Question about Maxtor 60GB ONETOUCH III MINI-EXT 5400RPM 8MB (R01E060) Hard Drive
Will not backup c drive - Maxtor 60GB ONETOUCH III MINI-EXT 5400RPM 8MB (R01E060) Hard Drive
Remove unwanted backups
Format Hard drive and them backup only 1 time. In the future, create an additional backup and then after that delete the oldest backup. I backup my system about every month.
Mar 06, 2014 | NTI Backup Now EZ
Hitachi backup saysproblem in windows 7 due to bit locker
You will always have problems to backup encripted drives, unless the backup software specifically supports the encryption software.
Usually you can to try to "mount" the drive as a unencrypted drive and run the backup on that drive.
Alternatively, use HD partition backup software (ex: DriveSnapshot, EaseUS, Paragon, etc...).
Mar 02, 2014 | Hitachi Computers & Internet
I only want to backup new information but the drive is backing up the entire hard drive each time. How do I change this?
Set your backup program to only backup the folders you need. You have it set to backup the drive. If your set up is to backup only "New" info, then the program needs to scan the drive to find out what is new.
Sep 08, 2013 | Seagate Expansion 2.0 TB USB 2.0 Desktop...
How do you start a backup on WD My Book
There are so many ways to do that.
1) Run the backup utility software that comes with the drive. choose the files you want to backup and select the drive as the destination for the backup.
2) Use Windows 7 backup software from start, Control Panel, system and security, backup and restore. Select the files you want to backup and select the drive as your destination for the back.
3) you can copy and pest the the File you want to backup to the drive.
Jun 07, 2010 | Western Digital My Book Home Edition 500...
My drive is full so it won't back up anymore!
Check the backup settings in the software that came with the device. You may be saving every backup instead of saving incrementally. An incremental backup will back up the files that have changed after doing one full backup.
You can also view the files on the drive through Windows Explorer.
The files should be dated. Delete the oldest files making sure that they seem to be the same size as the next oldest file.
If your computer is not faulty, and the files on the backup are not the only place that they are copied, you can start over with the backup drive, change the backup settings and create an incremental backup routine.
Depending on the size in Gigabytes of the backup drive, you are limited to the amount of data you can back up.
Example:
If you have a 500Gigabyte drive in your computer and the external backup drive is 250 Gigabytes,a full system backup will not fit.
Go to Windows Explorer, Click on My Computer and view the available space and total size for each drive.
If you need more help, Use Fixya's new Phone Call Service. For $29.99 an expert will walk you through the setup and drive check.
Mar 17, 2010 | Western Digital My Book Essential Edition...
How do i clone my hard drive onto an external hard drive
Are you using Windows? If you are using Windows, go to Start => Programs => Accessories => System Tools => Backup. In the backup wizard that opens, choose which backup type you want and you can choose your backup destination. Choose your Seagate Expansion external drive for your backup location so that Windows can store an image of your current system into your external drive.
Feb 09, 2010 | Computers & Internet
Two backup (one external hard drive)
Yes, that is possible. Normally what a backup does, is create a folder where it stores it's configurations and the data. If you create another backup and you name the backup differently, it will create a second folder.
Having said that multiple backups from the same PC, to the drive is also possible, because you create a profile for each backup and as long as the profile name is different it will not effect the other.
Jan 25, 2010 | Western Digital Passport 160GB External...
I want to backup my computers (4) and have maxtor partitioned and used at purchase time, but now when I connect it I get no prompts or choice of hard drive to back up. How do I go about back up?
You have a varity of option to do your backup depending on the type of backup you want to do.
1 Documents and folders
To backup your document and folders you can just copy the Documents and folders to the external drive.
You could also use the backuo feature of the Operating system you have like windows backup to backup your documents and folders.
2 System backup of your system.
You can not use a copy accross to do the complete backup of your system. You can use the windows backup to do this or a third party backup software.
Windows Back for Windows 7.
Click on Start ----- Controll Panel ----- System and Security ------- Set up Backup ------ Select where you want to save your backup ( the external Drive you connected to your system) in the box ------ Next ----- Choose the files or drive you want to backup and click next ------- Review your backup settings and save settings and run back.
This will save your files to the external drive you added to your system.
Jan 08, 2010 | Maxtor One Touch II (EO1E200) 200 GB Hard...
Seagate 250G running out of space
creat incremental backup rather than complete fresh backup.
empty trash can.
either way, it's possible the backup drive uses up more than working drive especially adding/deleting files alot between backup's.
Dec 26, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Maxtor 60GB ONETOUCH III MINI-EXT 5400RPM 8MB (R01E060) Hard Drive Logo
22 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
terminalcon
Jerry Umali
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
