Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
I had an "f2" error code on Fisher Paykel DD603
I removed the spray arm and impeller motor on the top (fault) unit and the darn thing broke in half with the metal impeller shaft sticking up. I then went the the bottom drawer and the whole impeller assy removed easily. Going back the the top and pulling on the metal shaft broke the shaft....
I finally got the bottom half of the impeller removed but damaged the large plastic piece the impeller asy fits in. After further investigation I noticed that the bottom impeller piece actually rubbed a hole through the large plastic piece that it fits in. So now I need to remove and replace the large plastic piece and order an new impeller assy.
How do I remove this plastic piece and how can I order new parts. I read in an earlier post that you can e-mail a service manual for FP.
Thanks for your help in advance.
  • 1 more comment
  • wbanwell Jun 26, 2008
    I need a service manual for the dd603.
  • xdfox Sep 03, 2008
    I too have the F2 error.
    Just moved into a new house with a dishdrawer DD603, saw the F2 error. Found that the impeller seems to be stuck.
    If anyone could forward me the workshop manual I would be very grateful.
    xdfox@hotmail.com
    Thanks in advance!
  • tliez1 Dec 04, 2008
    I have the same F2 error. In my case the problem is the that Rotor (F&P "Motor Rotor Assy" P/N 52688P) and the housing (a part of the F&P "Kit Motor Assy" P/N 528042 ?) rubbed together either due to a small foreign object or a small piece of the rotor or the housing fractured & lodged between them while spinning. Both the rotor & housing have a ring of damage about 1/4" wide near the center of the magnets. Also the lower blades show signs of damage.
    Replacing the Rotor Assembly is easy, but replacing the housing may not be.
    F&P will sell me the replacement Kit Motor Assy noted above, but will not supply instructions to perform the replacement. I am also concerned that I will not have all of the pieces that I will need.
    It appears from earlier posts that there is a service manual available. I would appreciate help in getting a copy. Thank you.
  • 770 Answers
I will but need your email address
Posted on May 20, 2008
  • gyagos
    gyagos Feb 18, 2012
    i too am in need of replacing the entire pump assembly as the impeller is fused and cannot figure out how to remove the existing one. Any help would be appreciated gyagos@yahoo.com
Fisher & Paykel Dishdrawer: DD603: Have had motor & rotor assembly replaced - now F-2 code here is goes again. Determined to have husband fix it!! I hope. Company says it is an issue with the...
Hi - F2 error code indicates a failure of the rotor/motor or the sensors, the following notes should give you guys something to check and see which of these has failed..
Error Code - F2
Which LED - Delicate LED
Reasons - The motor has not been sensed rotating
Likely Causes
_ Foreign object has jammed the rotor
_ The rotor has failed
_ The hall sensor has failed
_ The electronic controller has failed
Aug 19, 2011 | Fisher and Paykel 24 in. DD603H W Built-in...
F2 Error code beeping
your pump has seized.To check remove all the dishes followed by the grey dish wrack wedged in the bottom. Lift off the plastic spray arm to reveal a grey plastic ring around the outside of the stainless mesh, and you will also see the blue plastic impeller. Turn this anti clockwise and lift out the whole stainless mesh cover.
Then there is a brownish ring with the blue pump impeller on top. Turn this anticlockwise and the pump should lift straight up and out. My blue impeller had come off and lifted off with the brown ring leaving the rest of the pump stuck in the hole! I eventually managed to get it out without damaging the housing it fits into. Replace the motor/impeller unit and off you go.
May 01, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
There is an error code f2. How can I fix this?
The F2 code= siezed pump. To check remove all the dishes followed by the grey dish wrack wedged in the bottom. Lift off the plastic spray arm to reveal a grey plastic ring around the outside of the stainless mesh, and you will also see the blue plastic impeller. Turn this anti clockwise and lift out the whole stainless mesh cover. Then there is a brownish ring with the blue pump impeller on top. Turn this anticlockwise and the pump should lift straight up and out. The impeller may have come off and lifted off with it the brown ring leaving the rest of the pump stuck in the hole. So be careful here, get it out without damaging the housing it fits into. Replace the motor/impeller unit and off you go. Yours could just be stuck of course. A clean may do the same trick.
Feb 16, 2010 | Dishwashers
What is fault code f2 on fisher & paykel dishwasher
Rotor is not moving. Remove the spray arm, filters and the rotor, check for debris. Rotor impeller should turn if you try to turn it manually. If it does not - replace the rotor. Here is your part: http://www.fisherpaykelparts.net/ecart/item.php?item_id=231
Nov 26, 2009 | Dishwashers
I am getting an F2 error code on an DD603.
there is something jamming in the rotor , lift the spray arm and try spinning the blue fan , or if u havent used the btm drawer in ages it is a seized rotor , around 80 $ to buy new
Oct 27, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Excessive motor noise all parts in place correctly DD603 bottom dishwasher won't turn on top dishwasher just makes noise
Disassemble the pump and check the impeller. I would bet it's broken and the noise is caused by pieces rattling around. (I'm inferring that the part on top that isn't turning is the spray arm; that won't turn if there isn't any water spraying out of it.)
Aug 10, 2009 | Fisher and Paykel Dishwashers
Dishdrawer model DD603 gives fault F2 (Motor). Unit has only been used a few times. What to do? Out of warranty.
Ok this is what you do you need to swap over the motor rotors from top drawer to bottom drawer. check for anything jammming the rotor etc when you take it out. if it works with the other drawers rotor then you need a new motor rotor. cheers
PLEASE GIVE ME FEEDBACK
Mar 25, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher paykel
Looks like another older post unanswered, but for the sake of info I will answer it anyway.
F2 is a "motor not sensed to be rotating" code. This can be a simple as the rotor not being seated in the base properly, or it can mean you need a new rotor part number 525884P. Sometimes the impeller locks up or there is an object caught in it. You can remove the wash arm and filter plate with no tools, and then twist the base of the rotor assembly counter-clockwise and lift it right out. Try and spin it by hand. If it is frozen, it will need to be replaced.
As I said, no tools needed. You can get them here:
http://fisherpaykelparts.net/index.php?categoryid=113&productid=9
Oct 28, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher Paykel DD603
The top drawer on our DD603 top lid doesn't seal allowing water to spray out and down the sides.
Aug 10, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
1,876 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
