I have a Sanyo CLT2054 TV. Does have a digital tuner so I can receive digital signals from a DVR and Digital broadcasts? Neill Parkin
    Novelist:
    Scholar:
  • 100 Answers
Salutations nrparkin,
I hate to say there maybe some misunderstanding of the features of your television. After reading your owners manual it shows that you should only be able to pick up standard NTSC analog boradcasts not the ATSC digital broadcast standard.
Your television is a EDTV which means its an Enhanced Definition Television allowing a display of 480P. You may still need a digital converter to pick up the current and future digital broadcasts over the air.
Hope this helps.
Jon
Go Ahead. Use Us.
Posted on May 15, 2008
Will my TV receive digital signals without an external digital converter?
Hi, John.
No your tv is an older standard definition tv with an NTSC tuner..that was the old type tuner for analog stations.
You will need to get an ATSC digital tuner in order to tune in digital broadcasts.
Luckily, you don't have to spend hundreds to get one.
WalMart and several other stores carry inexpensive digital tuner converters that are in the $30-$40 range.
I hope this helps you out on getting stations picked up, as without the converter, your tv would only be good for hooking up a dvd player to it, or for video games.
Good luck tio you, and have a good day.
Jun 06, 2011 | Sanyo DS31520 31" TV
Do I need a digital converter box to recieve a digital broadcast with a Sharp LC-20SH4U TV?
Yes you need a digital converter box. Your model has an NTSC Analog Tuner. It doesn't have a Digital Tuner. This is why you need the converter box.
For example, many companies like Comcast or Time Warner or TCI etc used to broadcast Analog Signals through their wires. Now they have broadcasted only Digital Signals. This makes either your TV Obsolete as a Tuner or you have to get a digital converter so your Analog TV can receive the signal.
Depending on your service, it may be worth your while to get a TV with a digital Tuner.
Then again, it also depends on if you are connecting a box receiver to your TV. For example, if you have Directv or Dish, you would then use your standard Video/Audio or Composite Cables to transmit your signal OR your Out to TV Coaxial whichever works for your receiver. Some receivers have already built in converters . You should really consider all the factors to decide and determine it based on the type of service you have or want.
Mar 09, 2011 | Sharp LC-20SH4U 20 in. EDTV-Ready LCD...
Tv tuner will ot detect digital signal in windows media center, vista
All US TV signals are now digital, but most TV tuners are like our old TVs - analog. Are you sure your tuner is a DTV tuner? If not, you will need to replace it or get a DTV converter. A DTV converter will not let your computer pick the channel and time though.
But one footnote. Broadcast digital TV is often not the same a cable digital TV. If you get a cable digital signal it is encrypted to the actual serial number of the receiving box. No broadcast DTV converter can do this. This is how the cable company now controls the number of receivers and one has to pay for EVERY set.
Apr 23, 2010 | Sony VGC-LT16E VAIO 22" All-in-One Desktop...
I have my cable coax connected to the UHF, VHF, CATV input. If I connect cable to Digital Antenna In input and do channel search will I receive local digiatal broadcasts or do I need to split the coax to...
You need to put a compatible cable decoder box between the cable and TV as the sanyo will only decode analogue cable signals via the catv UHF vhf input
the digital antenna in is for digital air broadcasting signals only
Jul 25, 2017 | Sanyo HT27546 TV
Does anyone know if this tv is analog
the tuner on this tv will pick up the analog and the digital broadcast stations.
so yes you can get the analog stations , but you also get the digital or hd broadcast stations that are available
Mar 02, 2009 | RCA D52130 52" Rear Projection Television
Digital tv
Unless it says HDTV it is not digital.
Feb 16, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Sanyo tv model DS31520..is it an HD tv?
You can view the specifications here:
Sanyo DS31520
I found no mention of the needed ATSC digital tuner so you need to acquire a converter box to receive broadcast signals after the changeover. Cable and satellite reception are not affected.
I reviewed the available converters and chose the Zinwell ZAT-970.
Jan 14, 2009 | Sanyo DS31520 31" TV
Does the Sanyo LCD Flat panel 20" CLT2054 have a digital tuner
This model Does Not come with a digtal tuner, While being capable of HD disply it does not decode digtal signals. Lots of people are confused with the difference, HDTV vs Digtal
Dec 23, 2008 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Digital or not digital
this tv has no digital tuner built in to it. In order to recieve a digital broadcast the tuner must be atsc compliant. The best solution is to get a converter box to decode digital to analog signal.
Apr 03, 2008 | Televison & Video
Digital Television
You will need to use a converter box if you want to receive digital signals from an antenna as the tuner is not the ASTC (HDTV) type. Once you get a converter or cable box you can come out of it with component video cables and go into one of the inputs in the back of the set.
Feb 26, 2008 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
