Question about Olympus FE-140 Digital Camera
My olympus FE-140 the lens will not open but it start
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Sep 14, 2010
Olympus 5020 lens stuck, turns off after power
Please check if the digital camera batteries in it are effective,if the battery have compatibility problem ,no strong enough power or voltage,the refered satuation maybe happen.Change the olympus battery for a new one ,then try again. After use some years ,the olympus battery life usually end.
Jun 02, 2010 | Olympus FE-140 Digital Camera
Need a new instruction manual for our Olympus Digital FE 140 camera
Hello. Click the link below to download the 108 page manual for your camera. Save a copy to your computer for future use.
builderdale
http://www.olympus.co.jp/en/support/imsg/digicamera/download/manual/zoom/bman_fe130_e.pdf
Mar 03, 2010 | Olympus FE-140 Digital Camera
Need to download olympus fe-140dig.compact camera Service Manual
Well you can download the manual in pdf format from here: http://www.retrevo.com/support/Olympus-FE-140-Digital-Cameras-manual/id/200bh637/t/2/..................................sodeep
Aug 19, 2009 | Cameras
Olympus FE-140 ok except that flash does not work
Make sure you try and reset the camera to the factory default settings. There may be a setting that you are using that has disabled the flash functionality. To reset the camera - have the camera in shooting mode - press the menu button - left arrow to reset and press ok - you will see reset yes or no - highlight yes and press ok - camera will be back in factory settings - see if flash is able to work now.
Dec 28, 2008 | Olympus FE-140 Digital Camera
Lens not opening.
Try a new set of batterys.
Dec 26, 2008 | Olympus FE-140 Digital Camera
MY FE 140 OLYMPUS DIGITAL CAMERA
Lens will probabaly need to be replaced. Used replacement lenses can usually be found on ebay. Mechanically inclined person can replace them quite easily. Olympus repair shops are usually quite expensive and it's almost better to get new camera rather than have them repair it.
May 18, 2008 | Olympus FE-140 Digital Camera
Camera lens will open then close, plus both orange and yellow lights both flashing all the time
In addition to the one year World Wide Warranty,
issued by Olympus Corporation in Japan, the European warranty, issued by Olympus Imaging Europa GmbH, is
valid for two years from the date of purchase, if purchased after 1st April 2004
Oct 10, 2007 | Olympus FE-140 Digital Camera
Olympus FE-140
Yes I had the same problem, however, where is says "push to eject," it means to push the the memory card down and it will eject. You pushed down the latch for the plastic door cover. Try pushing something into the hole so the camera thinks the door is closed. I am still having trouble with mine. Hope this helps alittle.
Sep 16, 2007 | Olympus FE-140 Digital Camera
Lens wont retract
Lens motor is shot - check out Olympus web site for repair options-not cheap
Jul 04, 2007 | Olympus FE-140 Digital Camera
Olympus FE-140 Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
