Question about Intel Motherboard
GX-Ronald Hoop Converter
I am only getting 4 hoops/second, when I was told the average the GX-Ronald is capable of is 9. What am I doing wrong?
  • Anonymous May 17, 2008
    Yeah, I have the same problem- a problem with your FACE.
  • 183 Answers
Cause in same model some brand like GX have differnt renovated models had launched.
so your's are quit older than new launched board,
so its not a major prob,
enjoy with this model ,or if your need its greater,
than buy new 1 with replacing this.
you will also get as you want.
Posted on May 16, 2008
When trying to embroider on my husqvarna Designer 2 machine, I keep getting the message wrong hoop. I've tried repeatedly to start again, but keep getting the message. What's wrong?
Possibly the hoop is just a tad too small for your design. The hoop needs a certain degree around the edge to move the presser foot. For instance, a hoop that is 5"x7" can only take a design that is perhaps 4.5"x6.5".
Perhaps your machine is not correctly recognizing the hoop.
Apr 18, 2017 | Sewing Machines
When I install embroidery hoop light keeps blinking n saying wrong hoop size looked it up n it's saying malfunction
Ok, there are a couple of possibilities, and I'm going to include an image. I"m not sure whether you're trying to use the small or large hoop, but the first thing you should try is turn off the machine, take the hoop off entirely, then turn on the machine without anything and let it reset to its default position, which will be the center. If it has a problem there, make sure the needle it at its highest position.
Next, put the large hoop on, bring up a design, (preferably a design that came with your machine--there are sample designs in the \Library directory where the program is--that's generally in c:\program files\futuraquartet--and is designed for the hoop you're trying to use, and transmit to machine. If it tells you the hoop is the wrong size, download a patch from If it STILL tells you you have the wrong size, reseat your USB cable into the machine and tape it in place with masking or duct tape.
The third possibility--and the one pictured in the photo I'm going to attach--is there is a tab on your hoop which indicates the hoop size, and your TAB may be off. It needs to be dead center of the sensor, which is also pictured. A while ago a BUNCH of hoops were manufactured with the tabs slightly off, and if it's off, your machine can't read the size. What generally happens there, though, is it will indicate that there is NO hoop attached, rather than the wrong size.
You can see the sensors--they're inside the arm where you put your hoop, and they're not covered up. Below it are the large hoop (top), and small hoop (bottom). The hoop tabs have to match up to the sensors exactly, and you'll be able to see if it doesn't by matching up the notch in the hoop that matches the catch in the embroidery arm.
Oct 20, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
My mega hoop is on, but the screen keeps telling me the color block is not allowed on both sides how do I get it to go???
I have a Designer Diamond, and I experienced the same error message of "color block not allowed on both sides of hoop". I was trying to resume my project a day later, and received this message when I attached the hoop. I made several attempts to fix this problem and get rid of the error message to no avail. Finally I just checked the hoop size on the screen of the machine and noticed it was showing the wrong size hoop attached! I picked the correct size for the hoop I had attached, and viola! - message gone! and I was able to continue on with my project!
Jan 16, 2014 | Husqvarna Designer I
How do i calibrate the hoops on a baby lock emp6
This is a translation of instruction from the Service Manual for the Brother PR600, the twin of the Babylock EMP6. I will testify this works because I just did it to stop the insanity of my EMP6 thinking everything was a 5x7 hoop. If you look on page 4-36 of the free PR620 manual you will find the same exact set of instructions that are in the PR600 manual. So here are the exact steps to augment the manual's instructions.
1. Turn off the machine.
2. Press all three buttons (start, threader and cutter) and keep them pressed while turning the machine on.
4. Press A/D TEST.
5. Put the largest hoop on the machine (7 7/8 x 11 3/4).
6. Press LL.
7. Put the smallest hoop on the machine (1 1/2 x 2 3/8).
8. Press S.
9. Take the smallest hoop off the machine.
10 Slide the arm to where the knob on the arm is when the large hoop is on the machine.
11 The reading on the screen should be very close to the value that is in the LL setting.
12 If not, go through the large hoop steps (5-6) again.
13 Slide the arm to where the knob on the arm is when the smallest hoop is on the machine.
14 The reading on the screen should be very close to the value that is in the S setting.
15 If not, go through the smallest hoop steps (7-8) again.
16 Press close when you have both settings close. They need not be identical but they do need to be no further than 200 away from the screen value.
