Question about Dell Latitude D800 Notebook
D800 screen goes very dim. Looks like it is off, but if I look really close I can see it is still on.
  • Dell Expert
  • 393 Answers
1st change screen inverter if same then u need to replace LCD thats it .. Thanks
Posted on Sep 15, 2010
Hi there, my six year old dell latitude D800 lcd goes dark (not completely, but unreadable); (first brightness was jumping down and up). Two years ago I had such problem and solved by replacing the lcd...
Sorry to hear that, Paul. As far as notebooks displays go, the light behind the screen is the part most likely to go out. It generally does just that: it just goes out, though the screen itself works (the LCD is still generating a picture, which you said you can still see). Whether you run it dim or bright doesn't play much of a role.
Another inverter replacement is probably needed here, with the light itself (what the inverter is powering) an somewhat less likely explanation. In any case, the notebook will have to be opened up to do the work, where is where a lot of the cost comes from (unless you or a friend is doing the work for you).
Aug 08, 2011 | Dell Latitude D800 Notebook
Dell Latitude D800 no view on screen anymore.
Try pressing function the whatever f key a screen icon is on
Jan 17, 2010 | Dell Latitude D800 Notebook
I have the acer aspire netbook and it is stuck on blaCK SCREEN.alt f10 is not bringing up any sort of menu...what can i do?
so it's charged up or plugged in and the power indicator looks normal, then you press the power button and what is the sequence of events that follow?
also if you look really closely at the screen can you see anything very dimly appearing on the LCD?
Jan 13, 2010 | Gateway GT4016 Desktop PC
WXGA Display for Dell Latitude D800 Problem. When
replace either your cold cathode screen lamp or, your inverter board in your display
Aug 28, 2009 | Dell Latitude D800 Notebook
D800 laptop will not display on external monitor
Most laptops go into standby mode when the lid is closed. To stop this, (Windows XP) click Start, Control Panel, Performance and Maintenance, Power Options, then click on the Advanced tab, select "Do nothing" in the drop-down for "When I close the lid of my portable computer"
Feb 12, 2009 | Dell Latitude D800 Notebook
Acer 4520 light going dim
Normally the way it works is if you plug in your AC Adapter to a laptop the computer screen will Brighten up since its no longer running off of battery and is actually charging . The reason why it should go dim is when you unplug the Ac adapter it goes dim to save battery life and last longer. If you are getting a really dim you can check and make sure that the Ac adapter jack on the adapter or motherboard isnt loose and it could be having contact to the unit and be loose inside and every small movement causes it not to charge / charge in and out and would cause this Dim effect. Again this depends on how old the computer is and I dont really think its the LCD or backlight going bad but you can try to mess with the screen brightness and If im not mistaken on that model it should be the FN key and the Right > and Left < Key for lower and higher brightness. Give that a try and check the adapter connection and you can pin point the issue . Hopefully it doesnt come worst to worst which could be a bad LCD going bad or damaged lcd internal cable. Hope my answer helped guide you closer to a solution.
Aug 08, 2008 | Acer Aspire 5500 5570-2609 Laptop
Dell D800 screen looks like if it fizzing
you need to reinstall the Graphic Drivers. If you have Installed any antiVirus in recent days, try uninstalling it and reinstalling it back again. it seems as if the problem is with the graphic card and need to be replaced
May 01, 2008 | Dell Latitude D800 Notebook
Dell Latitude D800 Notebook Logo
52 people viewed this question
Alun Cox
