Question about Maytag Neptune MCE8000AY Electric Dryer
A load of wet towels was left in the dryer for several days resulting in a strong mildew smell in the dryer. Nothing easy seems to be getting the smell out. Have tried washing with sloutions, baking soda, etc. Is there some part of the dryer that can be replaced that maybe holding the mildew? I noticed their is a fan or vent of some sort on the back, or some other removable part that could be replaced or be holding the mildew? Martha Rasmus
  • 262 Answers
There is a spray called NOK OUT. It is available in most pet stores or you can check it out online at www.nokout.ca . This stuff is amazing and safe!! The trapped lint in the dryer vent can hold the odors also. You can try to clean out the excess lint from the vent assembly. Remove the hose from the rear of the dryer(unplug first) and any panel that will gain access to the vent assembly. I hope that this helps...Besides its free advice.
Posted on Sep 15, 2010
I suddenly have the smell of urine in my dryer. Nothing was washed with any urine residue. I always double rinse each load and often use a little bleach with my "white" laundry. A couple of...
The only thing that I can think of that could produce a urine/ammonia smell is a shorted capacitor that is leaking. But normally when that happens the dryer motor will not start.
Jun 17, 2011 | Dryers
Every since I had my washer it has periodically left orange coloured stains on my laundry. I recently washed brand new towels that left huge stains all over the towels and ruined them. What is causing...
I'm guessing it's a mildew smell, if it is try setting the machine with nothing in it and use some Affresh once a month, you never know it might solve the other problem too.
http://www.affresh.com/content.jsp?pageName=preventing_odor
If you have anymore questions please feel free to ask, Rich.
Jan 20, 2011 | Kenmore Front Load Washer
How do you get the mildew smell out of a clothes dryer?
Very unusual problem with a dryer as it gets hot and would normally evaporate moisture causing mildew!
Try the following:
  • Unplug the power point of the dryer.
  • Gently clean the interior (and exterior) with a super absorbent cloth/non-scracth sponge lighty soaked in a mild bleach soapy mixture to kill off and remove the (blackish) mildew (Nappy wash is not a bad mixture). Weat rubber gloves for protection.
  • Let the unit wet for a few minutes and then using clean warm water and sponge, remove all trace of the bleachy soap on the unit as it is corrosive. Additional drying off with disposable paper towel will help remove any trace of bleach.
  • Put a wet clean bathroom towel lightly soaking with material conditioner mixture at double the normal recommended ratio, power the dryer and dry off the towel as per normal: the fabric conditioner is also a freshner.
  • Musty milldew odour should be gone!
Hope it helps! Please let me know how you go!
Aug 05, 2010 | Hotpoint Dryers
Strong mildew smell in washer is making cloths & towels smell bad, how do you get rid of the problem?
if you look inside washer there is a rubber rim on the inside around the openning. Look inside and you will find where the stink is coming from. Keep door open when not in use and wipe inside of rubber trim to keep the mildew out.
I use tilex sometimes and do a rinse spin.
Nov 16, 2009 | Kenmore Elite 45986 Front Load Washer
Towels smell oily and moldy--really stink
Don't use fabric softener. I had the same problem and read somewhere to stop using the fabric softeners. I don't know why but after about two cycles (they smelled really bad) it worked! I always used fabric softeners with out a problem but one day I just started getting REALLY smelly towels. I always take my wet wash out as soon as the cycle ends and dry it completely so I was surprised when they smalled so bad. Give it a try.
Jan 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Mildew smell on cloths
The brand of your front loader is not that material on this issue. What is happening is that your old top load washer may have used as much as 45 gallons of water per cycle, while some front loaders use as little as 12. Because of the low water use, you must cut back on the additives you are using. Use only 1 tablespoon of HE detergent (even less if 2x or 3x detergent) per load. If you use fabric softener, use only 1 teaspoon per load. Odor on clothes after wash is indicating that the detergent and or softener has not been fully rinsed out. If you throw a load of washed towels into your machine and start a cycle without any soap, then stop the cycle, you should not see any suds. If you do, there is obviously soap left in the clothes. With bath towels, the towels are used to absorb clean water off a clean body. They do not need soap when you wash them, and never use fabric softener on towels.
If your washer is a LG WM-1832 it has a assessable filter behind the access door on the lower left front of the machine. Clean that out first, and if it has a tub clean or sanitary cycle use that cycle (if not, use hottest longest cycle available) with 3 Affresh tablets or use whirlaway to clean out the washer outer tub (the not visible tub that holds the water). You might want to use another cycle like that with bleach to head off mold or mildew growth. Use of proper amount of detergent and fabric softener should really help the clothes odor issue from then on. Also check the tub seal at the bottom of the door area to clean out any lint from drain hole areas to help prevent water from remaining in the tub seal area.
Oct 28, 2008 | LG WM-1832C Front Load Washer
Clothes/towels smell like mildew
Front load washers are so tight ( to seal in water ) that they tend to leave water in door gaskets and other places.. This water gets stagnant and can build up mildew etc..Home depot and other home goods stores sells a product called AFRESH and you use it about once a month ( with no clothes in washer).. It does help a bit..
Other techniques you can try would be to wipe down the gasket around the door opening after a wash is complete and to leave the door open between washes to let it air dry.. You should be using HE type laundry detergent and very little of it ( sveral drops is enough per load)..
hope that helps you...
Aug 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Mildew smell in towels
are you using liquid detergent? if so, change to powder. liquid detergent used for a long period causes a smell.
try putting on the hottest wash with no clothes in to get rid of the smell
Aug 05, 2008 | LG WM-1485FHD Front Load Washer
Mildew smelling towels and no separate rinse cycle
the problem is your door seal if you close the door after a wash then what happens is the water goes mouldy on the inside of the door seal what you need to do is replace the door seal you will never get rid of the smell without replacing it never close the door after a wash always leave it open to make sure its your seal the easy way is to look at the inner part of the seal and it will be mouldy only thing you can do
Oct 30, 2007 | Bosch Classixx WFC 2465 Front Load Washer
Bad smell
washers and dryers dont make smells themselves its a problem with something u might be putting in it. if u tend to add alot more detergent then usual to your towels then they never completely rinse the water out and will have a mildew smell
Feb 18, 2007 | Whirlpool GEW9250P Electric Dryer
Maytag Neptune MCE8000AY Electric Dryer Logo
85 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
