Question about GE DBL333EA Electric Dryer
My dryer puts burn marks on clothes. The top of the dryer is too hot to touch. the back cover also shows heat marks on it. The drum gets red hot when running for a short time.
  • turtle77769 Sep 14, 2010
    it wasnt hooke up to a vent....running in the middle of a room....thanks for the input...
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 20 Answers
Could be the glide bearing that supports the front end of the drum. When this part wears out there is an increase in the gap between this area that clothes get into and it leaves a rusty spot that resembles a burn.
Posted on Jul 15, 2015
  • 121 Answers
The first thing to check if the vent. If the vent is clogged then the dryer will get too hot. http://www.appliance-repair-it.com/clothes-dryer-repair.html
Posted on Sep 14, 2010
  • shawnryan111 Sep 15, 2010
    The first thing, you need to do is place the dryer on no-heat selection and see if it still heats. If it does then you will need to check the heating element. If the element is grounded out the heater can run even if the dryer isn’t calling for heat. To check for a grounded out heater disconnect the power to the dryer and unplug the heater. Then test for continuity from one terminal to ground. If there is any continuity at all replace the heater.
    If the heater isn’t bad then there is an operating thermostat that may be the problem. The operating thermostat is located on or near the air duct and it controls the heat.
My Estate dryer is putting marks on my clothes that almost look like burns. With stain solution I can usually get them out but it's happening with every load now, what could be causing this? It h
see this causes and fix it. God bless you
Heating Element A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Heating Element Assembly A defective heating element assembly can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element assembly to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Oct 02, 2012 | Estate Dryers
The dryer is hot to the touch inside the drum
two issues the heat thermal relay or the fan motor quit working you can go to www.appliancepros.com and look up the parts list for your model.
Apr 14, 2010 | Amana DLE330RAW Electric Dryer
My crosley dryer is making a terrible scraping noise. I lifted the top of the cover off and could see the drum. There are several scrape marks in a few spots. Obviously it is rubbing on the bottom. What is...
The first thing to check is whether there is something caught in the drum rim (both front and back). Feel around the circumference of the drum in both places for a piece of clothing or pocket item jammed in there. If all is clear, then most dryers have drum glides on the front that will wear. Those aren't expensive and not that hard to replace for the mechanically inclined. A bad rear support roller is also a possibility. To replace it , the drum will probably have to be removed. Drums aren't that hard to get in and out, depending again on your mechanical ability. Hope that helps
Jan 02, 2010 | Crosley Dryers
My dryer leaves burn marks on the clothes. What
Hi. Thanks for using fixya. I can help you. When clothes get marked or torn in your dryer, check these: Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it. small_8_13.jpg
Nov 09, 2009 | GE DBL333EA Electric Dryer
My gas dryer puts burn marks on my clothes. I only use low heat
The flame is too high or the heat sheild is defective. The flame is too close to the drum!
Mar 26, 2009 | Frigidaire Dryers
Clothes getting caught in dryer tub and appear to be burning.
-Base on what you said. There is nothing or sharp edge to hold the
cloth by the time the drum spin. Looks like when you close the door. The door snap or bite the cloth and hold it still (no moving)
and the drum keep spinning and rubbing it at the same spot. That's why it mark a burning line.
Same thing like you drive a motorcycle. You apply brake to the front wheel and let the back wheel spin. So it will make a burn line on the ground.
Good luck
Mai
May 18, 2017 | Frigidaire Dryers
Overheats and sets clothes on FIRE
sounds as if your experiencing an air flow issue, check your venting.. it would be normal to see a red glow from the right side vents with in the drum( its heating up after all, and its merely a reflection form the heater located on bottom of frame, no way its gonna heat entire drum to "red hot")
Dec 24, 2008 | Whirlpool GEW9250 Electric Dryer
Brown burn spots on Whites
Hot spots in the drum perhaps. Check for a loose heating element.
May 06, 2017 | Dryers
Holes in Clothes from Dryer
clean dryer vent. check the inside of drum for sharp points and the back for proper seal.
Jul 12, 2008 | Kenmore Dryers
Dryer is leaving brown streaks on cotton clothes
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": http://www.youtube.com/watch?v=XoYP_YsGP68 . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Dec 30, 2007 | Dryers
GE DBL333EA Electric Dryer Logo
250 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
