Question about Dell A215 Computer Speakers
Necesito los drivers para mis speakers a215, son mis bocinas pero las quiero instalar en otra computadora que no las reconoce......estan encendidas pero en la computadora no estan reconocidas aparece como si no hubiera ninguna conectada.... Que puedo hacer? gracias...
SOURCE: Necesito realizar el test de una Laptop Inspiron 8600
My spanish is very poco, but I think you want to start a diagnostics test, and need the combination of keys to start?? That would be the Fn + the Power key. Turn the computer off. Press and HOLD the Fn key, then press and RELEASE the power key. Keep the Fn key down until the screen says that you are starting in the "diagnostics" mode. You will then see prompts to ask if you want to conduct a full diagnostics test or a custom one. If you just want to check one or more parts of the system, choose the custom and select what you want to test. Otherwise a full test will cover all system hardware and will take about an hour.
Posted on Jan 06, 2009
  • 5 Answers
SOURCE: driver for A215 speaker
try this sofware called Driver Detective Software.
It should help because you will have your computer scaned for the speakers and it will detect the
http://www.quickpcsolutions.org/Drivers/audio-sound-drivers.html?gclid=CNyt99Gl7pkCFQ_yDAodjggpRg
this will help you find the speakers
here are some pics before u download
Posted on Apr 13, 2009
  • 10 Answers
Here's a link to all of Dell's audio drivers. If you're not sure which one to choose, go to the search bar and enter the model number of your computer.
http://search.dell.com/results.aspx?s=ge...
Hope this helps.
Posted on May 28, 2009
  • 5 Answers
SOURCE: Dell A215 stereo speaker ---drivers needed-----
you need to download the sound card driver for your computer, dell.com should have the drivers for you under support....make sure you have the model number of you computer, so that you can get the correct driver.....hope this helps.
Posted on May 30, 2009
  • 3940 Answers
SOURCE: recuperacion de sistema
COMIENCE, FUNCIONE, MSCONFIG, LENGüETA de Boot.ini Las 2 trayectorias del cargador se deben enumerar allí, y la que doesn' el trabajo de t se enumera como DEFECTO. Destaque la trayectoria funcional del cargador, chasque el SISTEMA COMO botón de DEFECTO, entonces AUTORIZACIóN
in English:
START, RUN, MSCONFIG, Boot.ini TAB The 2 boot paths should be listed there, and the one that doesn't work is listed as DEFAULT. Highlight the functional boot path, Click the SET AS DEFAULT Button, then OK
Posted on Jun 30, 2009
Necesito el diagrama para instalar el microfono dm-452 en un radio comanche black hawk
no spanish only English please. If I understood it I wouldn't mind.I can make out some of what you are looking for but thats it.
Mar 20, 2014 | Magnum Radio Communications
Tengo un 98 pontiac sunfire nadie le a encontrado el problema lo e yevado con 4 mecanicos y no le encuentran el problema es ke en los cables delas bujias aveses esta a ventando corriente y aveses no...
lo que tienes que cambiar es las bujias y los cables otra ves y asegurarte que esten bien apretadas las bujias y los cables oh otra cosa puede ser que tenga una fuga de gas en los cilindro pero asegurate que las bujias sean compatibles para esa marca
Apr 16, 2011 | 1997 Pontiac Sunfire
No enciende las vocinas para mi computadora son logitech x-530 quiero verificar como puedo cambiar los fusibles o verificar cualquier cosa que sea para cambiar pero como destapo los subwoofer para...
Primero trata con otra fuente de energia electrica otro tomacorriente u otro sitio a ver si no es el sistema de cornetas, para abrir el sub buffer solo encesitas destornilladores y verificar dentro el estaod de los componentes si tienes voltimetro mejor, cuidado con hacer cortos. pero no hay uan guia basica para eso, solo saber lo que haces.
Mar 14, 2011 | Logitech X-530 Computer Speakers
Yo tengo el model 0224879 pero solo tiene el timer y dos botones outlet y timer con on pero no lo puedo programar y no lo quiero devolver porque me hace falta.tiene las instrucciones atras pero lo prendes...
┬┐Es este el temporizador
http://www.lowes.com/pd_224879-95363-TM09DHBL2_0__?productId=3278549&Ntt=timer&pl=1¤tURL=%2Fpl__0__s%3FNtt%3Dtimer%26page%3D3
Estoy usando traductor Google.
http://translate.google.com/#auto'es'I%20am%20using%20google%20translate
Hay segmentos situados alrededor del borde de la dial.
