Question about Panasonic VIERA TH-65PV500 65 in. Plasma Television
58 inch Panasonic plasma not working with U-Verse STB. have tested the HDMI ports on the plasma with other equipment and they work fine. I have heard the issue relates to the many "handshakes" which take place between the STB and plasma. Can you assist?
  • Panasonic Master
  • 736 Answers
Until U Verse comes up with a solution they advise television owners to use component cables. The other solution that works sometimes is to turn off and unplug the UVerse for a minute to reboot it every time you turn it and the television on for the day.
Posted on Sep 14, 2010
None of my HDMI ports are working, but my DVD player works
I hope I can help with this. It may not be the HDMI port. When you change ports, are you changing the TV video source input on your tv to verify that they work? That is what will need to be done in order test properly.
Jul 28, 2016 | Panasonic Viera TH-50PX80U Plasma TV
Panasonic tv hdmi inputs not working
It appears that during the storm there may have been an electrical surge that damaged the electronics of your tv. If the tuner is working fine then the affected area (board) is the one that has the HDMI input sources.
Aug 30, 2015 | Panasonic Viera TC-P58S1 58 in. Plasma...
Panasonic LG plasma no audio on hdmi 1
HDMI cord may be faulty. Try the cord that works on the port that doesn't If it works then the HDMI cord is bad. If it doesn't work then the HDMI port may be bad on the TV.
Dec 29, 2012 | LG 42PC3RA 42 in. HD-Ready Plasma TV
Hi guys I have a Phillips Plasma TV 42PF5521D/10 model UK version bought in 2008 Guess what untill now i only used the HDMI ports to connect a Home Media Center PC to watch HD content. So last...
hi First, remember the old HDMI reset tech tip. Unplug all HDMI cables (one end will do.) Then remove power from all things in play. No, not just turned off but remove the AC. Wait 5 to 10 minutes, hookup re -test thanks
shaun .
Mar 09, 2017 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Hdmi on tv loses signal
Try another HDMI input on your set and see what happens.
Jul 26, 2017 | Panasonic Viera TH-50PZ80U Plasma TV
Everytime I use hdmi the colours are mostly green
I have a panasonic th42pa 60a SD plasma and I get the same problem WHEN USING CERTAIN HDMI cables. I had a connexa brand with my samsung stb that i got with the TV and I had no problems., but i had to replace that because one of the ends "frayed" when it was accidently yanked out of the tv socket. A high quality monster cable did the same green screen you describe. The cheapest "Crest" from Big W that did HDMI standard 1b worked fine, but a Rank Arena from Target did not. So buy the cheapest HDMI 1b cable you can, the picture quality and sound is the same as the more expensive stuff. BTW I tried a HDMI 3 way splitter as well and it did the same green screen thing, but it worked on a later model panasonic plasma. I think it is Pana's poor HDMI implementation.
Dec 05, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic home theater
switch the HDMI cable to another HDMI port (if available).
or use and AVI/COMPONENT to make sure the device (HOME THEATHER) is working fine.
Try also another HDMI cable or hook another device into it to see how it works.
If you determine the HDMI port in not working properly, then your Mainboard is damaged and need to be replaced, try EBAY for a general picture of prices but you will need your product code wich is located in the back of the TV next to serial number.
May 14, 2009 | LG 50PG20 50 in. Plasma HDTV
Panasonic VIERA TH-65PV500 65 in. Plasma Television Logo
57 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
