Question about Genius MaxFighter F-16U. USB PC Joystick with Turbo .
WHY DOES MY GENIUS MAX FIGHTER F-16U USB PC JOYSTICK HAVING PROBLEMS IN FLIGHT SIM FS2004 ON WINDOWS XP WHEN I AM FLYING IT SEEMS TO TURN ONLY TO THE LEFT AND DOWN NOT RIGHT OR UP ? I SETUP CONFIG IN FS2004 FOR JOYSTICK BUT STILL HAPPENS! THANK YOU.
myob247
  • 1342 Answers
SOURCE: my joystick problem
Click HERE for Genius support & drivers
Posted on May 15, 2008
  • 20 Answers
SOURCE: Logitech Freedom wireless joystick
i have had similar problems... it might be the disk also if the disk is really old it might not play properly becuase your computer is to new.but if that isent the problem your joy stick might only hook up to a desk top if you have considered these issues and nothng seems to effect it well ... get a joy stick that needs to be hooked up ... hope i helped
Posted on Mar 03, 2009
  • 412 Answers
SOURCE: reprograming the Pro Yoke Hatswitch
Go here --
http://www.fixya.com/support/p921647-saitek_pro_flight_yoke_system_flight_sim/manual-27479
Hope this helps..
Posted on Mar 24, 2009
SOURCE: maxfighter joystick not working in vista
EFO
Posted on Dec 16, 2009
MattP-MS
  • 32 Answers
SOURCE: MCFS Joystick Problem
Make sure, that your Joystick is compatible with the version you are having problems with. If not, make sure that it's enabled in the configuration of MCFS. If none of those work, you will most likely have to purchase a more compatible Joystick.
Matt P,
Computer/Gaming Relations Team.
Posted on Jan 23, 2010
Genius MaxFighter F-16U ... When i get into ANY game with Joystic support .. Jet fighters and etc ... I Pull the joystic and it wont pitch ...also it cant go right when i pull the stick to the right . ...
Hi, When you set your joystick up using the in game controlls menu try this. Try setting the controls from the bottom up I will try to explain. Lets say in the controls menu from the top it starts like this> 1)Pitch forward 2)Pitch backward 3)Roll right 4)Roll left. Start with pitch backward and pull the joystick back, It should auto input the pitch forward control. Next you would move on to roll left, It should auto input the roll right control. Get what im saying, You should only have to input one direction the other should auto input. Had the same problem with my LG extreme pro for BF2. Hope this helps good luck!
Jan 04, 2011 | Genius MaxFighter F-16U. USB PC Joystick...
Is MaxfFighter F-16 U good to play with in FSX?
If this is a USB device and the driver has been installed, chances are it will work.
If you go to the Setup in the Flight SIM program and can select/configure the joystick, then it will definitely work.
Oct 09, 2010 | Genius MaxFighter F-16U. USB PC Joystick...
Where can i find instructions for F-16u
Hello iewe_sch, You can find the manual at http://www.geniusnet.com/. This website is terrible and has no direct links to the manual so here is the path from the homepage:
  • Click the Service and Support tab
  • Scroll to User's Manuals
  • Select Product line --> Gaming
  • Select model --> MaxFighter F-16U
Please rate this solution if you found it helpful. Thanks, Edward
Aug 22, 2010 | Genius MaxFighter F-16U. USB PC Joystick...
Joystick wont bank left or pitch up on fsx using windows vista?
Check you have the latest drivers for it and that it has been calibrated correctly. This should solve it for you. Good luck!
Mar 04, 2010 | Genius MaxFighter F-16U. USB PC Joystick...
Have a Genius F-16U usb joystick no drivers needed but my XP does not recognize it
"Genius F-16U usb joystick no drivers needed"  sic. Are you sure? MOST things need a driver especially USB devices?  Check in "device manager" and see if it shows up there.
Feb 01, 2010 | Genius MaxFighter F-16U. USB PC Joystick...
I have installed and callibrated but still wont work when gaming
go in your game go options key confg set it to joystick and set controls if there is no opt. to change to joystick the game doesnt sapport the joystick
Nov 12, 2009 | Genius MaxFighter F-16U. USB PC Joystick...
When I bank right or left with joystick the screen Freezes
To check the joystick isn't the problem, go into control panel game controls, then check that the joystick appears and you can move the cross-hair around on screen, most modern joysticks are
auto-calibrating, but you could try running the calibration.
To check the game isn't a problem, unplug the joystick, then use the arrow keys to fly the plane, if it doesn't crash when you bank then it isn't the game.
I assume the game is Combat Flight Simulator 3, as very old games that were written for Windows 95,98,ME series often won't run on Windows NT,2000,XP,Vista as they are completely different versions of Windows. If this is actually Flight Simulator 3, you may need to consider buying a later version of Flight Simulator (FSX is the latest version, but may not run on your laptop).
Other things to try are updating the graphics card driver.
Norton shouldn't need deactivating, although it could cause problems if you're playing online.
Also remember that laptop graphics cards are never as powerful as desktop graphics, and games very rarely specifically support laptop graphics.
Hope this helps.
Jan 21, 2009 | Logitech Extreme 3D Pro Joystick
Genius MaxFighter F-16U. USB PC Joystick with Turbo . Logo
181 people viewed this question
Top Genius Video Game Consoles & Games Experts
James Wishart
Are you a Genius Video Game Console and Game Expert? Answer questions, earn points and help others
