Question about Premier P36S318BP Gas Kitchen Range
Premier gas range
The pilot light is burning but the burner in oven will not ignite
  • mgroch Dec 19, 2008
    I have the same issue. Pilot light for oven is on and when I turn the temperature up the pilot light brightens but no flame to the burner. No gas from the burner either as manually trying light burner does nothing.
docjohn174
  • 943 Answers
SOURCE: Oven will not light
hi thanks for the question. the part that's causing the problem is the bottom igniter. it lights up, but not hot enough to ignite the gas. replace, the igniter. thanks the appliance doc
Posted on Oct 06, 2008
aborcass
  • 2651 Answers
SOURCE: premier 30 inch gas stove oven does not light
do you hear any clicking when you try to start the oven portion of the range? if not lets try this, open the lower drawer so you can see the burner bar and mechanism for lighting the bake bar. as your watching the mechanism turn on the oven (nothing should happen as per your issue) while oven is on try lighting one of the top burners, any one will do wanna check if that lites the spark and in turn lites the oven pilot.if that does infact work you have a bad spark switch for the oven control
Posted on Oct 29, 2008
  • 3284 Answers
SOURCE: Premier GCK1000 Gas Range - Oven is 2 years old
Hi google the range they have there own web site and parts and own techs on a toll free number
Posted on Jan 27, 2010
  • 3284 Answers
SOURCE: 36" Premier gas range needs control center
Hi if you look on google you can find there wed site they should be able to supply spares
meztang
  • 112 Answers
SOURCE: Premier Pro•Series 36" Model P36S318BP
Sounds like you have shorted out the ignitor module and you may need to replace it. Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into. Hope this helps.
Posted on Jul 16, 2010
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Dec 01, 2012 | Tappan TGF320 Gas Kitchen Range
Oven pilot comes on but oven will not lite, burners work
The reason the oven ogniter will come on yet their is no heat in the oven is because that igniter is weak and not drawing the proper power to allow the gas valve to open. By replacing the oven igniter it will open the gas valve and once again heat the oven.
GENE
Oct 16, 2011 | Premier P36S318BP Gas Kitchen Range
The pilot light on the oven is on how ever the burner will not come on when the oven is turned up.
Their is 2 possible things that are causing the oven to not heat.
1) the pilot burner is clogged with build up and not burning corretly...the standing pitol light is small and when the oven is turned on the pilot enlarges and heats a small bulb connected to a tube on a gas valve,if the pilot burner is clogged it will burn the small pilot but will not enlarge to heat that bulb so the gas will flow to the main burner.If that is whats happening the pilot burner needs to be replaced.
2) the pilot burner is properly heating the bulb connected to the above mentioned gas valve but that gas valve is bad and not opening once the pilot has heated the bulb..so in that case that gas valve would need to be replaced
GENE
Sep 17, 2011 | Premiere Ranges GCK100 Gas Kitchen Range
Caloric range oven, older at least 20 years old, the range burners spark, but will not light, i am assuming that its electronic ignition, no pilot light?
If you don't smell gas, then it is probably electronic ignition and not a pilot light.
But if your oven and none of the range burners light, are you sure you are getting gas to the unit or from the range valve to the burners and oven? Can you light the burners with a match? If you can you can rule out the valve and incoming gas line, and concentrate on the ignitors.
Jun 07, 2011 | Kitchen Ranges
O'Keefe & Merritt Contempo Gas Stove Oven won't light
Probably needs the ignitor replaced. http://www.handymanwire.com/ubbthreads/showflat.php/Cat/0/Number/408747/an/0/page/332
May 24, 2010 | Kitchen Ranges
Premier 30 inch gas stove oven does not light
Oct 28, 2008 | Premier P36S318BP Gas Kitchen Range
Oven will not light
Oct 06, 2008 | Premiere Ranges SCK3XR Gas Kitchen Range
Gas stove the oven pilot lights but not burner
I HAVE THE SAME PROBLEM WITH MY GE GAS RANGE. THE PILOT LIGHT IS ON BUT WILL NOT IGNITE THE BURNER. WHAT IS THE PROBLEM. LINDA jolin49@yahoo.com
Oct 01, 2008 | Whirlpool SB160PEE Gas Single Oven
Oven & broiler not working
you ignitor is going out you will need to replace it the ignitor needs to draw a min of 3.2 amps in order to open the gas valve coil if short of this it will not open at thimes it may just have enough to open
Jun 28, 2008 | Hotpoint RGB528 Gas Kitchen Range
Premier P36S318BP Gas Kitchen Range Logo
53 people viewed this question
Top Premier Kitchen Ranges Experts
Paul Carew
ray gallant
Terry
Terry
Are you a Premier Kitchen Range Expert? Answer questions, earn points and help others
