Question about Lexmark X5150 All-In-One InkJet Printer
I HAE TRIED TO INSTALL A NEW COLOUR CARTRIDGE BUT A MESSAGE COME UP NO COLOUR CARTRIDGE WEN I PUT THE OLD ONE BACK IN IT SHOWS IT'S EMPTY?
SOURCE: Inputting new ink cartridges
dear sir pleaz make do the cartridge alinment prorame after installing the new cartridge or your cartridges are not original
Posted on Sep 21, 2007
SOURCE: Lexmart x4580 all in one printer
try disabling your internet security while connecting. jock67
Posted on Jan 05, 2008
Ajkill
  • 2035 Answers
SOURCE: Cartridge problems with the P915 Lexmark printer.
First check they compact able once, refilled cart are recognizied
by printer,,,,
Cleaning the contacts on the cartridge carrier
Step Action
1 Power the printer/All-In-One off and unplug the power cable from the outlet.
2 Open the printer/All-In-One lid so that the cartridge carrier can be accessed.
3 Gently move the cartridge carrier into a position where cartridges can be removed.
4 Remove the print cartridges. (For information on cleaning the cartridge contacts, click here.)
5 Using a dry, clean cloth wipe the carrier contacts gently from top to bottom.
6 Repeat Step 5 for the other cartridge slot (if applicable).
7 Reinsert the cartridges, slide the cartridge carrier to its original position, and close the printer/All-In-One lid.
8 Plug the printer/All-In-One back into the power outlet and power it back on.
If your cartridges are not being detected when they are snapped in, do the following:
Open the cover of the printer and unsnap both cartridges.
Snap them back in after a few seconds. Close the cover.
Repeat these steps (1-2) three or more times in succession. You will be prompted to go through the menu on the printer display to finish the process. Follow the instructions displayed.
If your printer is posting a LOW INK LEVEL or CHANGE CARTRIDGE error, snap the cartridges in and out as directed above (steps 1-3). When you close the front cover, you should see the message Cartridge Change - NEW on the display.
Press Select to indicate that you have just installed a new cartridge.
Posted on Mar 16, 2008
SOURCE: Print Cartridge Missing
had cartridge refilled put back but comes up no cartridge
Posted on Mar 23, 2009
  • 744 Answers
SOURCE: refilling cartridges
Joe,
You should have received control program software with your printer. If installed, the icon should be on your desktop or it may be in your programs list. You can also get the software from the Lexmark web site.
Anyway, you probably need to reset the cartridge using the control program. It's not difficult. Just follow the prompts.
Posted on May 16, 2009
Selphy cp780 continues to say ink cartridge empty even after installing new one. Tried 2 new ones to be certain it wasn't the cartridge, same thing...tells me ink cartridge empty install new.
try and reset your printer,unplug the power cord and wait 10 min, then plug back in,understand that Canon has installed a chip so you cannot use refilled cartridges,or cartridges you refill,if this doesn't work,then contact Canon,and you could get the same message I got take it in to be repaired, (to costly), so I end up buying a new one,,
Oct 10, 2012 | Canon SELPHY CP780 COMPACT PHOTO...
I put in a new cartridge (56) and now my alingment
after replacing the cairtage printer needs alignment it gives a test page when we put it face down on scannes it starts the alignment...
on alignment process it doesn;t found the colour bands so it shows the alignment failure..........
pls install the new colour cairtge the it will give u the printout
thanks....
Jul 08, 2010 | HP PSC 2210 All-In-One InkJet Printer
I use to refill my brother dcp-130c printer cartridge.but now it shows black cartridge empty also colour cartridges near empty..after I purchace new black cartridge also same messahe appears..pls help me...
the electronic on your printer, the one that detects the black cartridge might be dirty, try cleaning it with some tissue. if that doesn't work, try removing the installation of your printer and then install it back again. if you have any other black cartridge, put it in the printer and try printing. If a page comes out, even if it's blank, then it's the black cartridge that has an issue. try that and let me know.
Mar 03, 2010 | Brother DCP 130C All-In-One InkJet Printer
Installed a new Lexmark ink cart and got an incorrect message
take out the cartridge , turn off your printer and take out all the cables behind your printer and wait for 5 minutes and put everything back in.. if the same error shows.. im sorry but your printer needs to be replaced.
Aug 15, 2009 | Lexmark X2500 All-In-One InkJet Printer
Problem with replacing color ink cart. #5
Is it the right Cartridge you are trying to install please check and then check if the sensors are working.
Mar 31, 2009 | Lexmark X2600 InkJet Printer
Can't Print with black ink because all color ink are empty.
yes you need to install all cartridge before printing any page ...I have also this model...but u need to install all 4 cartdge. before printing any page wheather color or blacknwhite..
Jan 08, 2009 | Office Equipment & Supplies
Epson stylus photo 1290 'bk ink cartridge not installed properly'
Ameter:
Remove the black ink cartridge.
Check the place where the new cartridge should go. Check for a round small piece like a bushing or a little piece of pipe, stuck at the ink entrance of the printing head. This is a piece from the old cartridge, that sometimes gets loose and remains in place,and when the new one is placed, it doesnot go down to the right place to make contact with the electric connectors in the printing head.
If nothing solves...reinstall the printer drivers.
Good luck and Merry Christmas
Emiliosan
Dec 09, 2008 | Epson Stylus Photo 1290 InkJet Printer
Brother DCP-115C Printer: "No Ink" message continues even after old ink cartridge (still some ink!) is replaced with a new one.
Reset the printer to factory settings
Turn off the printer. and turn it on again.
If still not working
Take out the cartridges, turn off the printer
Turn on the printer and put the cartridge again.
Oct 27, 2008 | Office Equipment & Supplies
Empty ink cartridge message
I replaced the old cartridge with a new one (Magenta) and it still asks me to replace it with a new cartridge.
For 1 colour which is LOW, it stopped me completely from PRINTING or COPYING at all.
Any clues how to fix this?
Jul 11, 2008 | HP Photosmart C6180 All-In-One InkJet...
Hp 1610 says remove and check color cartridge, I did everything, checked cartridge, cleaned, powered down etc. Still says check... nothing works, it's not that old either
-If you have old empty cartridge, try to put it on and see if the error get out. the cartridge has a circuit that gets bad and then the printer shows the error.
-Even if it has ink the printer will get the error.
if the message goes out after you install an old cartridge, means you need to replace the bad one.
Apr 11, 2008 | Office Equipment & Supplies
Lexmark X5150 All-In-One InkJet Printer Logo
15 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
