Question about Apple iPhone Smartphone
Iphone has been connected but could not be identified
When I connect my iphone to my lap top I got the following message on itunes: "iphone has been connected but it could not be identified properly"
I tried a few times, in some cases when my laptop wss connected to its hub it did work. Also i had trouble opening itunes it took a great deal of time for it to start.
Thanks,
Shachar
I have the same problem let me know if you get any progress
Posted on Jul 09, 2008
How do you retrieve deleted text messages on iphone 4
Well, iPhone Data Recovery may help you solve your problem. You know, it is good at recovering iPhone data such as sms, contacts and more. You can follow the steps here in the following:
Step 1: Launch the program and scan to recoverStep 2: recover deleted SMS from iTunes backup files
Step 3: Start to recover iPhone text messages
For more details, read this guide:
Retrieve Deleted Text Messages on iPhone
Apr 12, 2013 | Apple iPhone 4 Black Smartphone
My iphone just turned of and it had full battery now it wont turn back on any help ?
Hi
Try holding down your power button and the power button for about 10secs or until an apple appears, your phone should then load up. If not then please follow the steps below to restore your iphone..
Use the following steps to restore your iPhone.
***** IF YOU CANT SEE YOU IPHONE IN ITUNES OR IT IS STUCK AT THE APPLE LOGO - POWER DOWN YOUR PHONE - HOLD DOWN THE HOME BUTTON FOR AROUND 6SECS WHILST CONNECTING TO ITUNES - RELEASE BUTTON - ITUNES WILL THEN APPEAR WITH MESSAGE SAYING IT HAS DETECTED IPHONE IN RECOVERY MODE & CONTINUE TO RESTORE YOUR PHONE - FOLLOW FROM STEP 6! ) *****
  1. Make sure you have the latest version of iTunes installed and running before attempting to update.
  2. Connect your device to your computer.
  3. Select your iPhone when it appears in iTunes under Devices.
  4. Select the Summary tab.
  5. Select the Restore option.
  6. When prompted to back up your settings before restoring, select the Back Up option. If you have just backed up the device, it is not necessary to create another.
  7. Select the Restore option when iTunes prompts you (as long as you've backed up your device, you should not have to worry about restoring your phone).
  8. Once the restore process has completed, the device restarts and displays the Apple logo while starting up:
    iPhone only: For the iPhone only, after a restore, the iPhone displays the "Connect to iTunes" screen. Keep your device connected until the "Connect to iTunes" screen goes away or you see "iPhone is activated." If iTunes does not have an Internet connection, you cannot complete this step.
  9. The final step is to restore your device from a previous backup. Once your device is restored and-in the case of the iPhone-in the process of activating, you should be able to see the following in iTunes:
    Select the backup you want for your device and select the Continue button to complete your device's restoration.
If you do not want to restore from backup, select "Set up as new...
Jan 01, 2011 | Apple iPhone Smartphone
My apple iphone16gb i lost the passcode and now this is only for emargency calls only i tunes couldn't be connected plz help me to unlock it
Hi, you will need to restore you phone but because itunes isnt seeing your phone you'll need to turn it off and hold down the home button for around 10secs and connect to itunes and release then itunes will bring up a message saying the phone has been found in recovery mode, from there continue with restore (follow from step 6 below)
***** IF YOU CANT SEE YOU IPHONE IN ITUNES OR IT IS STUCK AT THE APPLE LOGO - POWER DOWN YOUR PHONE - HOLD DOWN THE HOME BUTTON FOR AROUND 10SECS WHILST CONNECTING TO ITUNES - RELEASE BUTTON - ITUNES WILL THEN APPEAR WITH MESSAGE SAYING IT HAS DETECTED IPHONE IN RECOVERY MODE & CONTINUE TO RESTORE YOUR PHONE - FOLLOW FROM STEP 6! ) *****
    After a restore, the iPhone displays the "Connect to iTunes" screen. Keep your device connected until the "Connect to iTunes" screen goes away or you see "iPhone is activated." If iTunes does not have an Internet connection, you cannot complete this step.
Jan 01, 2011 | Apple iPhone 3G
My iPhone WILL NOT stop repeating this message... It is interfering with my sounds because it believes that it is still plugged into the stereo!!! The error message reads...."This accessory is not...
you'll need to restore your iphone to factory settings -
Use the following steps to restore your device:
  6. When prompted to back up your settings before restoring, select the Back Up option (as seen in the image below). If you have just backed up the device, it is not necessary to create another.
If you do not want to restore from backup, select "Set up as new..."
Dec 29, 2010 | Apple iPhone 3G
Just got phone downloaded itunes inserted sim card, but i tunes logo is all that is coming up on front of phone what more do i need to download ?? or what should i do to get phone up and running?? advise...
your phone has gone into recovery mode, you need to connect it up to your comp with itunes loaded up, make sure your itunes is the most recent update.
itunes will then appear with a message saying that it has detected an iphone in recovery mode and that you need to restore so carry on with the restoration of the phone.
below is a step by step on how to restore your phone but on the last steps you need to make sure you restore the iphone as a new iphone. Once you have gone through all that it will basically go through the setup of it and the activation of the phone, Hope this helps!
Dec 25, 2010 | Apple iPhone 3G
Iphone will not get pass apple logo even after i reset it several times
hi you need to restore your iphone as new...hope this helps!
Dec 25, 2010 | Apple iPhone Smartphone
How do you unlock a forgotten passcode on an iphone 4g
As you have forgot the passcode you will have to restore the iPhone using iTunes.
Note: This process will wipe all data from your iPhone 4. You may be able to sync most of the data back once you have restored it.
1. With the iPhone 4 disconnected from your computer, power it off. Press and hold the Power button on the top of the device for a few seconds, then slide the red slider. If this method doesn't work, press and hold the Power and Home buttons for a few seconds until it goes off.
2. With the iPhone 4 off, press and hold the Home button while connecting it to the computer you registered it from. It should then power on.
3. Keep holding the Home button until you see a Connected to iTunes message appear on the screen.
4. Open iTunes and it should provide a message about an iPhone connected in Recovery Mode.
5. In iTunes, select the Summary tab and click Restore and follow the prompts.
6. You may attempt to sync your iPhone back to your iTunes to restore any data lost in the recovery process.
I hope this helps! Thank you for using FixYa!
Oct 29, 2010 | Apple iPhone 4 Black Smartphone
How do i unlock my iphone i forgot the passcode
1. With the iPhone 4 disconnected from your computer, power it off. Press and hold the Power button on the top of the device for a few seconds, then slide the red slider. If this method doesn't work, press and hold the Power and Homebuttons for a few seconds until it goes off.
When the process is finished, your iPhone 4 should be available again without the need for a password.
Sep 19, 2010 | Apple iPhone Smartphone
Hi i got iphone with passcode locked can you help
Sep 11, 2010 | Apple iPhone (16 GB) Smartphone
Iphone won't allow me pass screen with itunes usb cable
Step 1. Turn off your iPhone.
Step 2. Hold down the power and home button.
Step 3. When you see the Apple logo, release the power button but continue holding the home button down.
Step 4. Open iTunes and wait for it to tell you that its in restore mode.try this it will work defenately
Jun 12, 2009 | Apple iPhone 3G
Apple iPhone Smartphone Logo
153 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
