I did a channel search and found all local and DISH satellite channels. I then somehow lost all the local channels and now repeated scans will not find them?
  • 12,061 Answers
I know what to do.
Posted on Sep 14, 2010
  • electronic & computer repair&  servicre
    You need to reset the unit and do it all again. You need to clear the memory before you can re-tune the channels as it still thinks it has them all.
    Check your manual on how to do this.
I have a Curtis 24 inch Full HD LCD TV 2425A never used Trying to set it up and their was no book in the box it says to run Channel Auto scan .it is hooked up to Dish satelite ant. .to run the auto...
Used the tv remote go into tv Menu goto SETUP go down Ch. enter pick CABLE and enter again.Tv now will go into auto scanning for CABLE channels.After the auto scan done for the CABLE channels are finish.After this u will able to go to channel 60 to used the dish remote.
Apr 24, 2011 | Curtis Televison & Video
We lost local tv from Dish on one of the local channels. We want to use the TV (model LC-46D85U) to view the local channel. How do we get the TV to view in local over the air instead of the satellite. ...
Connect air antenna to RF(coax) input of tv. Go to the menu and look for channel setup.Select antenna and auto scan. When done scanning you should have whatever stations you are able to pickup. Connect Sat reciever to one of the other input on the tv. Then go to INPUT or SOURCE on remote and select tv for local and what ever input you sat box is connected to for dish.
Mar 07, 2011 | Sharp Televison & Video
I am trying to connect an Insignia flat panel TV to my existing Dish satellite system. Dish satellite system is not HDMI. We have: cable from the wall (satellite) connected directly to the new TV (exactly...
I really need to know the model number of your Insignia TV and which connections you are using between the Dish box and the TV to give you the correct answer. If you are connecting both cable and satellite, I believe it should be set-up as follows:
1. Connect cable feed to TV
2. Run auto channel scan on "cable" setting
3. Connect Dish box to TV and then try changing the "input" selection.
With the Dish box switched on to a channel number you know, try pressing the "INPUT" or "SOURCE" button on your Insignia TV remote repeatedly until you find the satellite feed. Once you have done so, you should be able to change satellite channels using the Dish remote.
If you need further assistance, please post back with the model number of your TV and details of the connections you are using on the back of the TV.
Regards,
BElectric
Dec 29, 2010 | Televison & Video
Can only get channels 27 and 52 on sanyo 50in tv
is this TV connected to a cable box or satellite dish........if so turn the TV to channel 3, and make sure the source (also on the TV) is set to Cable not AIR... the cable wire from the box / dish is going to the TV (in)
no cable, no satellite how about an Antenna... using this format the source must be AIR and you must let the TV SCAN to lock in all the broadcast channels ... (using any other method there is no need to scan for channels you will only be using one (ch 3)
Dec 20, 2010 | Televison & Video
I am setting up my proview pa-32jk1sa, for the first time. we have dish network, but all my tv says is please scan channels. i have my coaxial plugged into hdtv, and also went to settings for hdtv and set...
chances are that your reciever is outputting conventional NTSC .. not high def ... so you would scan for standard channels not hdtv .. if chanel selection is done by the satelite reciever then the scan will only find one channel 3 or 4 usually (or better yet you can use Svideo or component oututs if it has them .... if the receiver is a block converter that uses the tv to tune channels then you should get more channels detected ..
Jun 24, 2010 | Proview PA-32JK1A 32 in. LCD Television
I only get 12 channels. . .why?
Download the user's guide and go to page # 19 for more info on how to set up the TV to the proper input to receive all the channels.
Let me know if you need further assistance.
Jun 12, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Unable to pick up local ''free'' channels following digital change over. Using RCA DTA800 converter and Phillips 2750/27 antenna. Can pick up only one local channel, but signal loss is more often the...
first of all, make sure all your connections are secure and threaded all the way in. Next, go to the main menu and press 5 (configuration) and press 1 (search for channels) if this doesn't work, press 4(signal strength meter) and see how strong your signal is. You may just need to re-position your antennae. If all else fails try system reset(number 5) and repeat search for channels. I've had similiar experiences with mine but I have a 62% signal strength and still get 20-something channels. Hope this helps.
Oct 11, 2009 | Televison & Video
Have Direct TV using a Sony Digital Satellite receiver model #SAT B2-2 /Sony Satellite dish purchased in 7/97. I get local channels thru Direct TV. Recently, local channels will show on the Direct TV guide...
Your dish is out of alignment. The local channel satellite doesn't have as strong of a signal, so a slight misalignment will cause problems.
It could also be an F-connector needs to be replaced at the dish or multiswitch (if you have one). Sometimes moisture builds up inside the connector and corrodes the copper stinger inside.
If you go into your satellite signal strength menu and find the local channel satellite, you're sure to see either a weak signal or an intermittent one.
One more thing, if a tree has grown in the line of sight between the dish and the satellite, this will cause signal problems too. In this case, you either have to trim the tree or move the dish.
Hope this helps!
P.S.
The customer service reps at DirecTV usually idiots reading from a script with no real field experience.
Mar 25, 2009 | Televison & Video
No local channels
your locals may be broadcasted on a a different satellite (directv uses 7 different ones). when u travel, your dish on your rv might be capable of receiving the satellite that broadcasts normal programming. the dish on your home may look a little different and picks up more than one of the satellite signals. also these satellites are in different locations
Oct 23, 2008 | Philips DIRECTV H20 DTV Receiver
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
