Question about Microsoft Windows XP Professional for PC
How to speed up windows 7 - Microsoft Windows XP Professional for PC
    President:
  • 2,291 Answers
U can speed up ur windows 7 in easy and one step download registry cleaner reg in out
Posted on Sep 14, 2010
Windows 7 Update
Follow this article
System Update Readiness Tool fixes Windows Update errors in Windows 8, Windows 7, Windows Vista, Windows Server 2008 R2, and Windows Server 2008 http://support.microsoft.com/kb/947821
Jan 13, 2013 | Lenovo Computers & Internet
Tip
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy...
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy Tips
If you fail to boot the operating system, you can:
#1. Use Windows startup Disk to fix Windows 7 startup problem
If the failure of booting is result from the errors or the damaged files of starting system, a start up disk will help to solve this problem with ease.
#2. Use last know Good Configuration to fix Windows 7 startup problem
It is also a common method to enter the operating system. To use last know Good Configuration you can press F8 when you reboot the system. Then select "Last know Good Configuration" on the Advanced Boot Options screen to enter this mode.
#3. Use System Restore option in safe mode to fix Windows 7 startup problem
Enter the safe mode as the step in to last know Good Configuration in method #2. Choose System Restore option in System Tool in start menu.
If you find the startup process of Windows 7 very slow, we suggest that you should:
#1. Remove redundant programs in your booting items as many as possible. After finishing this action, the speed of startup can be improved by no less than 40%.
#2. Delete short cuts on desktop. The more icons on the desktop, the longer it takes to restart Windows 7. To fix Windows 7 startup problem, you should clear up the unnecessary short cuts on your computer desktop.
#3. Optimize registry regularly with proper registry maintenance tool. Registry error is the main reason that slows down the rebooting speed. You had better do registry cleanup timely to speed up Windows 7 start up process.
on Jan 12, 2010 | Computers & Internet
Tip
Top 7 Tips for Windows 7 Maintenance
Want to keep your Windows 7 running as fast and stable as new? Updating hardware configuration and protecting your PC from being attacked by virus and spyware is indispensible, but, that’s not enough, even with the "impressive/promising" Windows 7.
Well, there is no rose without a thorn. For enjoying the non-compromised features of Windows 7 and keeping its freshness as long as possible, you can take the following top 9 tips for Windows 7 maintenance, and save your time, money as well as get full control of your PC!
Windows 7 Maintenance Tip 1: Cleanup hard disk
Windows temporary files, internet cache, cookies, invalid shortcuts and unused files and programs can take up much room on your hard disks. Even you have just upgraded to Windows 7, those junk files can soon accumulate and eat up hard disk space. So regular disk cleanup should be part of your Windows 7 maintenance routine.
Windows 7, as its predecessors, has a built-in Disk Cleanup program, you can find it in Start>Accessaries>System Tools>Disk Cleanup.
Windows 7 Maintenance Tip 2: Defrag hard disk
Your hard drive can be full of fragmentation with time, which dramatically slows down Windows running. Microsoft OS including Windows 7 provides the built-in Disk Defragmenter tool, which lets you remove empty patches, pack pieces of files together, and thus occupy contiguous storage locations, increase the speed of reading and writing files to/from hard disk.
Frequency: Disk defragmentation should be performed every two or three months, because frequent disk defragmentation can decrease the span of hard disk.
Windows 7 Maintenance Tip 3: Speed up Windows 7 boot
Open Run, input “msconfig”, then select “Boot”, you will see a list of programs in that auto-start folder. You can manage them there.
Windows 7 Maintenance Tip 4: Scan and repair registry
Registry is the central database of Windows which stores the necessary information and settings for software and hardware running smoothly. Even you have uninstalled a program, respective information is saved there. Windows registry can be full of errors that cause the main system crashes, error messages, freezes and slowdown. You will be amazed when you view how many errors exist in your registry.
Microsoft experts never suggest people to manually change their registry, since any improper operation to registry can cause serious damage. Instead of taking that risk, using a third-party safe Windows registry optimizer might be better. You may refer to this article and learn .
Windows 7 Maintenance Tip 5:Defragment registry
Just like hard drive needs defrag, registry needs too. Registry defrag is to remove fragmentations and creates a linear registry, which can speed up registry access and program response. Some defragger also compacts your registry to a smaller size, thus it can take up less memory and make room for other programs running fast. There is a free registry defrag software which can safely defrag registry in two minutes for most Windows systems.
