Question about 3Com Computers & Internet
I 've encounter problem in programing chamfer in mazatrol programming alarm is chamferring tool interference what should i do? can u help me?
3 Suggested Answers
efs_perpends
  • 1996 Answers
SOURCE: Cutting chamfer on oak wood
One way to do it is to use a table saw, with the blade cranked over at an angle, feeding the piece through upright, with the flat against the fence instead of down against the table surface. You can make a very shallow angled cut in this way, and it's accuracy is improved through the use of fingerboards to hold the work against the fence.
If you have a router table with a fence on it, you can set up a panel raising bit and do a fairly shallow cut on the edge of your threshold, but probably not as deep (from the edge) as on a table saw. (Probably only about 1 1/2" vs up to 3").
The most laborious method, but fairly simple, is to make some kind of sled-like jig for the router that will span the width x2 of your board, then mount the board on a large flat surface at the desired angle, and use a flat bottomed bit to essentially plane the board by hand, sliding the router back and forth from end to end, moving it over to make the next pass, and so forth. Slow & dusty, but effective nevertheless.
Here's a link I found with pictures of something like what I was thinking of. Router planing jig
Whichever method you choose, expect to have to dress the cuts with a belt sander to smooth out the machine marks.
If what you're after is a simple 45 degree chamfer, just buy a chamfer bit with a bearing, and if you wish to take more cut than the thickness of your workpiece allows, screw another board flush to the edge underneath to guide the bearing against while you make your cut.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 08, 2009
rowdy45176
  • 2176 Answers
SOURCE: Paslode cordless nail gun which way does the
chamfer side goes towards the nails/magazine
Posted on Aug 18, 2009
How to get a dial tone on AEG Chamfer 215-2?
If it was a lightning strike and had a power surge that toasted it you could contact your utility company about a claim.
Oct 28, 2014 | Lands Phones
How dow i unlock an aeg chamfer 210 cordless phone
DOWNLOADS VOXTEL D210 COMBO MANUAL
If this is not what you have, please provide a complete serial number, so that the best answer to your question can be provided.
Jun 21, 2014 | Uniden Cordless Phone
I sim card sgh a561 insert
Yes, if you look at the SIM slot in the cell phone you will notice the chamfer.
May 02, 2013 | Samsung SGH-A877 Impression Cell Phone
Where are the freeze plugs located on 1994 Ford Taurus?
For the vehicles covered by this information, one of two types of freeze plugs may be used: a cup-type plug or an expansion-type plug. They are removed in the same way, however two different kinds of tools are used to install them. REMOVAL & INSTALLATION
  1. Disconnect the negative battery cable. Drain the cooling system.
  2. Remove the necessary components to gain access to the freeze plug.
  3. As required, raise and support the vehicle safely.
  4. Drill a 1 / 2 in. (12.7mm) hole in the center of the plug, then remove the plug using a Universal Impact Slide Hammer T59L-100-B or equivalent. Inspect the plug bore for damage that might interfere with the proper sealing of the plug. If the bore is damaged, you will have to bore the surface to accommodate the next specified oversize plug.
Oversize plugs are identified by the "OS'' stamped in the flat on the cup side of the plug.
To install:
  1. Lightly coat the plug and/or bore with an oil resistant Stud and Bearing Mount E0AZ-19554-BA or Threadlock 262 E2FZ-19554-B or equivalent.
  2. Cup type core plugs are installed with the flanged edge outward. The maximum diameter of this plug is located at the outer edge of the flange. The flange on cup type plugs flares outward with the largest diameter at the outer sealing edge.
  3. Expansion type core plugs are installed with the flanged edge inward. The maximum diameter of this plug is located at the base of the flange with the flange flaring inward.
  4. For the cup-type plug, it is important to push or drive the plug into the machined bore by using the proper tool. Never drive the plug using a tool that contacts the crowned part of the plug. Damage to the plug and/or plug bore may result. When installed, the trailing (maximum) diameter must be below the the chamfered edge of the bore to effectively seal the plugged bore.
Fig. 1: Use the proper tool when installing a cup-type plug
  1. For the expansion-type plug, it is important to pull the plug into the machined bore by using a properly designed tool. Never drive the plug into the bore using a tool that contacts the flange. Leakage and/or plug blowout will result. the flanged (trailing) edge must be below the chamfered edge of the bore to effectively seal the plugged bore.
Fig. 2: Use the proper installation tool when installing an expansion-type plug
  1. Install all the removed components. Lower the vehicle, as required.
  2. Fill the cooling system and check for leaks.
Hope helps.
Jan 09, 2011 | 1994 Ford Taurus
The starter gear is worn. can i turn the gear over and use the other side?
No the starter gear is chamfered, so as to allow smoother entry into the ring gear. If you are going through the effort to remove the starter and retainer and spring, why not just replace the 3 dollar gear? Note the possition of the spring before you remove the gear.
Hope this helps, Matt
Dec 31, 2010 | Briggs & Stratton Briggs Stratton Intek V...
When i lock the disc in with the wrench as tight as i can the disc still seems to spin freely, its a thin disc for metal that came with is this meant to happen and will it happen with all discs or just the...
Well, I would make sure your arbor flanges are installed correctly. If you arent sure, I would make sure that the one with the chamfer goes on first, with the chamfer facing the tool (see picture 1). Put your disc on, and then install the locking flange (picture 2). If the disc isnt tight, flip the locking flange upside down and see if it gets tight. It is entirely possible that the disc is too thin, or the ID of the disc is too large. Let me know how this goes.
Nov 24, 2010 | Dewalt DC410KB Heavy - Duty 4 - 1/2" 18...
How to put sim card in nokia 1661 phone.
On the majority of mobile phones the SIM card slot is located under the battery. Remove the back cover and the battery to reveal the SIM slot. The SIM card has a chamfered corner and this must be placed into the slot to match the chamfer.
Jan 13, 2010 | Nokia 1661 Cell Phone
Apr 05, 2009 | Tools & Hardware - Others
Removed brushes and reinserted and motor won't work
It does. They should only go in one way, though. They have a chamfered edge and if you look in the hole, they it is similarly chamfered so they can only go in one way.
Feb 09, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Computers & Internet Logo
55 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
