Question about Microspeed KidTRAC Trackball
I appear to have an older version of this made by universal desktop systems. The model no is PD-380. It has a five pin connector with a large black horizontal pin . Is there any way this can be used or converted? Thanks, Frances Maclagan
Acer aspire m3201 pc power supply unit,output looms connectors have identification markings on them PI/PA/PB/PC/PD/PE/PF/PG .I want to know which componets the Molex type connectors fit. the PC has On
The Molex connectors in a desktop PC are keyed to ensure proper placement. The 4-pin flat connectors that are flat on the bottom and have beveled edged on top are connected to hard drives, CD, and DVD-ROM drives that have matching power sockets. Those devices that have Molex sockets usually have the 40-pin ribbon cables for IDE devices. There will be a four-pin square connector that connects to the socket on the motherboard for the CPU power. Then there is the 20 or 24-pin connector that is the motherboard main power.
Jan 13, 2015 | Acer Computers & Internet
Mitsubishi wd-62628 flashing error code 41 (short) now what?
Short detected in standby power supplies. on pwr PCB check the following:
1)12VS @ connector PD pin 14: possible cause;IC9A23 circuit
Zener D9A41
2)5V @ connector PC pin 8: possible cause;IC9A21 circuit
Q9A12 circuit
zener D9A47
3)4.5V @connector PD pin 16 possible cause: F9E10
F9E11
Dec 28, 2014 | Mitsubishi Televison & Video
Where does the black wire on the valet switch for a older model viper 300 12p pin ongl with gray valet wire
Hello Jesse,
I am not sure what kind of a valet switch that you currently have for replacement, however all viper systems use a two wire connector, with one gray wire and one black wire and a blue connector on the end. All this does when you hit the switch is series, or connect the two wires. The brain reads the number of pulses that is receiving the specified timeframe and then completes the command based on the set number of pulses. This connector is a separate 2 pin connector from the 12 pin main harness. This will be located when looking at the 12 pin harness on the right side of the brain.
Mar 06, 2014 | Viper Vehicle Parts & Accessories
Need a power supply model number for Gateway model GM4019E
Gateway GM4019E Cool Power Gamer Pro 875W 20+4-pin ATX Power Supply w/SATA PCIe & Dual 12V Rails (Titanium)
The Power Supply features one 20+4-pin ATX power connector, six SATA connectors, six large Molex... More Details
SKU: 50563-425048
Jan 30, 2013 | Computers & Internet
I tried to remove the password that appears when I boot up my computer. I went into the bios to do this and when I restarted the computer it still asked for a password but my previous one no longer worked....
If you forgot the system password it is hard to retrieve it. The best thing you can do is to clear the cmos and reset it to factory default.
There is a clear cmos jumper pins on your motherboard (usually located beside the battery). In older versions of motherboards, these are 3 pins but in newer versions there are only 2 pins. In the older versions of motherboards, the 2 pins have a jumper cap during normal operation, pins 1 and 2 are shorted (number 2 pin being in the center). In order for you to clear the cmos, all you have to do is short pin 2 and 3 for a few seconds using the same jumper cap or by using a screwdriver. After shorting the 2 pins, return the jumper cap to its original position.
In new motherboards, all you have to do is short the 2 pins for a few seconds. In normal operation, these 2 pins are open.
Please turn off your computer and unplug the power cord before clearing the cmos values.
Sep 07, 2010 | Computers & Internet
Where are the switches on an older motherboard to alter the configuration of the motherboard
This will be found right near the CMOS battery
Locate the 3-pin CMOS jumper (RTCRST) on the system board.
Remove the jumper plug from pins 2 and 3.
Place the jumper plug on pins 1 and 2 and wait approximately five seconds.
Replace the jumper plug on pins 2 and 3.
Sep 23, 2009 | Dell Dimension 3100 PC Desktop
TK 380 diplays "FPU OLD!"
This means that you need an older version of software. to program the radio. When it comes to Kenwood the newer version software will not program the older FPU Version radios.
Patrick Patterson N5SLI
Radio Service tech Manager
May 30, 2009 | Kenwood KNB-17AM, TK-280, TK-290, TK-380,...
Logitech QuickCam Communicate MP - black screen
  1. Either one of these image sizes:
    • Small image size: 160 x 120
    • Large image size: 320 x 240
  2. RGB, I420, or IYUV formats. (Each is fine; we recommend RGB 24.)
  3. Microsoft DirectX version 9.0
To get this information, click here to download a Microsoft application that checks to see if your webcam device meets these requirements.
