Question about Miele CVA615 Espresso Machine
I have a Miele Coffee Machine (built-in) CVA 620-1. I got a message saying the brewing unit is blocked. I removed the waste unit, a procedure that has to be done before you can remove the brewing unit. Then I closed the machine and this time I got another message "Brew Unit Missing" and when I tried to remove the brewing unit it is stuck! as if it is glued to the unit. Not moving at all in any way. Please help!!!!!!
The brew unit has lose parts on left-hand-side, wiggle them up and down. Put the waste unit back, switch off the machine and then turn it on (pull the cord). It worked for me!!!
Posted on Mar 15, 2011
Brew unit stuck
Hi molly girl.
You can try to clean your Brewunit. Most of the times when that message appears, it means the brewunit is dirty
You can have more info in the manual if you dont have it:
http://www.miele.co.uk/Resources/OperatingInstructions/CVA%20620.pdf
Jan 11, 2008 | Miele CVA615 Espresso Machine
I have a built-in. There is no water coming out. Could it be the brew unit itself?
About 428,000 results (0.82 seconds) Search Results
    [PDF]Operating and Installation Instructions Coffee System - Miele
    mieleusa.com/MieleMedia/.../Coffee%20Machines/CVA6405_Coffee%2...
    Preparing multiple cups of coffee, one directly after another (coffee pot) . . . . . . 23 .....safety requirement be met. If there is any doubt, have the electrical system of ...ventilation around the coffee machine. .... nDrip tray with no-spill grid .... and out. ? Remove the lid and fill the container with fresh, cold tap water to the. "Max.
    [PDF]Operating And Installation Instructions - Miele
    www.mieleusa.com/manuals_pdf/Residential/Coffee.../CVA615_us.pdf
    Read all instructions before installation or use of the coffee system. ... there is any doubt, have the electrical system of ... The appliance must be built into cabinetry before operation to ensure that no electrical components ... towards your body or use this machine ..... Lift the water tank up and out of the ..... nothing comes out.
    Miele Products: Coffee Machines
    www.mieleusa.com/Product/List/21?filterByType=false
    24" CVA 2662 Built-In Nespresso Coffee Machine. Add to Compare Details ... 24" CVA 4066 ss Built-In Coffee Machine, with Plumbed-In Water Connection.
    Miele CVA4066SS 24 Built-in Whole Coffee Bean System ...
    www.amazon.com/Miele...Built...In.../B0025TLW6A
    Amazon.com, Inc.
Feb 08, 2016 | Miele Coffee Makers & Espresso Machines
Miele cva 4075 stuck brewing unit
http://mielerepaircenter.com/miele-coffee-maker-repair
Sep 07, 2014 | Miele CVA4070 Coffee Maker
I have miele CVA 4070 It just recently started only brewing about 1/2 to 2/3 cup of coffee or espresso and the rest of it goes into the waste container. So the waste container has a watery puck and...
Have you clean the brew unit with the cleaning tablets? This dissolves and rids the brew unit of the oils which in turn build up and clog the brew unit - the result being watery pucks and less product being disbursed.
Feb 21, 2014 | Miele Coffee System
Miele CVA 4075 brew unit locked
Turn your machine off. Close the door. Depress <clear>, holding it down, press <on/off> then let go of both. Then press <clear> 3 times. On 3rd time, hold it until Service menu appears. Select <brew unit> then press left arrow to turn from <off> to <on>. Then press right arrow by <select> This will turn your brew unit drive to the correct position and you should be able to get your brew unit in/out and your waste container back in. Make sure to turn your machine off/on again to get out of Service Menu. I have a picture of how the wire needs to be inserted to get that back on. It's definitely not intuitive, but send another note with your email address and I can send the pics.
Apr 13, 2010 | Miele CVA4070 Coffee Maker
Display message - brewunit block - can not undo to start the machine Miele CVA 620 Build-in Automatic coffee machine
YOu must turn the machine off...hold both the small coffee and hot water button...tunr the machine on to light...let go of the buttons..then hold in the large coffee button for a few secinds andletgo ..if that doesn't work hold in the medium coffee button for a few seconds and letgo..that shouldreset the brew unit.
good luck
Jan 13, 2010 | Miele CVA615 Espresso Machine
Miele Coffee maker cva 615 coffee will not come out
The screens that the coffee grinds are squeezed in between are clogged. You need to remove the brew unit, remove the bottom screen, (should be one phillips screw in the center) and scrub the screens clean. You need to clean all of the really fine holes out so that the water can pass through. To prevent this in the future, use the rinse cycle on the machine frequently and also take the brew unit out and rinse it under hot water everytime you dump your waste unit.
May 05, 2008 | Miele CVA615 Espresso Machine
Miele coffee maker cva 4070
OK. Here's the deal. I struggled with this CVA 4070 (F 73) problem also recently, and even posted a questions in the cyber world about it. I jiggled, re-cleaned the machine, re-read the Miele manual, and scoured the internet for schematic drawings of this brewing unit's insides. No luck. Finally after finding out I'd have to pay $199 just for a service clown to walk in my front door, I said NYET!!!  I must solve by myself. If I can take apart & fix my Dyson, etc, etc, I WILL DO THIS TOO!!  (MUST HAVE COFFEE>>>)
Pull out the brewer, turn it a quarter-turn to your right, and look at the spot where that small black plastic piece -- shaped like a block "M" or block "W" -- should be situated. Pull it out, if it isn't out already. Don't worry about yanking it out or harming these parts, said the Miele troubleshooter guy in New Jersey on the phone. They're "made from the same plastic used in football helmets."  Okey-dokey.
This approx. 1.5" wide, blocky plastic piece is part of the "slide" that takes the brewed coffee grounds into the waste container. When positioned correctly, it looks like a block "W,"  with the "wings" ointing up, and slides in just under a brown 1.5" flat piece. A small, down-facing tab on the brown piece clicks into the "W" piece and holds it in place. The "W" should feel fairly solid, although it is not rigidly in place, as the entire mechanism is a movable system to deposit the grounds in the waste receptacle.
Put everything back inside your CVA 4070 "love" machine, hit "on," and wait for it to go through its warm-up.  No F73 message?  Yeah!  Mission Accomplished. You, like I, have fixed your Miele, saved your family relationships, and saved yourself a bundle from unnecessary service calls.
Feb 27, 2008 | Miele CVA4070 Coffee Maker
Miele CVA615 Espresso Machine Logo
1,144 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Colin Stickland
Colin Stickland
steve morris
steve morris
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
