Question about Toshiba HDDR500E04XL 500 GB USB Hard Drive
I have ROCO 320 GB extranal hard disk which is not recognized in my laptop windows 2007. I had stored so many data from my desk top computer. Any solution please.
  • 4,281 Answers
Connect your harddrive to another computer like windows xp then if it is recognize then take data backup . If your harddrive is fine then follow below for laptop. First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
Posted on Sep 14, 2010
MY PC WINDOWS XP ASKS TO FORMAT MY STOREJET 25 320 GB TRANSCEND PORTABLE HARD DRIVE
If it's asking to be formatted you need data recovery help. For remote data recovery and do-it-yourself data recovery see http://FreeDataRecovery.us
Sep 04, 2012 | Transcend StoreJet 25 Mobile - Hard drive...
My computer do not recognize the toshiba roco HDD
Dose it show up as drive letter E:/ under device manager in disk drives?(Check out:right clicking my computer icon on your desktop,select disk manager)
If so,try right clicking on my computer and selecting map network drive.(You'll get the same results by right clicking on network neighborhood icon on your desktop and selecting map network drive.)This is the method many people use to assign a drive name (i.e.,letter) to a drive.Then you can recover data from external hard drive with data recovery software like Tenorshare Data Recovery.It can recover data after deeply scanning your hard drive to look for lost data.You can get it here: http://www.any-data-recovery.com/product/datarecoveryprofessional.htm
Aug 27, 2011 | Toshiba 120GB USB 2.0 Portable External...
Hi, I have a 320 Gb StoreJet (with Elite software inside). My problem is that I can't save more data althought I have only 70Gb stored. The message says "Insufficient space".
Hmm, pretty weird.
Try to backup your data to your PC and FORMAT your USB disk.
(This Computer ->?Right click on your USB disk -> Format)
May 20, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
I got a transcend 320 GB external drive with data on it but windows 7 says I need to format it before using it. I know it is formated in FAT but that all I can see. EASEUS said there was a problem but...
Make a linux boot disk. Boot your computer with this disk. Retrieve all data to other disk. than reboot windows 7 and format disk.
LinuxMint life cd, does not install.
http://www.linuxmint.com/download.php
Feb 13, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
I have a Hitachi external USB hard disk 320 GB. it was working fine at may laptop but when i tried using it with computer, the Windows cannot detect the USB Drive. i tried it with 2 computers. but its...
i have a Hitachi external USB hard disk 320 GB it was working fine at may laptop but when i tried using it with the computer ; the windows cannot detect the USB Drive . i tried it with 2 computer . but its still the same .pleas help i badly need my files
Dec 05, 2010 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
Can I use my current w d. external hard drive with my laptop computer as well as my desk top.
you can only use it as an external on the laptop if you use it as an external you can use on the desktop just plugging the usb also if your motherboard has sata conection you could install it into your desk top.
Oct 06, 2010 | Western Digital (WD3200JS) 320 GB Hard...
WD external Hard drive 320 GB hangs my computer everytime connect
Try the external hard-drive in some other computer.
If it still causes problems, then it is the external hard-drive, not your laptop, that has the problem.
If the warranty on the external hard-drive is still valid,
exercise the warranty to get a replacement.
If the warranty has expired, you could try to "disassemble" the casing, to remove the "internal" hard-drive that is "inside" the casing.
Then, connect that hard-drive to a desktop computer,
and copy your data to the 'C:' drive (or burn your data to CD/DVD disks), if you can -- it's possible that the "electronics" that convert the USB-interface to the hard-drive interface is the problem, and that your data on the hard-drive is perfectly OK.
Nov 16, 2009 | Western Digital Elements powered by WD 320...
No manual for 320 GB desk top hard drive
its a plug and play just connect to the sys and start working on it
but be careful that u connect the power to the Ext.HDD first and then after that connect it to the USB port
similarly safe remove from the Sys and remove it only after u see the msg It is safe to remove the USB drive disconnect the USB cable from the Sys wait for 20-30 secs ten power off the HDD for better performence of the Ext HDD
Jul 27, 2009 | Electronics - Others
Toshiba HDDR500E04XL 500 GB USB Hard Drive Logo
212 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
