FixYa.com
Tags:
Copiers
Generic problem for all Copiers
Having to remove the paper from the output tray...
posted by Ennuiboy on May 15, 2008
Whenever I load more than 5 pages into the Canon ir 3030 top feeder, it will only print about four or so pages before it asks me to remove the copies and then it continues printing another four pages and so on. Is there a way to change a setting on the copier so it just copies whatever I put in there without having the delay of constantly having to remove the pages? Thanks.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 21, 2008
Not Rated (0)
arti_stim
Rank:Guru Guru
Rating: 85%, 57 votes
Depends on what finisher is fitted to the machine, but i'm guessing that a sensor is dusty or out of location. Look for the sensors at each side of the finisher, adjacent to the paper tray. If found, try cleaning with a tissue. Let me know?
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: HP 260 Color Copier HP 190 Copier HP 610 Color Copier Panasonic DP-C264 Copier Panasonic DP-150A Grayscale Copier Panasonic Workio DP-2000P Grayscale Copier Panasonic Workio DP-2500E Grayscale Copier
Can you Help with these Copiers problems?
Toshiba e-Studio 232 Black and White Copier
Toshiba e-Studio 25 and Windows...
I have a Toshiba e-Studio 25... Answer This...
Toshiba e-Studio163 Grayscale Copier
COPY IS NOT GOOD....
i have a e-studio 163 copy and... Answer This...
Canon imageRUNNER 5020i Copier
Need User Manual
Purchased refurbished Canon... Answer This...
Toshiba e-Studio65 Copier
low toner
I replaced the toner but it... Answer This...
Canon ImageRUNNER 330s Grayscale Copier
Adding Staples Image Runner...
We have an Image Runner 330S... Answer This...
Repair Service
Find Copier Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
