Question about Samsung DMR77LHS Tall Tub Dishwasher
My Samsung DMR77LHS dishwasher has lost power completely near the end of a cycle. About an inch of water remains. I have power to the unit. I checked the 15 amp fuse in the unit - it had blown. I replaced it, but still no luck. The fuse is not blowing, but there is no power to panel. Nothing happens when you hit the power button - no lights or anything. Unit acts as if ther is no power at all. I have seen similar posts. Any thoughts?
  • Samsung Master
  • 12,061 Answers
Hi, whenever a fuse of that magnitude, or any fuse really, Blows, you should never just replace it, as to have any device, blow a fuse, trip a breaker, requires a major fault, they do NOT blow spontaneously ever. So you have had a major short circuit inside your machine, at some stage, usually this is in, the main Controller Board, most likely the bridge rectifier has gone short circuit, or a capacitor, But it could be anything even the motor?anything like this then will blow the fuse. The reason the fuse blow is to prevent a fire and explosion or both, as if an unlimited amount of current could be drawn, it would be catastrophic, so a fuse blows to disconnect the power. The Cause of this MUST be discovered before one ever attempts to replace the fuse. Luckily, it seems in this case the fault has blown an open circuit on the main Board, and this has prevented any further trouble.
Really after such an event as this one should engage the services of a professional, as anyone untrained may mis something that later on my even prove fatal. Get this unit looked at by a professional service person, ask for a 'Quote" if concerned about costings, then you can make an informed decision as to what to do.
Your support site is below,
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP06&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=DMR77LHS
Posted on Sep 14, 2010
  • Crystalctx Mar 01, 2011
    My Samsung dishwasher has blown a fuse for the third time as of today , in a span of about 1 1/2 years. I will never purchase any of their products ever again. I also had to get them to refund my money on a refrigerator after multiple problems within the first year of ownership.
I have exactly same problem as Crystalctx. As of today, it is 3 1/2 years and I have replace the fuse 6 times (3 box of two). Almost regularly - once in 6 months.
Posted on Dec 12, 2011
  • 2 more comments
  • Vlad Sep 22, 2012
    Where is this fuse? I've looked everywhere and I can't find it.. I have the model DMR77LHS/XAC bought in Canada 3 years ago. I have followed the Service manual and opened the right hand side panel but it's not there. I also opened the front the left and nothing. I then opened the door still no fuse. Where is this fuse exactly?
  • Jack H. Scholl Jan 22, 2013
    I have a DMR77LHS bought in Texas. If yours is the same as mine it is on the bottom of the machine on the right side and is most easily reached by removing the metal cover on the lower right hand side. The fuse is inside of a small black inline case which separates when you unscrew the two pieces.
  • Dennis Lee
    Dennis Lee Jun 03, 2014
    Kind of late but if you still need. The fuse is located at the left side bottom. Inside black tube. You can twist it to open.
  • Dennis Lee
    If anybody has same problem is suffering to change it often, I have extends the line and take it out of the dishwater box so that I can easily replace it without taking dishwaher out. Since then, the fuse hasn't brown out for several years.
Why will my dishwasher Electrolux model #EIDW5905JS0A, not drain completely at the end of its cycle.
Good Morning Friend,
I understand your Electrolux dishwasher, model# EIDW5905JS, will not completely drain at the end of the cycle. It is not normal for water to remain in the bottom of the tub at the end of a cycle. If water remains in the bottom of the tub at the end of a cycle, the dishwasher may not be draining properly. Please follow these troubleshooting tips:
    1)If unit is hooked up to a garbage disposal, make sure the disposer is empty.
    2)If unit is hooked up to a new food waste disposer, check to see if the "knockout" plug located inside the disposal inlet has been removed.
    3)Check to see if drain hose is kinked.
    4)Make sure cycle is complete, not in a pause.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
Jul 03, 2014 | Electrolux EIDW5905JS Dishwasher
Why does my dishwasher not drain completely at the end of its cycle.
    -Best Regards-
    WP
My Samsung DMR77LHS dishwasher has NO power showing on display board, checked electrical hookups it ok. Outlet has power. Pressed Power On/off button, no response, all lights are off...
hti had athe same problem, and the fuse fixed it. it turns on now,
you can get to the fuse casing, small tube about 1.5 inches , black, by flowing the electrical line to the, inside , or the under carriage, on the side of the bottom of the unit.
15 amp 250 volt at radio shack.
Sep 12, 2010 | Samsung DMR77LHS Tall Tub Dishwasher
No power
The main PSU is part of the control board. You may be lucky to find an aged fuse to replace, but it's more likely a power transistor that's fried.
Unplug and remove the control board to see which bit's toasted. Chances are it's cheaper to replace the control board - but check the probable cause - the motors are not short circuited.
May 02, 2010 | Samsung DMR77LHS Tall Tub Dishwasher
Samsung DMR77LHS Dishwasher has power to dishwasher, ciruit breaker is on. Lights on door will not light up, nothing will work
This does sound like a problem with the "anti-flood" device that does detect water (leak / spill) at the base of the washer. This device is a protection device that consists of a polystirene float and a micro swithch. Once a water leak od spill is detected it automatically puts the washer in pump out mode. You need to determine if a leak exists that has caused the float to trigger the micro switch and clear the water / leak. This should put the washer back to normal.
Apr 12, 2010 | Samsung DMR77LHS Tall Tub Dishwasher
GE GSD4920Z dishwasher. Problem is that it does not drain completely at the end of the cycle--about an inch of water remains. After checking for clogs, etc, we followed a troubleshooting procedure which...
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 09, 2009 | GE 24 in. GSD4920Z Built-in Dishwasher
KUDIO1IL8L6 Kithenaide dishwasher. Water remains in bottom of dishwasher about 1 inch deep afeter all cycles are complete. I have checked to see if it drains and it does twice although it seems slow to me....
You have a restriction in the return of the unit. This also leads to sanitation issues. Pull the bottom basket, remove the lower arm and using a screw driver, remove the return cover. Clean out any obstruction and reassemble. If you are still having problems, your pump may be worn to the point it will not remove all the water at the end of the cycle.
Oct 03, 2009 | KitchenAid Dishwashers
Dishwasher won't empty all the water at the end of the cycles. Part of the water is draining as I can watch it in the disposal, but about an inch remains.
Check float sensor at the front of unit and make sure it is clean and not getting stuck. Otherwise timer may not be timing out dump cylce.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Aug 25, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
Samsung DMR77LHS Tall Tub Dishwasher Logo
1,912 people viewed this question
Top Samsung Dishwashers Experts
vince
gbob59
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
