Question about LG LFC21760 Bottom Freezer French Door Refrigerator
Just had LG frig installed yesterday. Freezer temp is set on 0 and frig temp is on 37. Are these the normal settings? Could not find anything in Owner's Manual.
  • LG Master
  • 3,361 Answers
Yes,those are correct for most applications.
Leave them for 48 hours before you decide to change. them.
Posted on Sep 14, 2010
I HAVE A LG SIDE BY SIDE BOTTOM FREEEZER WHY IS THE FRIG TEMP IS SET ON 8 AND WANT GO TO 40 AND THE FREEZER IS SET TO -29 AND WANT GO TO O
Check the rear of your freezer compartment. If it's frosted up, your defrost circuitry is bad. If it's not frosted up, then you probably have a coolant leak and need a professional.
Oct 17, 2014 | LG LFC23760ST Side by Side Bottom Freezer...
Model lsc27921sb repair
Check to make sure the fan or fans are not blocked, and spinning.
Apr 14, 2012 | LG Refrigerators
Our fridge is not keeping cool. both the fridge and freezer stopped working yesterday, then we vacummed it out- the freezer works but the fridge is only at 39 degrees. Help?!!!
If your freezer is working properly.(that is it freezes ice)and frig is at 39 dg then you most likely have a problem with air flow . set thermostat and air control at middle setting and leave there for a few hrs. You should see temps stabilize with some time.
Dec 31, 2010 | Kenmore Refrigerators
Bottom frig is not cold enough. just connected after 1 yr
Ok do this. Boil some water in a pot then use that to defrost the freezer. This is caused by ice build up in the vent that is keeping the cold air from coming into the refrigerator. Make sure it is defrost completel though cause the ice that is built up is mostly inside and can't be seen. That will solve ur problem I guarantee. Then set the temperature to normal. Like half way. This keeps the frost from building up. Believe it or not as refrigerators get a bit older they actually get even colder and therefore frost build up is more likely. Since no refrigeration can be made completely leak proof, small amount of the freon has leaked out older fridge, and this actually cause it to get colder. You don't need a service technician just defrost then set to a lower setting thats it.
Feb 11, 2010 | LG LRTC19314ST Top Freezer Refrigerator
We have a LG Two Side Fridge.
Look for the air ciculation regulator sliding vent between frig & freezer section open accordingly. Set both sides to #3 on dials if frig not cooling to less than 40 degrees, might need new cold/temp controller behind frig dial
Apr 30, 2009 | LG LRSC21934 Side by Side Refrigerator
Temperatures fluctuating
Wonder why the "repair men" can't find a defective temperature control or circuit board.
Nov 06, 2017 | Frigidaire Refrigerators
LG LRBN20514ST Bottom Freezer Frig cooling problems
Set the temp to low not high and wait 24 hours to see if the temp has drop.Also make sure the freezer is not icing up anywhere.If it is please repost.
Jan 13, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Lg frig side is warm but freezer side is good
You are setting your fresh foods side to 34 but the display will go back to showing the actual temp. It is still set at 34. The refrig should be able to reach the 34 setting, so although 40 is an OK temp for a refrig, it is not what you set it to and you are definitely having a problem with the unit. Instead of starting to go through a long list of checks, I would advise you to call for warranty service, as the unit is only 3 months old.
Please don't bother rating this solution, as anything but a FixYa will lower my score. Thanks.
Nov 30, 2008 | LG LRSC26940ST 36" Side-by-Side...
Sub-Zero temperture fluctuation
Just posted this elsewhere and it sounds like the same problem:
As you probably know, the recommended temperature range is between 35-45 F so if your control will not allow you to set this, the sensor or associated regulator has failed.
This seems to be an issue with Sub-Zero.
Aug 02, 2008 | Sub-Zero 650 / O Bottom Freezer...
LG LFC21760 Bottom Freezer French Door Refrigerator Logo
202 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
