Question about Whirlpool Washing Machines
Hi Sir, This is dominic from visakhapatnam. The problem with my whirlpool machine is when I am touching the body of the washing machine while washing the clothes, I am getting current shock. Can you tell me the cause of this issue. It will be very helpful for me. yours faithfully Dominic
  • Whirlpool Master
  • 3,361 Answers
Your house elctric current is not grounded correctly.
You can attach a solid copper wire from the washing machine to a cold water inlet pipe to ground the machine.
Have an electrician check your power grounds at the circuit panel.
Posted on Sep 14, 2010
Can't spin. Makes ratcheting noise as it attempts to start spin, can't start spin even w/o load.
What to do when Samsung Washing Machine does not spin ?
www.samsung.com/ae/support/skp/faq/1033383
Samsung Electronics'Washing machine not spinning' is one of the major problems faced by people nowadays with ... If so, the washing machine can't spin and may not function at all.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - Washing Machine Service Repair Manuals Online Your washing machine is not working properly. It does not spin, won't drain, can't turn on, ...
How to Fix Washer That Won't Spin ' Washing Machine Repair
Nov 28, 2015 | Washing Machines
My whirlpool top loader extra large washing macine
Many late model washing machines use a direct-drive system to agitate and spin. They don't use belts or pressure wheels to transfer power and motion from the motor to the transmission. The motor is coupled directly to the transmission. If the motor is running and there is no agitation or spinning of the tub, the culprit is usually a plastic coupling between the motor and transmission or the transmission itself.
Aug 07, 2008 | Washing Machines
Can't open pump
Dear Sir :
See the diagrams and proceed accordign with common sense.
God bless you
May 13, 2012 | Whirlpool AWM8143 Front Load Washer
Dear Sir, Drier door Lid Switch (Whirlpool 6.2 kg Super soak model)pin broken, need replacement. Kindly inform whether is it available with Visakhapatnam distributor if not pls intimate the nearest...
Sorry. I doubt anyone on this forum could give you that information. It's just made up of ordinary guys and gals, probably at home, from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will either have to search in telephone directories OR stay on line and search for the 'whirlpool washer service centre' or 'whirlpool washer spares' in you area and hope that you can find someone reasonably local.
Good luck,
John C
Mar 06, 2011 | Washing Machines
When I turn on the machine to wash then proceed to set the washing program and happen to touch any part of the machine it shocks me.
There is a leakage of current in the machine. Do the following Check the wiring. See there are no cuts or the wire is exposed due to wear and tear of rubber/plastic/cloth insulation. Ensure the exposed ends are not touching the body of the machine. Insulate all the open wiring ends. Check that the earthing wire is OK.
Feb 09, 2010 | Whirlpool LSQ9610L Top Load Washer
How to operate a whirlpool fl 5053 washing machine
Dear Sir,
How to operate fl5053-500 model whirlpool washing m/c (fully automatic),
pls forwad manual for mail id.
this is my mail id = rajan_raman@yahoo.com,
solution = a picture or video is helpful for as,
pls reply me on further information by mail.
thanks & regards ,
raman.
Nov 14, 2009 | Whirlpool Washing Machines
Where are the fuses to the water pump
Hi there......the water pump does not have a fuse...it is not controled by a fuse....it is controlled by the programmer....the whole machine is protected by a fuse in the plug top...water pumps or drain pumps usually suffer from a damaged impeller...or damaged coil windings...either of would require you to relace the pump
regards Sir Galahad
Aug 16, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
I cannot remove the basket from the tub.
i am a maintenance man at U OF I and need to change the tube seal on this washer but dont know how to remove the ajatator btoolmanA illicom.net
May 12, 2009 | Whirlpool LCR7244H Top Load Washer
Washing Machines Logo
29 people viewed this question
Dan Webster
Dan Webster
Sal De
