Question about Sharp Office Equipment & Supplies
Display alternating between L and 1. Not copying and now not working at all.
  • 1,110 Answers
What model of Sharp copier?
Posted on Sep 14, 2010
Intel g41wv mother board ram slot problem for solution
1.) check with alternate Monitor
2.) Check with alternate power supply
3.) Check with Alternate Video Graphics Card
4.) Check with Alternate Processor
5.) Check with Alternate motherboard
6.) Check with alternate RAM
Feb 28, 2013 | Intel Computers & Internet
#324 chak printer alram cameing
when you power on your fax machine and display show DATA ERROR its mean that 3 volts battery on the main board expired and lose all data fax number, logo and related with cartridge ink data so first of all you replace the battery. (this is a pure technical job and if your are not a technician you must take help of a technician)
After replacement of battery you power on fax machine and press
function key display show DATA REGISTRATION
press # display show #1SSSW
press left arrow key one time display show TEST MODE
press start/copy key display show TEST MODE [1]-[8]
press # display show AMI MODE
Press 7 display show FACULTY 1-6
press 5 display show INK CHECK 1-2
press 2 and start key
display show INK=YES and INS (ink level any one within 100 for example 42/205 you just remember first two digit of lest side)
press stop display show FACULTY 1-6
press 6 display show LOST INK CHECK
press start/copy key display show LOST INK CHECK [1]-[2]
press 2 display show SET LOST CNT
press start/copy key display show LOST INK= (here you enter the last left side two digit which you remember for example 42)
press stop two times
and unplug fax and plug again now your fax machine is okkkkk
NOTE:- If you can't get the success first time you must try until you get the success because this is the only way to get success
Jun 11, 2012 | Canon FAX-L250
How to do BACKUP
  1. Open Contacts application.
  2. Select Options > Settings > Contacts to display and enable SIM memory (uncheck other alternatives) > OK > Back.
  3. Select Options > Mark/Unmark > Mark (or Mark all).
  4. Select Options > Copy (or Manage > Copy).
  5. Select Options > Settings > Contacts to display and enable memories you want to use.
Jan 04, 2012 | Nokia C5 Cell Phone
Want to use HP 1040Fax machine to make copies
1. Turn the page face down and insert it into the document feeder.
2. Press Copy twice.
2. Press Copy.
Number of Copies then 01 [01-50] will display.
3. If you want more than one copy, use the phone pad to enter the number of copies.
4. Press Copy to start copying or press Start/Enter to go to the next option.
Zoom Rate then 97% will display.
Dec 05, 2011 | HP 1040 Plain Paper Inkjet Fax
Reset drum
Hi there!
To reset the drum light you need to press the following keys in sequence with 4 seconds for the initial 4 keys
Step 1: You need to press "C" then please press the far left key ( called exposure mode key) then press the "C" key then the far left key once again.
So the sequence is -- C, far left, C, far left.
Note: Some model utilize two other initial codes, you might need to use one of those two alternate codes to get your display to go blank. The remainder of the procedure is absolutely the same.
The alternate codes are as follows: #, * , C, * or pound key ,star key, C, star key and also #, Interrupt key, C, Interrupt key.
If done correctly the display will go blank.
Then type in 24 as if you are going to print 24 copies of something.
Then press the "print" button.
Then type in 7 as if you are making 7 copies
Now press the print button once again.
You will now get flashing zero's on the display of the unit.
Turn the machine off and then on again and your drum light will be gone.
Sep 06, 2010 | Sharp AL-1651CS All-In-One Laser Printer
The At&t LG phone video display is broken off of the phone. Is there a way to access the contact list without the video display. Impossible to navigate through menus on phone since display is broken...
To copy all contacts to the SIM card (so you can put it in a different phone):
Red key (to make sure you're on the home screen)
Left key (menu)
3 (Address book)
5 (Copy All Contacts)
2 (Handset to SmartChip)
1 to Keep original, 2 to Delete original (I'd keep it, just in case this doesn't work)
(Beep)
1 (Yes to confirmation)
Wait for another beep
Done.
Apr 11, 2010 | AT&T LG CU515 Cell Phone - Black
The copier displays an alternating L and 1. The
the display flashes L1 when turned on and will not make copies
Feb 12, 2010 | Sharp AL-1642CS Copier
Display ripped off phone, Copy Numbers to Sim card?
Left key (menu)
3 (Address book)
(Beep)
Done.
Oct 25, 2009 | AT&T LG CU515 Cell Phone - Black
I have an HP C4200 Printer-scanner-copier and when it tries to pull the paper in to print it says ''paper jam''. There is no paper in there that I can see.
1. Please visit the below web link
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3300218&lc=en&cc=us&dlc=en&lang=en&cc=us
2. select operating system
3. Downloa printing diagnostic utility
4. Run it and diagonize
5. Fix it and restart
If the issue still persists, then
Perform a reset of the HP All-in-One
  1. Press the On button and turn off the HP All-in-One.
  2. Unplug the power cord from the wall outlet.
  3. Unplug the power cord from the back of the HP All-in-One.
  4. Wait for 20 seconds.
  5. Plug the power cord back into the HP All-in-One.
  6. Plug the power cord into the wall outlet.
  7. if the issue still persists, then perform the below steps it should resolve your issue.
  8. 1.Power Button + Cancel Button Combo
    2.Enter special key combo 1[Scan] 3[Copy Color] 2[Copy Black]
    3.‘Support menu’ will be displayed
    4.Press the 2[Copy Black] until the display shows ‘Reset Menu’
    5.Press the 3[Copy Color] once
    6.Press the 2[Copy Black] until the display shows ‘Semi full reset’
    7. Press the 3[Copy Color] once
    8.The printer will go off and will power on by itself, else wait for 20 seconds and power on the Printer
  9. Turn on the HP All-in-One by pressing the On button.
Sep 03, 2009 | HP Photosmart C4250 Multifunction Photo...
All the lights on my HP 1350 printer are blinking and it will not print. Normally where you could put the number of copies i " E" is in thaat spot.
In addition to providing information about current tasks, the lights on the front panel can also indicate error conditions, as described in the table below:
If the On light, Check Print Cartridge light, Check Paper light, and Start Copy, Black and Start Copy, Color lights are all flashing, do the following:
1 Verify that the front-panel overlay is attached to the HPPSC.
2 Turn your HPPSC off and on by disconnecting the power cord and reconnecting.
Alternatively,
All ights blinking: An error caused the HPPSC to stop functioning.
1 Turn the HPPSC off and then on.
2 Restart your computer.
3 If the problem is not corrected, unplug the HPPSC and plug it in
again.
If the problem persists, contact HP.
Apr 26, 2009 | Office Equipment & Supplies
13 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
