How do i connect my mikomi am216 5.1 surround sound to my sky hd box?
5 Suggested Answers
markevans
  • 148 Answers
SOURCE: LG 42LC2D-EC NO SOUND ON HDMI
your setting for source of the audio is probably defaulted back to original setting in receiver. reassign audio input and problem may go away. it sounds like its not in the tv. i assume you have a receiver and are not trying to listen with speakers in tv. is this correct? if you are not using an amplifier, you may need to go to the tv menu to make sure the audio source is selected as the hdmi input. should take a bit to read thru the manual, but it ought to show you how to accomplish the correct settings.
let me know if it does not.
good luck
mark
Posted on Dec 23, 2007
  • 905 Answers
SOURCE: LG 42PG6010 sky code
this might work 0206
if not check here http://www.satcure.co.uk/tech/digicode2.htm#contrib
Posted on Oct 24, 2008
SOURCE: code for mikomi 15lcd250 to use my sky remote
You have probably solved this by now anyway, but I have the same tv and the code 0065 works.
Posted on Jun 06, 2009
  • 325 Answers
SOURCE: HOW TO CONNECT SAMSUNG 40 LCD TV TO SAMSUNG
you will need the following = HDMI LEAD
Optical Audio Lead
Red and White phono Lead
Sky HD Box > connect to Tv via HDMI Lead.
Sky HD box > Connect the optical Audio, and the Phono Leads To your Surrounds sound.
The reason I am wanting you to connect the phono's as well as the optical audio out. Not all programs are transmitted with Dolby D so you will need these for normal sound to come through your surround sound.
One last thing I would like you to check is the sound settings on your Hd box.
OLD PROGRAM GUIDE:
On your sky remote. Press SERVICES, 4, 2, then ensure that Dolby D is displayed if not highlight and using the blue button change this to Dolby D. then arrow down to save.
NEW PROGRAM GUIDE:
On your sky remote. Press SERVICES, 0, Arrow along to SOUND then arrow down and change this to DOLBY D Then press the GREEN button.
Hope this Helps you out. IF so please leave a thumbs up
Little Dish Fitter
Posted on Sep 26, 2009
Philips: HTS3520 doesn't use surround from HDMI feed from SKY
Check your connections and the settings in the menu.
Good luck
Mar 11, 2014 | Philips HTS3520/05 5.1 ch Home Cinema...
I have a LG TV 37LC46-ZC with LG surround sound DVD Player/Amplifier LH-T550TB and a Sky HD Box. This used to work fine through the scart leads on the old sky box but since I changed over to HD Box I...
I know that's not all that helpful at the moment but I know that the no video out (to run a 2nd tv) that's there way of getting you to have a 2nd sky box I hope that is not the case with audio but it is a possibility ..try using phono plugs
audio out (RED WHITE omd audio in on your amp I have a look about and repost
Nov 26, 2017 | Televison & Video
I have an lg ht805ph surround sound system attached to my SHY plus HD Box.Sometimes the sound is out of sync with the picture.How do I stop this happening?
the probable reason it is happening is the delay in your sky box decoding the signal and the surround sound decoding the audio. Have you tried taking the sound from the tv output and using that as the input for the surround sound and not taking it driectly from the sky box, which i am assuming your doing. If you turn off the LG and listen to the sound through the tv is it in sync, if its a random happening then it is the signal quality of the sky receiver thats at fault
Mar 10, 2011 | LG Televison & Video
Currently i have a sky hd box connected to my tv by a hdmi cable i want to connect my ipod into the sky box so i can play music videos ipod and sky box are close together and i don't want to connect ipod...
This isn't possible, the USB on the front of the Sky HD box is not active. I don't have any information on whether it will be in the future.
Your only option is to connect the iPod via TV or if you have a surround sound amp
May 21, 2010 | LG LH-D6230 System
How to get surround sound?
Hi, I would recommend using an optical cable from your Sky box to your surround system. The should look like this:
http://files.sandberg.it/products/images/lg/505-39_lg.jpg
Feb 16, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
HOW TO CONNECT SAMSUNG 40 LCD TV TO SAMSUNG SURROUND TZ215 THRUGH SKY + HD BOX.
Optical Audio Lead
OLD PROGRAM GUIDE:
NEW PROGRAM GUIDE:
Little Dish Fitter
Aug 26, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
How do i connect to sky hd and sony kdl 40w 4710 and dav-is10 i have hdmi from skyhd to tv and hdmi from home cinema to tv what else is required as i cant get surround sound from tv
you need a Optical audio cable, run this from the back of your Sky HD box to the Surround sound. Not all Broadcast are transmitted in DD so press your i button on the sky remote and you will see this on the yellow bar above the program information if it is..
Might be worth running a set of White and Red audio cable from the HD box to the Surround sound as well that way you can just mute your telly and have the lot coming through the surround sound system.
Hope this clears things up for you
Little Dish Fitter
Jun 05, 2009 | Sony DAV-IS10 System
5.1 sound from Sky hd through LG TV
link your optical cable from your HD box to your surround sound.
Then if you go into your HD services menu, press 4 then go to sound make sure its set to Dobly D
That should sort your problem out
Cheers
Little Dish Fitter
Feb 24, 2009 | LG 37LC7D 37 in. LCD HDTV
Set up surround sound with the following
YOU CAN ONLY GET 5.1 FROM THE OPTICAL OUTPUT ON THE SKY BOX NOT THE HDMI
SO CONNECT YOUR SKY BOX OPTICAL TO TV OPTICAL
PLZ LET ME KNOW IF THIS HELPS
JonnieC
Aug 10, 2008 | Pioneer PDP-4270HD 42 in. Plasma...
Open Questions:
Televison & Video Logo
216 people viewed this question
Top Televison & Video Experts
