Copier: Ricoh CL7000 has a code 542- probably needs to have a fuser reset. Can you help?
  • aplusbe Sep 14, 2010
    ZJL-
    Re: Copier: Ricoh CL7000 has a code 542- probably needs to have a fuser reset. Can you help?
    Really just need the reset procedure- Service mode, etc. The fuser has been repaired professionally.
  • 17,970 Answers
This error code means temperature fusing problem; you need to check good or bad heat lamps.
1.- Check each lamp in fuser.
- lamp is good if you get continuity
- lamp is bad if open
2.- Check the thermostat
- thermal control device
- triggers if unit gets too hot
3.- Also check thermistor
- monitors temp of fuser, two total (middle and rear)
If heat lamp is good: your best bet is to change all three items:
- Fuser thermostat - thermal control device
- Fuser thermistor (middle front) - thermal control device
- Fuser thermistor (rear) - thermal control device
These items wear out. Change at the same time. Fuser needs to be rebuilt or replaced (check for wear and tear)
Also, you could register in this forum copytechnet.com/forums to know details about TSB for the error-code-sc542 (PDF File Attached)
Hope helps.
Posted on Sep 14, 2010
  • ZJ Limited
    ZJ Limited Sep 14, 2010
    In order to clear error SC542, you must perform procedure 5810.
    • Press and hold online + escape, then power on.
    • Use up and down arrow keys to select SP2
    • Press Enter
    • Use up and down arror to locate SP5
    • Press Enter
    • Use up and down arrow keys to select 810
    • Press Enter
    • Confirm the selection
    • Power off and on.
    The error code is now cleared.
    In this LINK have the procedure: ricoh-error-code-sc542
    Good luck.
Service code 542
fuser problem, push in order clear modes (yellow button) 1 0 7 and hold the red stop button for 5 seconds the screen will change, turn off copier red power switch and turn back on if problem comes right back you need a service call
Sep 30, 2013 | Ricoh Aficio 450 Copier
Problem Ricoh CL 7200 error SC 542
fuser assy replace it and reset code or have tech come out and fix it
Jul 19, 2013 | Ricoh CL-7200 High Yield Toner Refill Kit...
How to reset the fuser error ( error code sc 542) in ricoh 1400
press yellow cancel and 107 and hold on 5 sconds on red cancel and yo will see 1 go to 4 and select 810 and press 1 simultanously with photo press you will see reset accepted or succes
Mar 25, 2011 | Ricoh Aficio 2015 Copier
Ricoh ft5832 code e5 47
E547 is a level A code (need to do a fuser SP reset, copier is inop) the fuser lamp continuosly stays on. Probably a shorted triac or fuser board problem.
Apr 12, 2010 | Ricoh FT5832 Copier
"xerox machine ricoh aficio 1018d error code ca:542 "
you have a fuser code. power cycle the machine. use the red off/on switch. turn off for 30 sec. turn back on. if code is still there have a tech fix it. could be bad thermistor, measures tempature. bad lamp, creates heat. thermofuse, protects from met down,. bad power supply, supplies power. bad main pcb, controls everything. most likely needs fuser rebuilt
Dec 31, 2009 | Ricoh Aficio 1018D Copier
My Ricoh Aficio 1027 has a fuser code SC542. Is there a way to reset this in service mode (I know how to get in) to continue printing or will I need to replace or repair a part? The copier no longer has a...
to reset it just enter service mode and cycle power. But first take out the fuser ( right side of copier 2 screws ) and check that the 2 rollers hot and pressure are touching each other no gap between them. The unit you have is a nice unit, for service to fix if replacement is required would be about 300.00 or so... -Carl
Jul 24, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
I have a ricoh aficio 2035 that reads error sc 542
Fuser warm up error. Repair problem (fuse, lamp, thermistor etc.) then reset code in service mode.
Jun 25, 2009 | Ricoh Aficio 450 Copier
Sc 542
SC 542 is a fuser code that may need resetting. and this should be only done by an qualifyed service representitive as it requiers going into service mode and going into copy sp 5-810 and having it reset or if this does not work you may need a new fuser unit! Again service mode will need to be entered to reset the SC542 as this is a safty feature built in to the copier to keep it from ferther damage
Jan 13, 2009 | Ricoh Aficio AP3800C Laser Printer
Sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Aug 13, 2007 | Ricoh Aficio 2015 Copier
59 people viewed this question
jasbo
jasbo
