Question about LG Televison & Video
I have a LG LH-RH 7601A DVD/HDD Recorder that has the DVD tray stuck in the open position and will not retract with the power on or off. Is there a quick fix that I can carry out or can you recommend where I can get it repaired economically?
  • 146 Answers
SOURCE: want to know how to set my LG dvd/hdd player to multi region
IF there is a code for it you will have to check on some of the sites that have region hacks for DVD players. Not all players have the capability of changing them to region free. I looked to see if your model was listed on a couple of the sites that have directions, info and or firmware updates to change region settings on various makes and models of players, and I didn't find yours listed anywhere. It may use methods from other LG models, but you have to do a little research, some google searches and a little trial and error. Keep in mind that applying these hacks can render your unit inoperable and not recoverable. You might want to look into getting an inexpensive player from Phillips, Durabrand, Apex or one of several other manufacturers that are easy to find codes for and simple to change region coding, and in alot of cases cost less than 50 USD. Phillips are the easiest to get codes for and they are reasonably priced in most department stores like Target and Walmart or at Best Buy and Circuit City. Durabrand are Walmart brand players that cost 25 or 30 dollars and they are easy to do as well.
Hope this helps
Cheers
Posted on Jan 03, 2009
  • 5 Answers
SOURCE: Code region
power on the dvd
let it load and show no disc
open tray and enter '0' four times
region edit and region code appears with the default code
press 0 for region free and enter
region code should be 0
press pause on remote
power off and on again
Posted on Jan 04, 2009
SOURCE: can I copy vcr tapes with the LG RH 1999H dvd/hdd recorder?
I use the av2 input in the front of the recorder to copy my vcr tapes to the hard drive
Posted on May 04, 2009
SOURCE: dvd tray will not stay closed. opens and shuts randomly
i had exactly the same problem on a LG-RH278H resp. a Medion MD 81733. I solved it by opening the micoswitches, cleaning the contacts and streching the springs inside the switches a little. The Problem was, that one of the microswitches stayed conductive even when it was off/open.9acead3.jpg
Posted on May 22, 2009
  • 208 Answers
SOURCE: LG RH1757 (80 GB) DVD Recorder / HDD Recorder
Could be a timing issue with the tray mechanism - possible that somebody has given the tray "a shove" to make it close instead of using the open/close button and has put the timing out.or a worn tray loading belt
Posted on Mar 18, 2010
LG RH1757 (80 GB) DVD Recorder / HDD Recorder Drawer keeps opening Drawer keeps opening and closing and won't read discs! Rassie from Cape Town South Africa
Mar 16, 2010 | LG RH177 DVD Recorder/HDD Recorder
How can I play a Region 1 Dvd in Australia?
power on the tv and dvd without any dvd in tray
open disc tray
press pause then 0000000 on remote
region menu shows on tv screen
select ur region
then power off
Jan 26, 2010 | LG RH177 DVD Recorder/HDD Recorder
DVD TRAY KEEPS ON OPENING AND CLOSING CONTINOUSLY
Hi, I have exactly the same thing. Happened before but went away when I got bored trying to fix it. This time I phoned LG support and they said take it back to Comet (they have bought out their servicing). End of conversation. Polite but firm.
Appalling support via their websites, appalling products. Never again.
Oct 05, 2009 | LG DR787T DVD Recorder
Door opens when recorder starts
Hi
I have the same problem on my RH 278 It appears that the you need to open the recorder and clean the switches. On this forum there is some pictures of how to do same. Search some more on the site at
Generic problem for all DVD Players DVD tray will not stay closed
Jul 15, 2009 | LG RH177 DVD Recorder/HDD Recorder
Can I copy vcr tapes with the LG RH 1999H dvd/hdd recorder?
Apr 27, 2009 | LG RH1999H DVD Recorder/HDD Recorder
Code region
power on the dvd
Jan 03, 2009 | Televison & Video
Can I make my LG RH4820W HDD/DVD recorder multi region?
1 Power on the DVD recorder
2 Press "open"
3 Press "0000000" on the remote control slowly
4 Congratulations' will display on the screen if setup was successful.
5 Press "enter", then finish
Nov 19, 2008 | LG RH-4820 DVD Recorder
LG HDD DVD Recorder remote control not working with LG TV
I have a rh 265 remote and lg tv. It stopped controlling the tv. I hold the tv power button down on remote then pushed 1 at the same time. It reset it to work with my tv.
May 29, 2008 | LG DE9523P DVD Player
No sound from LG HDD DVD recorder
Same Problem here, have not done anything yet, but I am convinced that it is due to blown Capacitors in the Power Supply......
Apr 25, 2008 | LG RH-4820 DVD Recorder
Televison & Video Logo
66 people viewed this question
Computer Repairing
Computer Repairing
