Question about Toshiba Satellite A135-S4427 Notebook
Computer power My computer battery is not being charged and the computer (laptop Satellite A135-S4427) will start then turn off even with the AC power cord pluged in. Note: I have two A135-S4427 comupeters and I have tried changing the AC power cord to see if it would work, it dosent. I can however place a fully charged battery from the second computer into the first computer and it works untill the batt goes dead. So, what do you think, thanks Milo..........
  • Anonymous Nov 05, 2008
    Have had a lot of problems with my Toshiba laptop, will definitively never buy toshiba again.
  • 472 Answers
The power connector on the motherboard is not making contact.
This is not a simple procedure to correct due to the laptop needing to be completely disassembled to get access to the motherboard.
If you gently move the power cord around in a circle while pushing towards the laptop it should get power to it until it moves out of place again. Do this while watching the lights panel for any signs of light. Also remember it will take a second or so for the battery charge light to show power entering the laptop, so move the cord very slowly.
The suggested soloution will invole the laptop being sent to your local laptop repair centre for this to be corrected, or if you still have warranty, then get it done by Toshiba.
It is also a common fault to all laptops.. There is just not enough strength in the solder that holds the power connector in place to take years of connecting/disconnecting of the cable.
Posted on May 15, 2008
I HAVE A TOSHIBA SATALITE A135-S4427 TURNED IT OFF ONE NIGHT WORKING FINE, THE NEXT DAY IT WONT TURN ON. I HAVE POWER THRU THE CORD AT ABOUT 18+ VOLTS BUT NO INDICATOR LIGHTS OR POWER TO COMPUTER. HELP?
Try removing the battery and power supply, hold the power button for about 10 seconds then just plug the power supply back in (not the battery) and see if it turns on.
Holding the power button with no power supply can discharge any stored power in capacitors.
Oct 24, 2013 | Toshiba Satellite A135-S4427 Notebook
Please, I need instructions on how to replace the screen for my Toshiba Satellite A135-S4427. Thank you.
do a search about "screen replacement" or "laptop repair" in youtube. I've seen many videos about computer repair in there
Mar 18, 2010 | Toshiba Satellite A135-S4427 Notebook
I have no drivers for Satellite A135-S4427,
Here's the link to download drivers for Satellite A135-S4427.
www.yboyandrei.com/A135
Aug 23, 2009 | Computers & Internet
Satellite A135-S4427 PC Notebook wont start at all
it might be because your laptop is not able to complete post (power on self test), moreover have you tried holding the power button down for 15 sec without the battery and ac adapter and then trying to start
to troubleshoot further you should contact a local technician
Further Queries are welcome
Feb 20, 2009 | Toshiba Satellite A135-S4427 Notebook
Toshiba A135-S4427 no start-up
Ok my friend the only additional test that you can do, is the memories remove ram that are in the small cover in the central part for the side of below and to return to place them, if nonetheless not turn on, the damage is the system board, good luck
Jan 12, 2009 | Toshiba Satellite A135-S4427 Notebook
Satellite A135-S4427 won't start
when you connect the AC charger with the battery , your laptop power on ?
and try to directly connect the ac charger with laptop without the battery, if it is on, that means the battery go bad, you need replace
Dec 27, 2008 | Toshiba Satellite A135-S4427 Notebook
Won't Power Up - A135-S4427
power surge only affects the ac adapter... replacing it might do the trick... and/or have it repaired by a certified electronics technician...
Aug 27, 2008 | Toshiba Satellite A135 Notebook
Starting up problem
I had the same thing. I was passed down this laptop to checkout for a friend. After overviewing the system turns out the processer board got loose. Pushed it back in and she fired up..
Issue was green power led then 2 short orange flashes that repeated untill I discoved the issue.
Feb 22, 2008 | Toshiba Satellite A135-S4427 Notebook
Toshiba Satellite A135-S4427 Notebook Logo
109 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
