Question about LG Dishwashers
When the LG dishwasher come on it try to start then le flashes and it dost start what do i do
  • LG Master
  • 3,361 Answers
You have a water fill problem.
Make sure the water supply is turned on.
Could be a bad water valve,bad wire bad timer,etc.
Copy and paste this Factory Service manual to help in diagnosis.
http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
It may not be specific to your model number,you did not post a model number.
It should help generically.
Posted on Sep 14, 2010
What can cause and lg dishwasher to not fill water and stop and show le code
Please try the plain VINEGAR in the bottom of your dishwasher. It cleans out the pipes. When you start the machine it automatically starts to drain whatever water has been left from previous cycle. When this cannot happen, due to blocked outlet pipe, it will not precede with the wash cycle. Adding the vinegar, leaving it a few hours, or overnight (hey, I left it for a week one of those times!), it is enough to liquify any heavy fats in that pipe...enough to start the cycle and the normal draining gets reinstated.Hope this helps you, it is such a pain to go & choose another dishwasher to fit into the space allowed & that has all the functions you need. This 'fix' cures all my dishwasher blues! Havagreatday!
Sep 21, 2014 | LG LDF6810ST Stainless Steel Built-in...
I have a LG dishwasher, and from the word go I've had problems, I try not to use it any more. it started with flashing LE and bing bing bing all the time, now it flashes HE, I think its time to throw...
the le code is motor code the motor is not turning the he code is heater code if the motor is locked it will also bring up the he code because the over stat on the heater will cut out because the water cannot circulate
Oct 25, 2011 | Dishwashers
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
Aug 31, 2010 | LG 24 in. LDF 7811 Stainless Steel...
Dishwasher showwing LE error message
Hi Tanja
LE is motor error.
Empty water from inside the machine and try tripping the circuit breaker for a couple of minutes.
If that does no clear the error , then one of the following faults may have ocurred:
Wiring connection broken either bad connector on pump side or on timer control side, or faulty wiring harness.
The hose connected to impeller, or the impeller itself is blocked.
Motor or pump locked.
Faulty timer board.
Aug 15, 2009 | LG Dishwashers
Repair code LE and bottom is flooded
I don't know if this thread will help, but you can have a look here: http://www.howtomendit.com/answers.php?id=28214
If not try the LG website which has support and fault codes to assist you.
Jun 18, 2009 | LG 24 in. LDF 7811 Stainless Steel...
My LG dishwasher stops running 5 mins in
The LE code means there is a problem with the washer motor. ( Motor error ) Condition : The motor is working abnormally. Possible cause : Wiring connections. The impeller of washing pump is locked. The rotor of washing motor is locked. The blade is locked.
Remedy: Correct wiring connections. Replace the cause of restriction. Replace the washing motor. Replace the PCB.
May 02, 2009 | LG Dishwashers
I get error code le on LG dishwasher.
hi,
le means locked motor disassemble the filter and work your way down to the macerator(steel chopper blade) remove it and see if the side labeled "this side up" is really up, its in english... dont think the chinese labourers paid attention to the warning cause i have seen alot that were wrong way
if it was installed correctly order the complete motor/sump assembly btw you do know LG d/w came with a 2 year warranty right? and some of the water distribution system had a longer limited warranty
read your manual, it states warranty, then price the part, then call warranty depot to ask them their service call and labour to install motor/sump
This part taken from a LG repair manual:
(Display Condition LE = Motor Error
locked.
locked.
Remedy:
Replace the PCB.)
good luck.........
Mar 12, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
LE indicater
I have had that where the filters are dirty,
check and clean filters at base of dishwasher.
Chris
lg durban
031-7165444
Jan 22, 2009 | LG 24 in. LD-12BW5 Free-standing...
LE ERROR CODE
This new....just call out LG to repair under warenty!!
Jul 22, 2007 | LG LDF6810 Built-in Dishwasher
Dishwashers Logo
112 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
