Question about Diesel DZ1127 Watch for Men
The crown asnpped on the inseide so i have no way of using it now. i need help
    President:
  • 2,501 Answers
It needs attention by the maker. Go to their web site "diesel.com" and find their nearest store and contact them about it.
Posted on Sep 15, 2010
Is there an online instruction manual for Kenneth Cole Model KS3025?
i don't know about on line instruction.
but i could help you ....
there is two position for crown 1 and 2.
bring crown on position 2 and turn crown clockwise to change TIME, DAY & DATE.
bring crown position 1, and turn crown counterclockwise to change DATE.
your watch has Chronograph / Stop watch.
use that please press right TOP button chronograph will START, press again Chronograph will STOP.
Press bottom button to RESET Chronograph.
hope it will help 9k=
Jun 06, 2014 | Kenneth Cole Watches
My crown fell off the stem of my Gucci watch. How
If you still have the crown you may be able to put it back on yourself. However for a secure repair you would need a watchmaker to repair this.
To try yourself get some RED locktite (available at any Ace hardware store or automotive store) Put a small amount on the threads of the crown. Then screw the crown onto the stem as much as possible.
Let it sit for about 10 minutes so the locktite can cure. Then you can try using it to set the time or whatever.
If this does not work you will need a watchmaker to repair this.
Prices to fix this would vary.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Nov 01, 2009 | Gucci G Watch ladies' YA100510
Setting time and date on my Cartier Pasha watch.
Do not be so afraid. Unscrew that big crown fully, pull off and then you will see the real setting crown(quite small one), called an underlayed crown.
That little chain is hard enough to withstand your pulls, unless you are drunk. :)))
When you get that small crown handy- you can set the time and all the features.
If the small crown is not moving, your watch is rusty and you will need a proper watchmakers help.
Don't forget to rate, please.
Jan 11, 2009 | Cartier Pasha 32MM WJ111156 Wrist Watch
How to set the time on a tag heuer
Probably your watch has a screwdown crown and prior to attempt any settings you have to unscrew it. Some peoples fingers are stronger then others, so, try that with a pair of plyers. Cover your crown with a soft cloth and then grip with plyers(this will avoid any damage). Thread is right handed and unscrewing is done by turning the crown anticlockwise.
After setting the time don't forget to screw the crown back- it is for water resistance.
If you are unable to unscrew the crown, that means your watch is rusty and you will need watchmakers help.
PS If the watch is rusty, you can brake the crown off while trying to unscrew it. Don't panic yet, as in this case you will need a watchmaker anyway.
Jan 10, 2009 | Watches
I can't seem to set the time on my used tag heuer watch
Jan 10, 2009 | Tag Heuer Watches
Help setting the time
Tags have a screw down crown (winder knob) turn the knob counter clock-wise until you feel the crown unscrew (not off) then pull the crown carfully. It will pop once this is for date adjust. Then pull once more and you can now adjust the hands, set accordingly then push crown back in. After you push it back in gently compress the crown and tighten clockwise until it stops. CAUTION!!!!!!! Tags are not waterproof if the crown is not screwed back down. I hope this helps I am actually a car guy (just happen to own a couple)
Nov 06, 2008 | Tag Heuer WAF2110.BA0806 Aquaracer...
Rolex watch
if your watc is automatic or self winding,you need to use your watch at least 12hours a day,to set the time , wind the crown counter clock wise,until the crown lose then full the crown to set the time,after setting the time fush the crown then wind it clockwise to lock again! thank you !
Aug 26, 2008 | Bulova Watch
Setting time and date crown positions
Yes, you must unscrew the crown before you wind up or set the watch. Always screw the crown down afterwards this keeps the watch in a water resistant condition.
May 19, 2007 | Rolex Day-Date President 118238 Wristwatch
How to Set Alarm
This is the movement used in the following Seiko watches..
SNAC74 SNAC75 SNA548 SNA694 SNAC40
SNAC41 SNAC42 SNA749 SNAC03 SNA411
SNA414 SNA765 SNAA03 SNAA05 SNAA01
SNAA02 SNAA61 SNAB61 SNAB62 SNAB64
SNAB65 SNAC25 SNAC29 SNAC35 SNAC36
SNAA61 SNAC38 SNA283 SNA695 SNAA30
HOW TO SET ALARM TIME
1. Pull the crown out to the second click position.
2. Press button “B” to set the alarm hour and minute hands to
current time.
3. Push the crown back to normal position.
4. Pull the crown to the first click position.
5. Press button “B” to set the alarm hour and minute hands to
desired alarm time.
6. Push the crown back to normal position.
Note:
Alarm setting on a 12-hour basis only. Alarm will ring at the
designated time for 20 seconds; one time alarm only. The alarm
needs to be reset in order to re-engage the alarm function.
HOW TO USE CHRONOGRAPH
1. Set crown at normal position.
2. Press button “A” to Start/Stop/Restart.
3. Press button “B” to Split/Split release/Reset.
HOW TO USE ALARM DIAL
AS DUAL TIME DISPLAY
2. Pres the button “B” to set the hour and minute hands to time of
a different time zone.
Nov 27, 2006 | Seiko Coutura SNA341 Wrist Watch
Diesel  DZ1127 Watch for Men Logo
29 people viewed this question
Top Diesel Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Diesel Watch Expert? Answer questions, earn points and help others