Windows 7 Maintenance Tip 6:Uninstall unused programs
Uninstalling programs that you seldom use is better than just removing them from your hard drive., because simple deletion can cause Windows errors. Some programs have the built-in uninstall app while others don't. Then you can go to the control panel and uninstall them. For those malicious programs that don’t allow you to uninstall, you can make use of a third-party uninstall manager (known as built in Wondershare Registry Optimizer) to get rid of them.
Note: cleanup registry is necessary after the uninstallation. Detail is given in the following part.
Windows 7 Maintenance Tip 7: Boost performance by adjusting registry parameters
This step is to change registry parameters designed to boost Windows 7 system performance, such as automatically end hung applications, optimize internet connection, speed up loading web pages, speed up Windows shutdown, etc.
There are many online tips talking about how to manually revise registry settings for better system performance, but manual revisement fits more for computer expertsor than for beginners. Beginners has better use a system optimizing utility (known as built in Wondershare Registry Optimizer) to have this done in single 1 mouse click.
on Dec 23, 2009 | Computers & Internet
When i turn on its taking time to get my disk that is my proplem
the best way is to upgrade ur PC , or format your harddisk or apply this settings as follows ===
Speed Up Windows 7 Boot Up Time Don't Try This To Make Windows 7 Faster:
Try ReadyBoost:
  • 1. Speed Up Windows 7 Using ReadyBoost
  • 2. Check ReadyBoost
  • 3. Speed test your SD Card, CF Card, Flash Drive, HDD
Speed Up Windows 7 BootUpdate 04/21: This tweak does not seem to have great effects on your boot time. Instead use a startup programs manager for Windows 7 and remove as many startup programs as you possibly can.
Do you have a dual-core or quad-core processor? Great, let's lower the boot time of Windows 7:
1. Click on Start, enter "msconfig" into the search field
2. Open the "boot" tab
3. Click on Advanced
4. Check "Number of proccessors" and select "2′ or "4′ from the dropdown menu. (obviously, you can only select it if you have a dual-core/quad-core).
Full Image
Speed up Windows 7: Change Taskbar Thumbnail Preview Time1. Click on Start, enter "regedit" into the search field.
2. Goto: HKEY_CURRENT_USER\Control Panel\Mouse
Speed Up Windows 7 Taskbar Thumbnail Preview
3. Double-click on "MouseHoverTime" and change the value to 100 or lower:
Change the mouse hover time to 100 or lower
4. Voilà, your thumbnail previews should appear a lot faster now. For another great tweak to speed up the Windows 7 taskbar, click here.
Speed Up Windows 7 Shutdown Time1. Open the registry editor (enter regedit into search field)
2. Go to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control"
3. Lower the value (12000 is the default value = 12 seconds) to a value of your choice
Speed Up Application Access - Increase your productivityFirst of all create a folder "QuickStart" somewhere on your PC. Right-click on your taskbar:
toolbar.jpgLocate the folder "QuickStart" (you just created the folder so yo should know where it is) and then click "Ok". You are almost done, but we don't want that ugly text on our taskbar that is using a lot of space, turn it off:
texttitle.jpgRight-click on the new toolbar and uncheck "Show Text" and "Show Title"! Now drag the toolbar to the left until it's below the main icons and you will have something like this:
Sep 01, 2011 | Acer Computers & Internet
I have been using a Belkin Hi-Speed USB 2.0 DVD Creator F5U228/ P74201-B to transfer VHS tapes to my XP computer. My new windows7 PC will not recognise it. Are there Widows 7 drivers available to download...
Unfortunately a lot of devices do not have Windows 7 drivers and some manufacturers are reluctant to provide these drivers for their older products.
Try going to the Belkin WEB site to see if there are Windows 7 drivers for your DVD creator.
THIS WORK AROUND MAY WORK.
Try running XP emulation within Windows 7 - for details how to do this, check out this WEB site.
http://www.microsoft.com/windows/virtual-pc/download.aspx
Jun 13, 2011 | Computers & Internet
Would upgrading from vista to windows 7 speed up the response of my computer ?
yup definitly you will have to upgrade windows 7 one day or another many coll features but going from vista to 7 is no problem at all
reffer to this
upgrade paths
Apr 11, 2010 | Microsoft Computers & Internet
Is there any way to speed up Windows Vista. Its standart Vista Home Premium, Mcafee antivirus was on it. Is there a program witch can speed up my laptop with windows vista. help please. its too slow :)
please let me know your
Machine configuration.
Processor speed,Ram,Hard Disk Size.
I have to assist you remotely to do this.
There are so many reasons for a laptop to be slow.
Dec 08, 2009 | Microsoft Windows Vista Home Premium with...
Significant speed drop in Windows 7
you need to install the latest software from the linksys website
Nov 01, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Microsoft Windows XP Professional for PC Logo
22 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
