Question about Alesis Multimix 8 USB 8-Channel Mixer Spdif System
Alesis GIgaMix 6 FX(powered mixer) Has worked fine for a few years then nada. It still powers up when I turn it on but no sound to speakers. Tried various speakers and cables assuming a broken speaker cable. Is there a second(hidden) fuse that has possbily blown and where is it located?
SOURCE: wont install in my vist computer
I have the same prolem
Can everybody help us please
Posted on Aug 27, 2008
  • 15 Answers
SOURCE: Alesis M1 Active Mk2 Speaker won't Power Up
Hi, This is usually the Capacitor C8 on the powerboard it usually bulges and pops, its becuase its right next to a resistor which gets very hot and sometimes puts the capacitor into meltdown, yours might have gone past that stage but this is worth a look; http://www.neufeld.newton.ks.us/electronics/?p=232
Hope this helps
Cheers
Steve
Posted on Jun 02, 2009
  • 15 Answers
SOURCE: alesis 620 m1 active studio monitors sound cutting out
It could be a power problem, unless you have blown the driver ?, carefully pull out the power supply board, and look to see if anything looks melted, burned, or capacitors popped etc. Be carefull though as I do not want to be responsible if you get an electric shock, etc. preferably look and dont touch, just use common sense ;)
SOURCE: alesis prolinear 720 powered monitor stopped working
Yeah. I think you should listen to that guy, Lamar Barton.
Posted on Dec 18, 2009
kevinmunn
SOURCE: clip signal on Alesis multimix 12 USB - no inputs!
What capacitors?
Posted on Sep 28, 2011
Condenser mIcrophone input quiet to nonexistant but other channels work fine
The condenser microphones I am familiar need power to operate, some have Phantom, some have a battery and some have both. What you are describing sounds like no power to the internal mcrophone amp.
Feb 02, 2013 | Alesis Multimix 8 USB 2.0 FX 8-Channel...
Alesis 620 M1 active no power no light
You just fix the power supply and Brige and check the transformer
May 18, 2012 | Alesis M1-Active MkII Main / Stereo...
I have a mackie fx 8 mixer connected to two thump 15 " speakers. i want to add a set of base non- powered speakers with power amp to my fx 8. what are the connections?
Balanced audio interconnects (either XLR or TRS cables from the mixer and then balanced audio interconnects from the amp daisy chain inputs to the existing speaker inputs. If the amps do not have linked input jacks, then use TRS type WYE connectors at the inputs. Then use speaker rated cables from the amps to the passive speakers.
Aug 12, 2011 | Mackie ProFX8 Professional Compact Mixer
How do i go about connecting the alesis monitor one mk2's to my my laptop? i do not have an amp and there are no cables or connectors with the speakers when they arrive
You can without an amp in between. They are non-powered speakers and need an amp to drive them. If you connect your laptop to a mixer, mixer to an amp, then amp to speakers THEN they will work.
Feb 19, 2011 | Alesis Monitor One Mk2 Speaker
No power
Take a breath...
We need to know a few details here
Colors of the wires? Are wires broken on the power supply or did the power jack come out of the mixer? If they are broken INSIDE the mixer, what happened in there, anyway?
Have you checked Alesis's website for tech support or documentation? 'Cuz that is what any of us would have to do. They're really good at this kind of support. or you could call Alesis at (401) 658-5760
Jul 23, 2010 | Alesis Multimix 16 USB 16-Channel Mixer...
Clip light on Multimix 12 Firewire always on
I have just gotten the same problem. In my case it worked fine for almost three years and one today I turned it on and this loud humming noise + the red clip light always on appeared. When I hit solo button on channels 9-16 the humming disappeares but the light would not go away. With solo on humming get louder on the mic channels individually (1-8). I am puzzled... No solution so far
Sep 27, 2009 | Alesis Multimix 8 USB 8-Channel Mixer...
How to hook up alesis air fx to 16channel makie mixer what jack it goes into
Go to http://www.zzounds.com/item-ALEAIRFX.Under the picture you will see About This Product. Click on DOCs and you can download the manuals for it. Read the manual carefully and it is explained very well. Use your mixer manual to get the best set up. I would recommend using it in an FX loop that lets you mix the individual channels FX into the output you have hooked up to your computer.
May 17, 2009 | Alesis Music
Clip signal on Alesis multimix 12 USB - no inputs!
http://www.fixya.com/support/t3033553-clip_light_multimix_12_firewire_always
eugene_m has a solution. You have to replace 2 capacitors.
Apr 12, 2009 | Alesis Multimix 8 USB 8-Channel Mixer...
Hooking up sound system
The RSQ player goes into the input section of the mixer.
The mixer effect send goes to the Quadraverb input and the output of the Quadraverb goes back to the effect in on the mixer. Now the Main out on the mixer goes to the EQ then the EQ goes to the compressor/limitor to power amp to speakers.
Apr 02, 2009 | Stanton Sa3 DJ Mixer With Eq System
Wont install in my vist computer
May 08, 2008 | Alesis Multimix 8 USB 8-Channel Mixer...
Alesis Multimix 8 USB 8-Channel Mixer Spdif System Logo
252 people viewed this question
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
shaqsatin
Level 1 Expert
Ben Armstrong
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
