Question about Water Heaters
Pilot light will not light - Water Heaters
    Filmmaker:
    Uploaded 5 video answers.
  • 119 Answers
Make sure there is gas. Install a new thermocouple. Call the 1-800 number on the tank for for free parts if it is still under warranty.
Posted on Sep 14, 2010
I light pI lot and it stays lit burners light and reach temp but then burners wont relight to keep temp unless I tap gas valve..is it my gas valve
A lot of pilot lights have a thermal coupler... the pilot light must be lit for several min to open the coupler so the pilot light will not go out.... the newer systems use an electronic ignition and no pilot light and need power to autostart but the coupler may be gone if you are holding that pilot start button down for several min and the pilot light is still going out..ps.. leave it in pilot mode for several min after initial start up before turning turning full burner operation operation operation operation operation operation operation it will snuff out the pilot light.
May 18, 2016 | Water Heaters
Wher is pilot light
Why will my pilot light on the gas water heater not stay lit for ...
diy.stackexchange.com/questions/.../why-will-my-pilot-light-on-the-gas-...
Jul 28, 2011 - The pilot light went out on my gas water heater. I followed the ... This could be from a valve not being all the way open. It could also be from a ...
How To Relight Your Pilot Light On Your Water Heater ...
? 7:54
https://www.youtube.com/watch?v=gqM7kMkkFAI
Apr 15, 2013 - Uploaded by TipsNNTricks
How To Relight Your Pilot Light On Your Water Heater. TipsNNTricks .... I answer the following questions in this video. How can I relight my pilot ...
How to Light a Water Heater (with Pictures) - wikiHow
www.wikihow.com/Light-a-Water-Heater
wikiHowJump to Questions and Answers - If the pilot light doesn't relight or goes out immediately after ... if you are unable to light the water heater after several attempts.
Jan 13, 2016 | Water Heaters
PILOT LIGHT KEEPS GOING OUT.
If the pilot flame is weak, when the main burner is ignited, there can be enough 'whoosh' of air and gas to blow out the pilot. There may be a little of grit in the pilot valve jet hole restricting the flow, hence the weak flame. Try using a piece of fine wire to clear the obstruction. If that does not help the pilot jet will have to be unscrewed and cleaned with compressed air. Ensure the gas is turned off before attempting any maintenance.
Sep 13, 2010 | Reliance Water Heater #6-40-GBRS 40GAL...
The water heater pilot does not stay on?
The pilot light on hot water heaters is controlled by a thermocouple, a small copper rod that usually sits in or very close to the pilot light flame. When they go bad, which is not unusual, they do not allow the gas line to stay open and feed the pilot light. The easiest thing for you to do would be to replace the thermocouple. When following the pilot light lighting instructions, be sure to hold the valve button down for 30-45 seconds in order for the pilot light to heat the thermocouple prior to turning on the gas burner.
Sep 11, 2010 | Reliance Water Heaters
Pilot light will not stay on Bosch natural gas tankless water hea
Check to make sure the flame of the pilot is hitting the thermocoupling. If not then you can use compressed air to clean the pilot port and relight and check again. If the flame is hitting the thermocouple, then it may need to be replaced.
May 05, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
M# 640HORT4 s# H07A090378---MY Pilot Light wont
First thing is to replace the thermoscouple. When you light it you get it a bit hotter then normal. You turn on the main burner which keeps it hot. Then when it goes back to just pilot the flame is not hot enough to hold the pilot valve in.
Replace the thermocouple and you will be fine...
heatman101
Mar 26, 2010 | Water Heaters
After heating pilot goes out . my igniter is bad so i light manually and after heating main burner shuts off and so does pilot
The thermocouple that controls the gas to the pilot light must be bad. The thermocouple, when it is heated by the pilot light keeps a valve open that keeps gas flowing to the the pilot light. This thermocouple closes the valve that supplies gas to the pilot light, this is to prevent gas from continuing to escape when the pilot light goes out. This is a safety issue, I recommend that you call a professional about this problem. You might be able to repair it your self by replacing the thermocouple but I still recommend that you have it checked by a professional.
Dec 02, 2009 | Whirlpool Water Heaters
Water Heaters Logo
16 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
