Question about Olympus C-3000 Zoom Digital Camera
I have an old c 3000 zoom camera/digital. I am running vista as my os. I neeb a driver to even pull thecamera up over usb port but cant find proper driver. cn you help?
  • 10,421 Answers
Olympus camedia digital c-3000
maybe the OS on that hp lap is Vista:
well u need a compatible Vista Utility/driver for u cam.
check olympus for ur cam vista drivers!!
May 31, 2009 | Olympus Camedia Stylus 300 Digital Camera
Hello, i am trying to get microsoft web cam nx 3000 to work on my vista 32 bit OS however the driver does not install properly, driver error 39. can you help
Normal 0 Try disconnecting the Camera from the USB port and reinstall the software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Jan 25, 2009 | Microsoft LifeCam NX-3000 Personal Web...
QuickCam Zoom not working after upgrade to Vista
Just read the most wonder article on how toe fix your quickcam zoom for vista follow these steps
These is from 2007 post so you will have to google for the drivers mentioned. I did and it worked
I have a Logitech Quickcam Zoom and this is how I got it to work:
1. Install QuickCam 32-bit Version: 10.5.0 Build 1096b
It can be found here: http://www.logitech.com/index.cfm/downloads/software/CA/EN,CRID=1794,contentid=10234
2. When you get to the camera detection part where it asks you to plug in your camera, plug it into a new usb port (if you had it plugged in when you installed Vista) and just press skip.
3. Windows may try and find the driver for it, you can cancel that too.
4. Install the old QuickCam software (Version: 8.4.8 build 1034A)and overwrite anything it asks you to (it will fail to install completely because of the new version, but it will put the files you need into the Logitech program files directory.
The old software is here: http://www.logitech.com/index.cfm/downloads/software/CA/EN,CRID=1794,contentid=7649
5. Go to the windows orb (former start button), open control panel, go to system, then on the top left of the window click device manager.
6. Find the unknown usb device (hopefully you only have one... otherwise unplug anything else that doesn't work or you haven't updated the driver for yet)
7. Right click and select update driver, choose a location to find the driver, navigate your way to C:\Program Files\Logitech\QuickCamWebInstall\Drivers\WinNew\PRO2
8. Press OK or whatever, and let it install.
9. Enjoy!
Mine didn't even need to reboot and worked with the 10.5 QuickCapture software. Still need to test with Skype and Live Messenger though.
Jan 08, 2009 | Logitech Quickcam USB Zoom Webcam
Olympus C-3000Z and Vista, can't unload
i have an olympus c-3000 more don"t instalaction automatical to windows i dont have the softwear for instalaction : cd ok
Aug 22, 2008 | Olympus C-3000 Zoom Digital Camera
Can't find driver compatible with windows vista for D-540 Zoom
Do you have driver for XP? I have the same problem, but with XP. I can not insall the camera. I don't have the originalCD. I you have the driver, please send me .
My e.mail: klavier.mozart@aon.at
Thanks Jovanka
Mar 30, 2008 | Olympus Camedia D-540 Zoom Digital Camera
Olympus C-3000 download Help
I also have a c-3000 zoom and tried to use it with my vista laptop for the first time (worked fine for years on xp with the software). I got an error message saying something along the lines of "Your camera is too old to work with Vista" (not the exact wording). I bought an external card reader, and you should probably do the same.
Mar 27, 2008 | Olympus C-3000 Zoom Digital Camera
Vista and firewire 1394?
Firewire works fine under Vista, but it's quite possible your USB to Firewire bridge doesn't have proper Vista drivers. You wouldn't expect Vista to include these, they would be installed from a disc that came with your adaptor. USB to Firewire is a questionable option at best... there are often problems with it. You may be better off with a PC-Card or ExpressCard solution, if the laptop is your only computer.
Also, when the camera says "DV IN", it's expecting video from the PC to be sent to it, it's not in capture mode. Most camcorders must be in either "play" mode, or a special "link to PC" mode in order to even be recognized by Windows (any version) as a video input device.
However, until you resolve the issue of supporting your Firewire device in Vista, nothing the camcorder does will be an issue yet. You should check the documentation that came with your USB to Firewire device, the driver disc, etc. for information on Vista support.
Jan 05, 2008 | Canon ZR200 Mini DV Digital Camcorder
Camedia software to see my camera via the USB port.
I'm assuming a Windows Machine (98 or 2000), and that you have (known to be) working USB ports. Boot your computer. Plug the computer end of the USB cable directly into the computer USB port (not a hub). Turn off the camera. Plug the camera end of the USB cable into the 3000. Then turn on the 3000. Windows should recognize new hardware. When Windows asks about drivers for the new hardware, direct it to your Camedia CD. Probably directory \USB\Win98 (or 2000) or something similar. Windows should then load the driver automatically. I *don't* think the 3000 will show up as a Drive device in My Computer. I think only the 2040/3040/E10 models will. But, Camedia should see it now. Toward the left-hand side (center) of the Camedia screen you should see a camera icon. Click it and it should open directories, drill down till your pix appear as thumbnail images. If Camedia says it can't find the camera, select Edit/Options/Download from the Camedia menu and ensure that USB is the selected choice.
Sep 07, 2005 | Olympus C-3000 Zoom Digital Camera
Olympus C-3000 Zoom Digital Camera Logo
73 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
