Question about HP Office Equipment & Supplies
My printer HP Officejet J4580 All in one, does not print, It reports "Entering sleep mode". Put new ink cartriges in, paper not jammed and no lights flashing and I printed a test page on the printer to check' old cartriges. Advise.
  • HP Master
  • 19,396 Answers
Hi.
Try the following in order:
Disconnect printer power cord.
Turn off computer.
Disconnect computer power cord. (if laptop also remove battery)
Restart first computer than printer.
(this may look stupid, but it drains power that can jam USB ports and cause malfunction).
Clean the metal plate contacts in the ink carriage using cotton and isopropyl alcohol or cleaning solution.
Try turning off printer and performing a new cartridge installation. Use the HP software cartridge replacement procedure, do not simply swap cartridges.
Disconnect printer USB, reinstall printer software, connect printer back when prompted by setup wizard. Updated software for this model available at Software & Driver Downloads.
If you have spare cartridges, test them, the problem may be caused by a defective cartridge chip. Non original or refurbished cartridges commonly cause similar problems.
Posted on Sep 14, 2010
My HP J4580 will only print color. How do I fix it so the black will print?
When you go to print out the document make sure you have selected to print in black and white
Jul 30, 2015 | HP OfficeJet J4580 All-In-One Laser...
How to check ink levels in a HP officejet J4580 printer
Checking ink levels
  1. open HP solution center on the computer desktop screen
  2. click on settings on the bottom
  3. click printer toolbox
  4. click the estimated ink levels tab
or
  1. on the printer control panel,push the wrench button
  2. press the right arrow to go to print report
  3. push OK
  4. select self test
  5. push OK
It will print a page with color bars signifying correct ink levels.If a color bar is blank it means it's empty or depleted and needs to be replaced
Jul 21, 2011 | HP OfficeJet J4580 All-In-One Laser...
Clearing a Paper Jam On Top - HP Officejet J4580
Lift up the top and look for the torn piece of paper. try moving the roller with you fingers it will not print untill you get all the paper out.
Jan 14, 2011 | HP OfficeJet J4580 All-In-One Laser...
My hp officejet j4580 all-in one is having problems feeding the paper. Paper feeds partially then jams.Repeated attempts resulted in same action.
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 06, 2010 | HP OfficeJet J4580 All-In-One Laser...
How can I fix a paper jam on HP OfficeJet 4580
hi,
Paper jam messages can be true or false. The product might report a paper jam when there is not any paper jam. The following steps resolve both true and false paper jam messages.
this link will help you out:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01368841&cc=us&lc=en&dlc=en&product=3645100
thank you for using fixya,rate my answer
vijay
Oct 05, 2009 | HP OfficeJet J4580 All-In-One Laser...
My Officejet 5610 will feed the paper but no ink will be on it
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab103
Jun 17, 2009 | HP Officejet 5610 All-In-One InkJet...
Print cartridge problem: tri-color
lestave my j4580 trouble lt says ck blk cartrige
Jun 09, 2009 | HP OfficeJet J4580 All-In-One Laser...
It starts printing, then stops, the printer cartrige is jammed
Try emoving the duplex cartridge on the back (return printer to it's original configuration) and try printing. If the printer prints OK, then re-attach the duplexer checking for anything that could interfere with the print cartridge.
If the printer doesn't print, then I suspect something has fell into the printer and is creating enough resistance for the printer to detect and report. Turn the printer off, Remove all the cables from it. Try inverting the printer and gently shake it to see if anything falls out that could be jamming the printer cartridge.
Jun 02, 2009 | HP OfficeJet Pro K8600 Printer
HP Officejet J4580 paper jam
Paper can jam inside the printer for a number of reasons.
  • Open the cover to the printer and look inside to see if there are any pieces of paper or debris that may be blocking the print path.
  • Be sure to unplug the printer before touching anything internal to avoid electric shock. If there is something blocking the print path, remove it, close the printer, and try printing again.
  • You can also check inside the printer to see if any components have come loose.
Feb 24, 2009 | HP OfficeJet J4580 All-In-One Laser...
69 people viewed this question
Seeker5211
Seeker5211
