Question about Kenwood Car Audio & Video
Ok i basically have a kenwood kac-6404 amp and its a 2/3/4 channel i was wondering how i can alter them or switch it from 2 to 3 to 4
  • 138 Answers
I guess there is no switch. its how you wire the outputs together to create 1 channel from 2 channels. consult the wiring guide that goes with your amp
Posted on May 16, 2008
Ihave a keenwood kac 7252 amp that is running two mtx thunder 4500 12`s but amp fuse keeps blowing at higher volume why?
1.-check proper heat sink, or dissipation.
2.- check speaker impedance. Must match between amp and speakers.
3.-low power line on the house may cause low efficience work on the amp, overheat, and finally fuse protection.
4.- finally, check speaker wires. Thin cable overheat amp too.
Nov 23, 2014 | Kenwood Kac-7252 2-channel 1000watt Power...
What is the rms outpur of my kenwood KAC 848 amp
rms at 4 ohms is 50x4 in 4 channel mode if your in 2 channel mode then its 150x2 if at 2 ohms then it would be 4 channel 75x4.
Jul 28, 2010 | Kenwood KAC-848 Car Audio Amplifier
Wut would be a good amp to power my 2 10 inch srw 1051 clarion subs
Here is a good Amp for your Clarion subs, , remember Clarion subs cant handle too much power, clarion is more of a radio and speaker company, Subs are not really their market. Go easy with them :Here is a link with the amp and price I recommend :
http://www.shopping.com/xPO-Kenwood-KAC-6404
Jun 20, 2010 | Clarion SRW1051 Car Subwoofer
The subs aren't pushing out bass.
Hello crobins2,
The Kenwood KAC-6202 2-channel is only rated for 60 watts RMS per channel into a 4 ohm load. That just isn't much power for a pair of 12" subs. Even the bridged output is only 200 watts into 4 ohms, still at the low end for a sub, much less to share between a pair of subs.
Assuming that your subs are 4 ohm, you could probably get more sound by driving just one of them on the bridged terminals. But to get the best power with what you have, connect one sub to each channel, set the filter switch to the far right (LPF), set the operation switch to stereo (both channels driven), set the filter frequency (Hz) to 100 or lower, and adjust the input sensitivity as far clockwise as possible without causing distortion.
But, to do the subs justice, you really need at least 300-400 watts to share between them.
Hope this helps.
Sep 27, 2009 | Kenwood KAC-6202 Car Audio Amplifier
KAC-8070 kenwood 4-channel power amp
Audio section
Max Power Output (4 ohms, 1kHz)
Rear 70W + 70W
Front 35W + 35W
Max Power Output (4 ohms, 1kHz, 10% THD)
Rear 45W + 45W
Front 25W + 25W
Max Power Output (4 ohms, 1kHz, 1& THD)
Rear 37W + 37W
Front 20W + 20W
Frequency Response (-3dB)
Rear 2 Hz ~ 100 kHz
Front 5 Hz ~ 50 kHz
Sep 27, 2009 | Kenwood KAC-8101D Car Audio Amplifier
KAC-9104D output terminals
ok i have the same amp and 1 2ohm dvc sub and was woundering the same thing but from futher research and askin sum xsperts. What i found out is that it is only one channel and even tho there are 2 (+) and 2(-) they actually connect inside the amp makein it one . so if u wanted to wire sumthing parralel u wouldnt have to hook wires from one coil to the other on the speaker , u can just hook it up to the amp. so basically both +'s and negatives on the amp are actually one within it so all the power if you only use one set of them and if u wanna add more subs its just easier to add to the amp by using the xtras .
Jan 13, 2009 | Kenwood KAC-9104D Car Audio Amplifier
Wiring
hi!well i think you should use both channels.because if you'll use both channels then u'll have high power to your subs.i have tryed it and i prefer you use both channels.
Jun 26, 2008 | Kenwood KAC-9102D Car Audio Amplifier
My 800 watt kenwood
Sounds like you shorted out the main power wire somewhere and killed the amp. Is the amp on the fuse intact or blown? Do you have 12 volts at the amp? check you connections and see if it helps.
Jun 03, 2008 | Kenwood KAC-7201 Car Audio Amplifier
Transistors
If it's only 2 months old, it should be under warranty. Have you tried to get it repaired under warranty?
Any car audio repair shop should be able to repair it.
If you want to repair it yourself, it's possible but you'd need basic test equipment and soldering/desoldering tools.
The following page shows you the basics for amp repair. Your amp is somewhat different than the one shown but the troubleshooting/repair procedure would be similar.
Basic Amp Repair Primer
May 16, 2008 | Kenwood KAC-8103D Car Audio Amplifier
Power of amplifier
If the KAC-7252 is to be bridged, the operation mode switch on the top of the amp is set to mono. When switched to Mono, the signal from the left channel input only is used. Bridging creates 4 times as much power so the KAC-7252 delivers 170 Watts per channel so that 340 watts total so that value 340 is multiplied by 4 and that gives you 1360 watts of power. so it will drive them.
Aug 27, 2007 | Kenwood KAC-7252 Car Audio Amplifier
Car Audio & Video Logo
51 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
