After approximately 20 minutes of use, colored squiggly lines appear horizontally across the screen and the computer freezes. I have to disconnect and remove battery in order to reboot. (HP Pavilion dv6000 laptop) Thank you.
    President:
  • 1,851 Answers
You have to check 2 options:
1.Try to clean up any air inlets - outlets using a brush. In case it's available use air under pressure to throw away the dust from the ventilation grids, but after this leave the laptop to calm for some minutes. Avoid closing the ventilation grids with any objects (especialy blunkets etc when in bed)
2.Update the VGA drivers. Right click on my computer - click on properties - choose the hardware tab - click on device manager - click on the + before the VGA adapter line - right click on the devise that will expand - click on update device driver - choose auto intallation - click on next - in case of an question about the source choose internet update.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Sep 14, 2010
Horizontal lines across tv
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 12, 2014 | Sony Televison & Video
Horizontal lines shadowed / blured picture after 20-30 minutes
There are some semiconductors or capacitors that are leaky. Might need thorough check up inside the TV.
Jul 07, 2012 | LG 55LH40 55 in. LCD HDTV
I have a KDL 46XBR5 which displays horizontal lines across the screen for approximately 5 minutes after turning on the TV. Is there a fix for this problem?
The reddish blotchy screen also had a series of horizontal lines/sections of screen on occasion. I was able to determine that the ground wire screws were loose (loosened and retightend all of them) and a few of the connections between boards (the wires/plugs) were loose. Seems to have resolved the issue without having to replace any boards/caps etc. I would try this free 20 minute fix before searching out a new board.
Jul 28, 2010 | Sony KDL-46XBR5 46 in. LCD HDTV
Small Rectangles or squiggly lines on screen
bad RAM on graphics card. replaces graphics card
May 14, 2010 | BenQ G2110W 21" Monitor
Horizontal lines across whole screen
Bad inverter, or a dirty one. Remove the power cable and battery, then take apart the screen bezel, or casing. Remove the LCD by unhooking it. Disconnect the inverter. Clean it. Reconnect it. Fixed.
Feb 01, 2010 | ASUS Eee 1000H Notebook
Horizontal black lines across the screen
you can try contacting Lumaco they are a British monitor repair specialist.
www.lumaco.co.uk
It might even be cheaper to buy a new one.
Jun 19, 2009 | Relisys TL 766 Monitor
57" Toshiba with wavy green/red lines "good overall picture"
Appears to be a convergence problem, the chips are located on large aluminum heat sinks. Check near the 2 or 3, STK IC's for + and - voltage usually 20 to 25vdc. If 1 or both are missing, check microfuses. They should both be close to equal in voltage reading, if not, turn set off after it has been on for 10 minutes, feel the heat sinks at each IC,if one is hotter than the other, replace both IC's or all 3 if it has them. Now check the small low ohmage resisters in and around the STK IC's and you will most likely find a few burnt or discolored and have changed in value, replace these or the new chips installed will self destruct.
Jun 26, 2007 | Toshiba 57H81 57" Rear Projection...
Computers & Internet Logo
123 people viewed this question
David Payne
David Payne
