Question about LG KP260 Cell Phone
I am using LG KP265 handset.. When I connected it with my pc it got switch off and start again.. This problem is still continuing.. For fifteen days it worked properly, after that this problem arose.. Now too after 30 mins or less the phone is getting switched off when I connect it with the pc for internet purpose... This is occuring from nearly fifteen days.. I am unable to fix the problem.. Plz help..
Whole software
Posted on Nov 12, 2011
I cannot download pictures from my LG Neon gt365 to my computer. What do I need to do? Do I need a USB? Do I need a micro SD? If so, what kind do I need? any help would be great!
You should be able to connect it using a usb cable that will need to be bought separately and a micro SD card installed in the phone. You should be able to buy any micro SD card up to 4GB. Also, if you buy a card with an SD adapter that will allow you to connect the SD card (with a memory card reader) to your computer without the additional usb cable. The manual link is attached: http://www.tmoatt.com/uploads/53/LG_Neon_GT365_UG_English.pdf
Per the manual:
Transferring Music from the Digital Music Service 1. Using your computer, open your preferred PC music management client. 2. Download the selected song to your library. 3. Make sure the microSD™ card is inserted properly into the handset. 4. Use the USB adapter cable to connect the handset to the PC. When you try to connect handset on your PC, the handset displays "Call and Message functions will not be available while connected to USB". 5. Once the USB connection has been established, the handset displays "To avoid data corruption always carry out safe removal hardware on PC after use." and the computer screen then shows the LG NEON device. If the detection does not occur, skip to Changing USB Connection Settings section on page 63. 6. Follow the instruction in the program to transfer music to your handset. n Note If you have a USB hub, connect the handset directly to your computer rather than through the hub. Transferring Music using Windows Media Player 1. Open Windows Media® Player on your computer (version 10.0 or higher). 2. Use the USB adapter cable to connect the handset to the PC. When you try to connect handset on your PC, the handset displays "Call and Message functions will not be available while connected to USB". 3. Once the USB connection has been established, the handset displays "To avoid data corruption always carry out safe removal hardware on PC after use." and the computer screen then shows the LG NEON device.
Jul 23, 2011 | Cell Phones
Can not get the second handset to register to the base
This is the registration procedure
Step 1: press MENU-6 and select 3 “SET BASE”
Step 2: press the REG key on the master base
Step3: press register to finish the registration procedure.
• After the registration complete, handset 11 and handset 21 can
2-WAY intercom with each other
If issue persists reset the unit start registration by using 2nd unit that currently unable to register. if issue continues please inform for further troubleshooting
Good Luck
Jan 01, 2008 | EnGenius SN 920 Ultra Cordless Phone
I cant use my handset LG GX200 to connect internet through PC
download lg pc suite, install it to your PC then use the USB cable to connect to internet.
Download pc suite from here
Jun 02, 2011 | Cell Phones
Hi, I am using LG kp110 Handset, and I want to connect internte through pc, please suggest me is there any software is there or directly connecting data cable????? Thanks for your support in...
Hello thanks for using FixYa
By LG PC suit you can connect internet through pc.You can easily download LG PC suit free After open it the link where you have to click just see the image given below.
Downloading will start after clicking.Download it then extract the files & install it on your PC
After Downloading connect your cell with PC via data cable, PC suit detect your cell and by the given option in PC suit you can connect the internet.
Further help I am here to help. Best of luck
Thanks and Keep using Fixya
Mar 14, 2011 | LG CU500 Cellular Phone
My LG KG110 is not switching on asking for a security code what is it i tried all the no's i know bt its not working
You have to enter the default security code
Default will be 0000 or 1234 or 12345 or 00000(For default code check user manual of user handset).
If these won't works somebody changed security code.
To reset security code you need to flash your handset
To flash you need *USB cable compatible with your handset *A C omputer *PC suite of your handset *Internet connection(Min speed 1Mbps)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE**
**Please don't disconnect while updation process
Jan 17, 2011 | LG KG110 Cellular Phone
I followed the precise instructions for using lg kp265 as usb modem,in final step,click 2 create dail-up connection i get the error,modem alreddy in use or not configured propely?
disconnect all network connections,restart your system,try again to create dial up connection.moreover u will have to add your device to system to get the options for what you want to do then select dial up networking.
Jan 05, 2011 | Computers & Internet
I take a GPRS on Airtel internet continue in my
Dear customer
Your internet connection is activated only in handset u can brouwse and download only from your handset u can not connect ur internet with PC by ur handset. If you want to connect than u have to set PC internet cofiguration which will provide u from ur AIRTEL customer care executive.If u are satisfyd with my information then please vote me. Thank you have a nice day.
May 24, 2010 | Nokia 3110 Cellular Phone
Philips Dect 215 phone continually bleeping.
Remove all handset batteries and leave for 10 minutes.
Unplug main cradle and reconnect after 30 Seconds.
Replace all handset batteries and place handsets back on cradles.
Oct 06, 2009 | Philips Lands Phones
My lg kg 300 is dead not runing or not lifes again
Remove the battery immediately. Don't put back the battery again at all in your handset until and unless your handset get fully dried. Also do not try to Switch On your handset, as this will result in permanent damage of your handset's main board.
Take your handset to the Authorised LG Service Centre and they will do the needful. Don't try to open it yourself.
Apr 23, 2009 | LG KG300 Cellular Phone
Can't connect using LG PC SUITE
go back to the main menu of your phone and switch the handset on an off..this should work...because u will be in a search mode for something and you may not notice...this worked for my new LG 501
Feb 02, 2009 | LG KU990 Viewty
LG KP260  Cell Phone Logo
63 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