17 Turn the machine off.
18 Turn the machine back on, load a file, and see if you have the same results that I had; it will show the proper hoops when you press the hoop symbol and it will also center itself in the hoop properly.
You can buy the PR600 service manual online for about $12. However, you have the 620 manual for free and there is really very little difference. I have found the manual invaluable in saving me trips to the shop and doing my own repairs.
Aug 26, 2013 | Baby Lock Sewing Machines
Can i do a large applique with my pfaff 7570 using the large hoop
Both the 7560 and the 7570 will only stitch out to the largest hoop it came with which is a 120 x 115 CM hoop (approx 4 1/4 x 4 3/4 inches). If you are using the Creative Big Fantasy Hoop or a Hoop-it-All you will need to split out the design so that each piece will fit within the 120 x 115 hoop. Transfer both designs to the machine. If using the original hoop, hoop your fafabric and stitch out the 1st design. Unhoop and rehoop again aligning the fabric with the hash marks on the hoop. You will have to move the design around on the screen to make a perfect fit. Stitch out the 2nd design. If you are using the Creative Big Fantasy hoop, you just have to hoop the fabric once, stitch out the 1st design and loosen the side screw on the hoop and slide the hoop into place for the 2nd design. Stitch out the 2nd design. The same process applied to the Hoop-it-All.
Feb 28, 2013 | PfaFF Creative 7570
I have a Do All Quilter's Hoop which I can't use
I'm a bit amazed that a Husqvarna technician was unable to do the minor adjustment to the embroidery arm - he needs to contact Husqvarna headquarters and ask for instructions. Meantime, you can still use your hoop (which by the way is my favourite hoop - it's a little beauty!). Tell your machine you are going to use the Large Hoop (6" x 9.5" or 150mm x 240mm) even though you are really using the 6" x 6" or 150mm x 150mm Do It All Hoop. Provided you have centred your design before loading it on your USb stick or floppy drive, it should work. However, just to reassure yourself, use the Check Size button on your touch screen to test the outside size of the embroidery and be sure it is not going to foul on the hoop borders. (It is the one on the second screen (press More to access this) once your have loaded your design - looks like little double arrows pointing to the corners of a square. Each time you press this button, the needle will zoom to each outer corner of your design in turn.
Jul 10, 2010 | Husqvarna Designer I
My Singer Futura keeps telling me that I have installed the small hoop and need to change it to the large hoop...but I have actually installed the large hoop. It is giving me an incorrect error message. I...
Make sure you have the latest software version. Current version you may check in About dialog under Help submenu and in the same submenu you wil find a function Live Update.
Also make sure you switch on the sewing machine either with the large hoop connected or without hoop. If sewing machine was switched on with the small hoop attached, it will provide this error message about wrong hoop.
Jan 30, 2010 | Singer CE-200 Quantum Futura Computerized...
How do you use the Plus Hoop on a Husqvarna Viking "Rose" Sewing Machine?
The plus hoop is a multi positional hoop that allows you you to embroider designs up to 4" x 6". It is essential for monogramming and lettering using your Rose. The Rose hooping system is the same as the 1+, the Scandinavia 300 and 400.
The designs you use must be formatted for the plus hoop. That is, the design has already been divided into two or three elements. Each element is an individual design. For instance, say the design is a long stemmed rose. It would probably be divided something like this: design 1: the flower and the top part of the stem, design 2: The middle part of the stem and the leaves, design 3: the bottom part of the stem.
You would hoop up your fabric to be embroidered, attach the hoop to the machine, set the hoop to position 1, select design 1, stitch out design 1, set the hoop to position 2, select design 2, stitch out design 2, set the hoop to position 3, select design 3, stitch out design 3. You should have a complete design when you're done and everything should match up perfectly!
The hoop is divided up into three squares, 4" x 4". Position 1 square overlaps position 2 square and position 2 square overlaps position 3 square. This overlapping allows the designs to stitch out more smoothly.
I hope this helps. Let me know if you have further questions. Carrie
Aug 27, 2008 | Husqvarna Rose
Intel Motherboard Logo
67 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