To make it easy, when you’re asked where to Save the program, just save it on your Desktop.
Once it’s downloaded, here’s what to do:
  1. Double-click the amcap.exe file on your desktop.
    • If you have more than one webcam installed, click the Devices menu and select the one you want to use.
  2. Click the Options menu, then click “Video capture Pin.”
  3. Under “Color Space/Compression:”, choose one of the following formats:
    • RGB 24 (our recommendation)
    • I420
    • IYUV
    Note: If one of the options above isn’t in the list, then your webcam is not compatible with Yahoo!7 Messenger.
  4. Under “Output Size”, choose one of the following:
    • 160 x 120
    • 320 x 240
  5. Click OK
  6. Close the ampcap application.
  7. From your desktop, click ‘Start’ and select ‘Run’.
  8. In the run box, type: dxdiag
  9. In the confirmation dialog box, click OK.
  10. On the System Tab under ‘System Information’, look for DirectXversion. Verify that your version is DirectX 9.0. If it is, just click Exit. If your version is older than 9.0 (any lower number), click here to download the latest version of DirectX.
  11. Start the webcam from Messenger by clicking My Webcam in the Messenger menu.
Attention Logitech webcam users:
Some Logitech webcam drivers may cause one of the following problems:
  • Windows freezes when accessing the webcam
  • A black screen appears when using the webcam in Messenger
  • A ‘Webcam not found’ error message appears.
  • After 3 seconds, the sound drops out of calls made via Messenger
If you already verified that your device is compatible through the above steps and you’re a Logitech webcam user, please click here to update your Logitech webcam driver.
Dec 16, 2008 | Computers & Internet
Psu
The motherboard will only draw the wattage/current it needs.
Be carefull with Branded machines often their components are proprietary.
Remove the 20 or 24 pin connector to the motherbaord and compare the colour coding of the pin outs with the examples shown on this site.
http://pinouts.ru/pin_Power.shtml
Jul 23, 2008 | Acer Aspire T690 (AST690UP820A) PC...
Fuse box
Wiring relays and connections – all modelsRelays (typical)
1 Vacant
2 Intake manifold preheating relay (carburettor models) or fuel
pump relay (injection models)
3 Seat belt warning system relay
4 Gearshift indicator control unit
5 Air conditioner relay
6 Dual tone horn relay
7 Relay for foglights and rear foglight
8 Relief relay for X contact
10 Intermittent wash/wipe relay
11 Rear window wiper relay
12 Turn signal flasher or trailer towing warning relay
13 Seat belt warning system (interlock) or rear window, driving
lights and oil pressure warning relay
14 Window lift or seat belt warning system relay
15 Headlight washer relay
16 Control unit for idling speed increase
17 Fuse for rear foglight
18 Control unit for coolant shortage indicator
19 Thermo fuse for window lifters
20 Switch unit for heated driver’s seat
21 Switch unit for heated passenger’s seat
22 Switch unit for overrun cut-off
23 Vacant
24 Vacant
Relays are symbolised as a number in a black box
Not all relays are fitted to all models
Connections
A Multi-pin connector (blue) for dash panel loom
B Multi-pin connector (red) for dash panel loom
C Multi-pin connector (yellow) for engine compartment loom left
D Multi-pin connector (white) for engine compartment loom right
E Multi-pin connector (black) for rear wiring loom
G Single connector
H Multi-pin connector (brown) for air conditioner or wiring loom
K Multi-pin connector (transparent) for seat belt warning system
loom
L Multi-pin connector (black) for lighting switch terminal 56 and
dip and flasher switch terminal 56b (carburettor models) or
multi-pin connector (grey) for dual tone horn (injection models)
M Multi-pin connector (black) for lighting switch terminal 56 and
dip and flasher switch terminal 56b (injection models)
N Single connector for separate fuse (manifold heater element)
P Single connector (terminal 30)
R Not in use
Fuse colours
Blue 5A
Green 30A
Red 10A
Yellow 20A
Jul 17, 2008 | 1987 Volkswagen Jetta
Microspeed KidTRAC Trackball Logo
32 people viewed this question
Top Microspeed Computers & Internet Experts
David Payne
David Payne
Are you a Microspeed Computer and Internet Expert? Answer questions, earn points and help others
