Question about Nintendo DS Lite Console
Clock adjustments How do i change my time appearance from military time to standard time?
  • 5 more comments
  • Anonymous Jun 25, 2008
    how do i change the time on ds from military to regular time
  • Anonymous Dec 27, 2008
    is there a way to change the clock from military to standard ??
  • Anonymous Dec 28, 2008
    i dont know how to change from military
  • kylesticked Jan 10, 2009
    Military time is annoying for a yr old, can it be changed
  • Anonymous Jan 26, 2009
    i have the same problem too with my reglar ds not ds lite
  • Anonymous Jan 27, 2009
    i cant change it it would so much easier if it were standerd time please help
  • Anonymous Mar 24, 2009
    the time on my ds always goes past 12 and not to 1
Go on options and click clock
Posted on May 16, 2008
How do you change the time from military to standard on a digital scoreboard clock?
can not say as do not know what make or type watch you have .
Oct 06, 2017 | The Watches
How to set time
Plug in the unit.
First, the month and date appear, then the
year, and then the current Eastern Standard/
Daylight Time appears in the display.
Press
TIME ZONE
Area number "2" appears in the display.
If you live in the Eastern Time zone, you do
not need to adjust the area setting.
Area number
Time zone
Atlantic Standard/
Daylight Time
(default)
Eastern Standard/
Daylight Time
Central Standard/
Daylight Time
Mountain Standard/
Daylight Time
5
Pacific Standard/Daylight
Time
6
Yukon Standard/Daylight
Time
7
Hawaiian Standard/
Daylight Time
Press
TIME ZONE
repeatedly until the
desired number appears.
The display returns to the clock about 4
seconds after the operation is complete.
Note
During the shipment and your first use, a clock
error may occur. In this case, refer to "Setting the
clock and date" to set the correct time.
When daylight saving time
(summer time) begins
This unit employs Automatic Daylight Saving
Time/Summer Time adjustment. The DST
indicator appears in the display at the beginning
of the daylight saving time (summer time), and
disappears at the end of it.
Daylight saving time begins at: 2:00 AM on the
second Sunday of March.
Standard time begins at: 2:00 AM on the first
Sunday of November.
To cancel the automatic DST/summer
time adjustment and to set DST display
manually
The automatic DST/summer time adjustment can
be cancelled.
Press and hold
DST
for at least 3 seconds while
the clock is displayed.
A beep sounds, and "Aut
OFF" appears in the
display to show that the automatic DST/summer
time adjustment is cancelled. The display returns
to the clock.
Notes
Daylight Saving Time depends on the law in
each country/region, and your area may not use
it. In such a case, cancel the automatic DST/
summer time adjustment before using the set
and set the time manually as necessary.
To activate the automatic DST/summer time
adjustment again, press and hold
DST
for at
least 3 seconds. A beep sounds, and "Aut
On" appears in the display to show that the
automatic DST/summer time adjustment is
activated. The display returns to the clock.
To change the display to the daylight saving
time (summer time) manually, see "To change
the display to the daylight saving time (summer
time) indication."
Setting the clock and
date
To change the setting manually, follow the
procedure from step
Press
CLOCK
for at least 2 seconds.
You will hear a beep and the year will start to
flash in the display.
Press
or
until the correct year
Press
CLOCK
Repeat steps
and
to set the month,
day and time.
After setting the time, two short beeps sound
and the clock starts from 0 seconds.
Pressing and holding
or
changes the year,
month or day rapidly.
When setting the current time, time changes
rapidly by 1 minute-increments up to 10
minutes, and then by 10 minute-increments.
While setting the clock, you must perform each
step within 65 seconds, or the clock setting
mode will be cancelled.
To display the year and date
Press
SNOOZE/DATE/SLEEP OFF
once for the
date, and within about 3 seconds press it again for
the year.
The display shows the date or year for about 3
seconds and then changes back to the current
time.
If you connect the AC plug to an AC outlet while
this unit is powered from the backup power
source, the current date and time appears in the
following order (the same as when the unit is
powered on after a power interruption).
"month and date" (about 1 second)
"year"
(about 1 second)
"current time"
saving time (summer time) indication
Change the daylight saving time (summer time)
adjustment setting according to the following
procedures if you have cancelled the automatic
DST/summer time adjustment.
Press
DST
The DST indicator appears in the display and the
time indication changes to the daylight saving
time (summer time).
To deactivate the daylight saving time (summer
time) adjustment, press
DST
again.
May 24, 2015 | Sony SY-ICF-C414 Clock Radio
Military time
go to menu and change to 12 hr on clock
Mar 23, 2014 | Sceptre "32"" Class 720p 60 Hz Lcd Hdtv...
I need to know how to set the clock. i bought a car with a jvc kd 300 stereo in the car. love the unit but i don't know how to set the clock. thank you
Press and hold SEL (select) for more than 2 seconds so that one of the PSM items appears on the display.
Press number 2 button to to select Clock (clock should be above the #2.
The Clock HR (Hour) setting will appear.
Adjust the hour using the round left side control.
Use the up/down arrows (right side) to toggle to Minutes and use the dial to set minutes.
Use the up/down arrows to toggle to 24/12 and choose between military time or standard
with the left dial.
Press SEL to save changes.
Here is what appears to be your manual. See page 9 for clock. Save the manual to
your computer for future reference if it is correct.
JVC KD-LH300 Manual
Apr 04, 2011 | Car Audio & Video
Can I change the clock in my 99 Beetle to standard time and not military time?
Yes. I believe you have to have the engine shut off. but with the power on hold the hour button until the time changes. you can change the temperature the same way but with the car running. in standard time 0 o- clock means midnight.
Nov 24, 2009 | 1999 Volkswagen Beetle
Getting the clock off military time
This is controlled by hardwired switch (12/24) OR digitally during menu setup sequence.
Sep 17, 2017 | Audio Players & Recorders
With the sytem off, hold down the Alarm Setup button and the On/Off button to switch between 12 hour (AM/PM) and 24 hour (Military) time. If you need the manual go to
http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/customer_service/owners/guides/music_system.jsp
Nov 28, 2007 | Bose Wave Radio
Changing time from military to standard
According to the manual, you have to flip the switch on the back of the main unit, unplug and replug it into the outlet.
Apr 24, 2007 | Nakamichi Soundspace 3 Shelf System
Nintendo DS Lite Console Logo
623 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
