Question about Whirlpool Inglis IP4400 Washer
Dear Sir, I have a problem with my washing machine. The problem is when I am touching the body of the washing machine I am receiving electric shock. Can you tell me the cause of this problem and also how to rectify this problem. Yours faithfully, Dominic
  • Whirlpool Master
  • 8,220 Answers
The machine needs a piece of copper wire attached to the frame to ground.
Posted on Sep 14, 2010
All lights are working belt is attached dunno why ifs not filling up or moving when I switch a wash program on but make a slight buzz as if it wants work
How to Check a Washer when Is Not Filling With Water OTHER washers test similiarly
# Test procedures to follow when a GE Hotpoint washer is not filling
* Disconnect the washer from the wall outlet
* Set the timer dial on regular and pull the knob to turn the timer push-pull switch on
* Set the temperature switch to the cold/cold setting
* Open the controls panel to gain access to the water mixing valve solenoids
* Touch the 2 terminals on the cold water solenoid with your volt meter test proves. Make sure that your body don't touch the washer cabinet, this eliminate the chance of getting an electrical shock.
* Have someone plug the washer cord for you while you check the voltage
* The reading should be 120 volts
* Touch the 2 terminals on the hot water solenoid with your volt meter test proves. Remember, to keep your body from touching the washer cabinet to eliminate the chance of getting an electrical shock
Have your helper plug in the washer cord again so you could check the voltage at the hot water solenoid
* The reading should be 120 volts. If you get 120 volts, this tells you that the wall outlet, the timer, the water temperature switch cold and hot water settings are working ok.
If the GE Hotpoint washer is not filling, the problem should be on the water valve, the screen filters or the water supply
If one of the solenoids is bad you will need to replace the complete water mixing valve assembly YOU SHOULD ALSO GET AN OHMS READING OR SHOW CONTINUITY WHEN TESTED UNPLUGGED ON BOTH SELINOIDS HOT AND COLD
Mar 29, 2015 | Washing Machines
Tip
How to avoid electrical fatal shocks?
Always keep in mind that if electricity is passed through our brain or upper portion of body where hearts & lungs are affected the electrical shock is likely to be fatal. To avoid electrical shocks and fatal shocks pl do following: 1. Don't touch electrical device or leaky cable with wet hands
2. Before doing any electrical job (even ironing) use clear hill chappal/shoe or stand on any insulator like rubber mat etc. 3. Always presume that any metalic body or cabinet or exposed metal part of an electrical device may give you shock and keep you ready with preventive measure as told above. 4. Switch off device and remove power cable wherever possible before opening/trouble shooting of electrical gadget. 4. The most important: if anybody gets a shock don't touch him/her with your hands. Just use your leg to disconnect him from electrical system. Otherwise electricity will pass through your heart making you lethal shock. 5. As neutral of a power plant is put into earth, the supply line has a tendency to close the circuit to earth through a load (conductor). Don't give any chance to make that 'load' with your body. So never touch live wire or insulate your body to stpo flow of electricity to the ground/earth and remember not to allow passing of electricity through upper part of body. 6. Don't do any electrical job after taking bath. Wet body gets very low resistance and helps in passing high amount of current during contact with live wire. Higher current through body means more danger for life. These small tips will protect you & your family members from any lethal shock. Pl teach this others also. Gautam Kr. mandal, Electrical Engineer, Durgapur
on Jan 19, 2010 | Kitchen Appliances - Others
Whirlpool awe 2217
Sound like your earth ground isn't hooked up.
Sep 01, 2014 | Washing Machines
Eziset 950 wont spin and gives slight electric shock
Possible that the motor has failed and it has developed a leak to the body which seems to be felt over the machine, Isolate the motor and test the external voltage presence.. if absent it can be related to the motor.
Jan 12, 2013 | Simpson Washing Machines
I have a bodyguard t260 treadmill and when I run on it there is a great deal of static electricity that shocks me when I touch the treadmill handles
The shock is a build up of static electricity on your body called Electrostatic Discharge (ESD). Friction between the walking board and belt can generate static electricity.
If experienced, the shock is not harmful or dangerous.
Nov 11, 2011 | Exercise & Fitness
Hi Sir, This is dominic from visakhapatnam. The problem with my whirlpool machine is when I am touching the body of the washing machine while washing the clothes, I am getting current shock. Can you...
Your house elctric current is not grounded correctly.
You can attach a solid copper wire from the washing machine to a cold water inlet pipe to ground the machine.
Have an electrician check your power grounds at the circuit panel.
Sep 14, 2010 | Whirlpool Washing Machines
When I turn on the machine to wash then proceed to set the washing program and happen to touch any part of the machine it shocks me.
There is a leakage of current in the machine. Do the following Check the wiring. See there are no cuts or the wire is exposed due to wear and tear of rubber/plastic/cloth insulation. Ensure the exposed ends are not touching the body of the machine. Insulate all the open wiring ends. Check that the earthing wire is OK.
Feb 09, 2010 | Whirlpool LSQ9610L Top Load Washer
LOUD NOICE AND JUMPING
IT seems that the wash drum is hitting on the exterior body possibly the shock absorbers have flattened out. Also the balancing liquid in the top inner portion of the wash drum has leaked out u will have to check the two
Oct 08, 2009 | Washing Machines
Getting electric shock from water in washing machine and laundry
Yes, because there may be a problem with your incoming electric service. Call your power company to check out their equipment, if their equipment is ok, then call a reputable electrician, because the problem may involve your equipment
Aug 09, 2009 | Whirlpool Washing Machines
The body of wacsing machine has electric
It is either static electricity, or someone has wired the plug head wrong
In either case get a qualified person to look at it pronto
Jul 13, 2009 | AEG Washing Machines
Whirlpool Inglis IP4400 Washer Logo
113 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