Hay dos segmentos para cada hora del d?a.
Segmentos Tire hacia arriba para ajustar el temporizador.
Cuando los segmentos son abajo, y no hay electricidad va a la l?mpara, y la l?mpara est? apagada.
Cuando los segmentos se han reducido, a continuaci?n, el temporizador se activa, y la electricidad va a la l?mpara est? encendida.
Para ajustar la hora actual, gire el dial hasta que las l?neas actuales del temporizador con tri?ngulo de punta de flecha situada en la parte interior de el dial.
Timer interruptor que se encuentra por encima de marcar.
Para temporizador para operar, mueva el interruptor de TIMER ON
Enchufe la l?mpara en el temporizador.
Enchufe el temporizador en el tomacorriente el?ctrico.
Asegure que la l?mpara est? encendida.
Dec 14, 2010 | Hardware & Accessories
MI PC TIENE BOCINAS PERO DICE QUE NO LAS TIENE Y NO SE ESCUCHA.
Hola si tienes donde poner los cables de las bocinas detras de la computadora y todadia no trabaja entonces tienes que abrirr el control manager y prender las bocinas por dentro el control de volume va a estar en el keyboard la tabla de teclas . buena suerte
Sep 21, 2009 | E-Machines eMachines Desktop PC
Hola , necesito saber si puedo cambiar toda la maquina, excepto el DD y dejar este mismo como master, tengo programas que me costaria mucho conseguir e instalar de nuevo gracias
Muchas Gracias COnstantin, quizas me expresé mal, mira mi problema es que el pc, excepto el disco nos quedó chico, es decir, quiero cambiarlo por una maquina mas nueva core duo por ej, por ende con distinta placa, y el DD tiene toda la informacion y programass con licencia que necesito, entonces necesariamente tiene que quedar como master, me indicaba un tecnico que los driver de la placa podriasn darme problemas, si es así y tengo los drives de la maquina nueva ( placa) no debiera tener problemas?
agradeceré tu respuesta
gracias
Jun 23, 2009 | MSI PM8PM-V Motherboard
No puedo instalar mi x1270 en el vista
Yo no hablo mucho de espanol, pero aqui estan links para instalar printer en english, y posible con un translator tu puede instalar su printer.
para Vista ver aqui , y ver "To Add a local printer"
para su download de Lexmark aqui y entrar su x1270 nombre
Yo quiero este es un poquito de ayuda para ustedes.
Lo siento por mi pobre espanol...
Apr 07, 2009 | Lexmark X1270 All-In-One InkJet Printer
Yo ya intale la caja wireless-N Broadband router en my computadora Windows xP travaja vien pero a hora yo quiero intalar el internet a mi otra computadora Windows Vista co un wireless USB. mi pregunta...
Es un computador de casa o un laptop? Si es de casa entonces deves de instalar el USB Adapter en la connecion mas alta para poder agarar el signal mas potente. No importa si es adelante o atras
Antes de instalar el USB adapter devs de instalar los Drivers del USB adapter antes.
Dec 01, 2008 | Computers & Internet
Necesito configuracion de m955g v3.0a
Intente distinguir que tiene el problema. Si más de un dispositivo del usb no funciona, necesitamos localizar averías los puertos del usb. Si usted tiene apenas un dispositivo del usb para probarlo con, usted puede querer intentarlo en otra computadora. Dónde usted está conectando los audiophones?
Nov 04, 2008 | PC Chips M955G Motherboard
Problemas con la camara web
Hola soy nuevo en esto de los foros, tengo problemas con mi camara web 1,3m que viene integrada a mi Toshiba Satellite A215-S4807, tengo Windows Vista Home Premium, entonces mi camara web casi nunca logra funcionar con el msn e incluso el programa que trae ("C:\Program Files\Camera Assistant Software for Toshiba\traybar.exe.exe") no funciona correctamente ya que a veces funciona y otras no... ahora ultimo no ha querido funcionar mas con el msn.
Quedo de ustedes y esperando sepan ayudarme.
Gracias de antemano. Carlos
Jan 25, 2008 | Computers & Internet
Dell A215 Computer Speakers Logo
216 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
