, this is a bit speculative, but here goes,......
I'm guessing that the spots are only found on the front side, primarily of shirts, or blouses, etc. These are from grease splatters from cooking, which many times only show up after washing and drying.
The soap releases some dirt, which is attracted to the non-removed grease spot, allowing it to show up. Re-wash the clothing, pre-spotting those areas with a citrus pre-spotter.
Aug 31, 2009 | LG WM0642H
Brown spots on clothes
Brown spots indicates a bearing is breaking up, the spots are the grease from the bearing and as the seal breaks down due to the bearings going off centre, the grease gets in the drum.
Get the bearings replaced if affordable.
Jul 02, 2009 | Frigidaire ATF6000ES Front Load Washer
Grease-like stains on clothing
hi. i can help. the grease is coming from one of two places. Either some item with grease on it got placed in the machine and the grease transferred to the tub where it will cause the problem until it is spotted and removed with a degreaser, or wears off.
OR the grease is coming from the washer itself. Perhaps some grease oozed out of the mechanicals related to the aggitator.
Either way I would get a strong flash light or trouble light and look carefully in the tub and around the aggitator for grease. Then remove it with a cloth and some degreaser, available at any auto parts store.
Jun 27, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Leaves spots
YOUR BEARINGS ARE GOING THE BLACK SPOTS ARE GREASE FROM THE BALL RACER RING THEY SIT IN, IT WILL ONLY GET WORSE & EVENTUALY YOU WONT BE ABLE TO GET IT OUT OF YOUR CLOTHING & THEN YOU DEVELOPE A PUNGENT SMELL THAT WONT GO UNTIL IT IS FIXED, YOU CAN CHANGE THEM YOURSELF BUT IT IS NOT EASY FOR SOMEONE NOT KNOWING WHAT THEY'RE DOING, SORRY, I HOPE THIS HELPS A BIT...
May 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Spots on my clothes
hi, your drum bearing needs replacing, hope this helps, thanks for using fixya
Feb 15, 2009 | Kenmore Elite 45986 Front Load Washer
Grease spots on clothes
That could mean your overloading your dryer to the point the wheel bearings are squished really bad. When loading your washing machine you should always be able to see the water level more than the clothes, your clothes should be floating in the water. That way, when you unload your washing machine and go to dry, you will have the right amount of clothes everytime
J
Jun 29, 2008 | Whirlpool LER5636P Electric Dryer
Your drum support bracket grease shaft seal (which will require a new Lip Seal Kit #12002022) is dead and potentialy the two shaft bearing are at risk. Parts cost retail approx. $100 or so. Labor, Lookout...
I'm fighting this issue for the second time.......
Bill B.
May 20, 2008 | Maytag Neptune MAH7500WH Front Load Washer
Maytag LAT3600A Top Load Washer Logo
83 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
