Question about HP Photosmart M525 Digital Camera
Hp m525 on/off light blinks on for about 2 seconds and then flashes twice in a row and shuts off
  • Anonymous Jun 04, 2008
    I have the same problm with my camera when I turn it on/off light blinks on for about 2 seconds and then flashes twice in a row and shuts off
Ok you need to fully charge your batteris!! that always happens when batteris does not have enough charge!!!
Posted on Jun 04, 2008
My Sony Bravia TV - Model #: kdl-52z5100 no longer powers on. There's a red light that blinks twice whenever I attempt to power it on. Please help
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Jul 30, 2016 | Sony KDL-52Z5100 LCD TV
Source button
In TV Mode: Press & Hold Mute & Select for 2 Seconds (flashes twice in a row), Type 960, should blink twice
Jan 11, 2014 | Directv Televison & Video
I have a 2000 Sony projection tv. When I turn it on it has a blue screen then it shuts off in around 5 seconds. The light on front keeps flashing 8 times in a row. Any ideas?
8 blinks Driver SOS 3 SS Board (SS energy recovery circuit)
Consistently finding that as an answer. I would assume that is the part that is broken. The 8 blinks is an error code which points to this part being faulty.
Oct 24, 2012 | Televison & Video
Where do I find the wires that I apprently need to cross to get the check engine light to flash in order to get the codes?
Remove the kick panel just beside the left foot rest on the driver's side.
2) Locate blue wires.
3) Locate black connector. Hold it notch up.
4) With ignition off, insert one of the wires into top row, 2nd pin from left.
5) Turn key to on position, but do not start the car.
6) Watch blinky check engine light on dashboard. Count blinks. Long blinks = 10, Short blinks = 1.
7) Keep watching blinky light until you get mesmorized.
To clear codes (after problem has been resolved):
1) With engine off, stick the blue wires to 1st and 2nd pin in the top row counting from left on the
black connector, with notch facing up.
2) Start car. Shut off car. Remove pins.
3) Read codes to make sure they are clear. No codes = steady blinks at 1/4 second intervals. yhis is for the 94, 92 should be the same. have a good day !!
Jun 05, 2011 | 1994 Subaru SVX
"on" light flashes twice and then "blacks out"
IF power light comes on and a few seconds later goes off, do the self check this model has.
On front of set when this happens, press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and then release both buttons.
Watch the power light closely, it should blink a two digit error code like; 2 blinks, 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Dec 11, 2010 | Mitsubishi WS-65909 65" Rear Projection...
Power will not come on even after system reset. Pushed reset and LED flashes then after it stops flashing TV will still not turn on.
do self check: when it shuts off and power light goes off:
On front of set press and hold both menu and input (device) buttons for at least five seconds and release both buttons.
Power light will blink a two digit error code, like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code and I will assist you
SD TECH
Sep 24, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Red light blinking three times in a row
Service manual says 3 flashing red leds = eeprom error (main digital / video pcb).
Suggest you start by implementation of Fujitsu Service Bulletin PDP 0068-01 Main Digital pcb see:-ttp://www.eserviceinfo.com/download.php?fileid=43450
Mar 31, 2009 | Fujitsu Plasmavision P42HHA10 42 in....
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Power problem
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Jan 30, 2009 | Panasonic PT-47WX42 47" Rear Projection...
HP Photosmart M525 Digital Camera Logo
67 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
