My problum is red colour not appear in printing this is convert to yellow how solve
  • 17,129 Answers
First of all check your ink cartridges after selecting the maintenance program .If bad replace and make a test print.
had a head cleaning done within the program. If there is no improvement remove printer, reinstall and check once again.
If not the printer head can be faulty .
Posted on Sep 14, 2010
After changing the ink catridges and resetting the drum fuse lately (note: it is known that the fuse will be blown off after certain number of prints but otherwise is in good condition), my Epson Acculaser...
The repeating image is a ghost image, and here is described what it can be. Probably if you solve this, you also solve the red-dot problem. If possible, I would suggest to replace the wiper blade.
Repeating images on laser printerThis likely means a faint ghost of the main printout at a distance equal to the circumference of one of the rollers or photosensitive drum.
Depending on where the problem originates, this could be a bad wiper (cleaning) blade, faulty corona, or incomplete fusing.
  • If the distance between successive images is equal to the circumference of the photosensitive drum, it is a wiper blade, erase lamp, or corona problem.A residual latent image or residual toner is sticking to the drum and not being properly cleared.
  • If the distance between successive images is equal to the circumference of one of the fuser rollers, then the fusing may not be complete due to damaged rollers or an incorrect temperature setting.
It is easy to determine where the problem is located: Interrupt a printout in mid-stride (where part of the paper is between the toner/developer and fuser. If the un-fused image has ghosting, it is a fault in the area of the drum
Jul 08, 2011 | Office Equipment & Supplies
I have just fitted new cartridges although it was only the colour one which needed renewing I thought! However it wuld only print out in red/pink shades so I changed the black cartridge to be on the safe...
I have personally encountered similar problem in my work. There is no problem with your printer, No need to go to your suppliers yet.
Sometimes when either of the inks overflow at the nuzzle, it gets absorbed to an extent into another ink compartment. So that colour affected now prints another colour; the colour that has crept into its compartment, Sometimes it is serious at other times is not. If not serious, usually, after a few solid colour prints the colour affected returns to normal.
I do not know how much of a technical person you are, but I will give you the solution to returning that yellow printing red back to printing truly yellow. Bring out your colour cartridge. Peel off the seal covering top. You will see the holes through which in is fed into it. Get a clean handkerchief, fold it and place over the top of the cartridge. Hold it over a bowl or something. Now place your mouth over the top with the handkerchief in between and blow hard. Ink will discharged at the nuzzle. Clean off the ink. (At the nuzzle do not rub only dab). Now press a piece of folded tissue to the nuzzle firmly. It should be blotted with ink:- red, blue, yellow. If any colour is missing you may need to repeat the procedure. Once you get the three colours back, the issue is resolved.
Dec 06, 2009 | HP PSC 2355 All-In-One InkJet Printer
My DCP-115C printer was missing red colour.
Yellow is one of the colours used to produce a shade of red.
I don't know how but ther must be a way to print a test page to see if the print heads need cleaning I've never used a brother.
Sep 26, 2009 | Brother DCP 115C All-In-One InkJet Printer
Printer prints colours in different colours
Either you are out of red ink or the print head is getting plugged. Most printers substitute the nearest available color when a color runs out or the head is plugged. As some shades of red are made with yellow mixed, it therefore prints only in yellow if red is unavailable.
Aug 30, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
My brand new ESP 5 will not print red letter on a
It seems to be a problem with the colour ink cartridge ,did you remove the protective tape that came with it?
you should return the colour cartridge and get it replaced or buy another one.
If that doesn't solve it then return the printer since it's under warranty.
Jun 15, 2009 | Kodak ESP 5 Printer
I just fix in new black and coloured cartridges and only black and red colours appear on my prints. the replaced coloured cartridge was giving similar print problems.
hi im josh in cebu phils. friend may i help you? it happen try to shake the cartridge that doesn't print.and install it again and just remember this: Problem: Your Color Printer Doesn't Print All Available Colors This problem is most likely caused by an old ink cartridge. It's not unusual for some colors to get depleted before others, throwing off your color output. If you're seeing less blue (or red or yellow or black) than normal, chances are it's time to change your cartridge. so thats all good luck
Mar 06, 2009 | HP DeskJet 1280 InkJet Printer
Won't print colour copies it comes out in yellow
Try replacing the Yellow/Black Printhead of the All-in-One. I am sure the issue will be fixed.
Jan 08, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
The upper 2/3 of the word is either red or yellow
let the cartridge be new but the colours are got mixed with each other so this problem as the canon cartridge has the sponge in the cartridges that sponge material has soaked the colours from each other and this has happened.to solve this problem two things needs to be done 1)the head needs cleaning as the colour will be filled in it now.
2)the cartridges needs to be replaced.
Dec 15, 2008 | Canon BubbleJet i560 InkJet Printer
Printing Yellow instead of Red
The colours in the 3 colour cartridges are cyan, magenta and yellow. If you want to print "red", this requires a mixture of magenta and yellow. Thus if only yellow is printed when you should be printing red, it means the magenta is not printing i.e. faulty/empty magenta cartridge or faulty/blocked magenta nozzles.
Please post a new comment if you wish for further help with this problem.
Jul 17, 2008 | Epson Stylus C86 InkJet Printer
PRINT COLOUR IMAGE FROM GOOGLE IMAGES
getting vertical lines on my pictures . i have a epson cx5000.
Jun 08, 2008 | Epson Stylus C66 Inkjet Printer
71 people viewed this question
k24674
