Question about Sanyo DP32746 32 in. LCD Television
I have a 32 inch LCD TV from Sanyo. There is no display and there is a smoke behind the TV. The guy who came to fix the issue told me that the entire PCB is to be changed. Is this true? If yes, how much it costs including service charges. I purchased it 1 year and 8 months before. Please advice.
    Brigadier General:
  • 3,006 Answers
Your repairer is likely to be entirely correct, without examining the tv directly it's impossible for anyone on FixYa to say he's wrong. Although the circuit board might be repairable, the extra time involved in tracing and fixing the fault will often be higher than any savings made by fixing the part. A repaired pcb with heat damage is also far more likely to cause additional problems in the near future which may not be presently evident, so the prospect of a further call-out for unpaid remedial work means that most repairers will not be interested in repairing the pcb.
Repair costs depend entirely upon local labour rates, taxes, and parts costs, and as you haven't said which country you're in it's impossible to give an opinion. Replacing the board should take under an hour, but many repairers will often clearly state that their minimum charge is for one hour and then charge for additional time in complete half hour units. Expect the total repair cost to be a little in excess of around 50% of the cost of a replacement tv. If it's lower than that then count it as a bonus.
Posted on Sep 14, 2010
How Fix white horizontal lines on LCD display
you have the same problem I have . We have a bad circuit board that is doing it . The repair guy told me to hit around the edge of the screen and it cleared up . We have to do this everytime we start the 46 inch Sanyo tv / monitor . once it heats up it is fine . We got this form walmart and started a week after we got it . The repair guy said it would cost almost as much as a new monitor/TV ; to repair this one . So we have been doing it for 4 years now .
Aug 11, 2014 | AOC LM729 17" LCD Monitor
My tv is a 42 inch lcd sanyo the left side started having vertical lines andn then fuzz when turned on then it slowly started staying that way and going farther across screen if you move the tv around it...
Its probably a bad ribbon cable on that side of the tv. if u put pressure on that side ( on the plastic) it may resovle the issue. otherwise it could be a bad tcon board and the tcon board would need to be replaced.
Dec 15, 2013 | Sanyo DP32746 32 in. LCD Television
Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
I have a 47 inch sanyo lcd tv and the screen is broken in the lower right hand corner i want to know how much it will cost to fix and i dont want it will be cheaper to buy a new one
i have a 47" inch lcd sanyo t.v. and my kids accidentally shot it with an air-soft gun. and there is a crack where the pellet hit and there is also a crack running down that spot. Also the screen has these lines running up and down the screen. Different colors. and i was wondering if it was possible to fix.
Jun 02, 2010 | Sanyo DP32746 32 in. LCD Television
Is there a way to fix my sanyo 32in cracked screen #DP32648
You can have them repaired using a TV Repair guy but often it costs as much as a brand new LCD. My daughter broke my $1,600 LCD. It would have cost $1,200 to fix.. so I just bought a new one.After that I picked up a TV screen protector called TV Armor http://www.tv-armor.com Its designed to protect the TV from damage. Now I dont have to worry anymore when she is playing near it. It works really well.
Eric
Jan 02, 2010 | Sanyo DP32648 32 in. LCD TV
My mom has 32 inch Sanyo vizio tv, er32647, she bought less than a year ago and now ion the lower left hand cirner there is a pink line that goes up the , about an inch long muy husband said it was a pixel...
Hello williskathy2,
This might be a problem with the circuitry of the screen driver. what happens is the one of the drivers in the display matrix IC goes bad and it can not fire that one string of LCD elements, and this creates the line that you see. Since the line is pink, I would say that the driver is incorrectly firing the string of LCD elements. I would suggest that if you have a background in electronics you check the voltage levels on the display driver IC and the connection to the screen. If you do not have a background in electronics I would suggest that you have a qualified TV technician fix your problem.
I hope this helps,
Shuttle83
www.electron-age-technologies-llc.com
Nov 28, 2008 | Sanyo DP32746 32 in. LCD Television
Our 32 inch lcd sayno tv
Hello All,
I posted this earlier, however it applies here as well:
I hope this helps,
Shuttle83
Oct 30, 2008 | Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 32 in. LCD Television Logo
95 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
