Question about LG LS240CE Split System Air Conditioner
My inside unit has an error code flashing ch46 do you have a list of codes and what they mean.
  • 2,133 Answers
CH-46.Outdoor unit suction sensor fault. Disconnect from PCB and measure resistance. 10 kOhm at 10°C and 4 kOhm at 30°C. If OK replace PCB, if not replace sensor.
Posted on Jan 01, 2011
LG air conditioner model number LMN095HVT units keep on flashing with error code CH 46 and with no response at all. How can I fix it? Thanks for your help in advance!
ERROR CH46:
Sep 01, 2015 | LG Heating & Cooling
What does it mean when PO8 and H7 are flashing on worcester boiler dial
Either on the inside of the door or in your manual will have a list of all the codes. You could try turning the unit off, not while its in operation, and turn back on in 20 seconds. But first find the meaning of the codes, or faults. They will be listed. Unless the code is stupid simple, contact a pro. CO and fires kill if you don't know what you're doing
May 12, 2014 | Heating & Cooling
What does error code E6 mean? On a Mitsubishi Mr. Slim A/C
Code E6
Error detail Indoor/outdoor unit transmission error (signal receiving error).
Inspected unit Indoor.
Air Conditioning Fault Codes
Aug 01, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
I need a list of codes for my lennox hp26-036-7p the red and green lights on the outside unit are flashing continuously. the outside unit acts like it wants to come on and i can her it running but it is...
LED Flash list should be located on the inside of the unit's electrical panel by the wiring schematic, and by counting the flashes in between the longer pauses should give you the diagnostic code. A continuous steady flash can also mean normal operation, and something else on the inside could be holding you out like a float switch tripped (located on emergency pan underneath Air Handler Unit If Applicable) etc.
Jul 05, 2011 | Heating & Cooling
ERROR CH46
if you have multiple unit running from one compressor then you get this code when you set one unit to heat and another unit to cool. All units running from a single compressor need to be in the same mode.
Apr 17, 2011 | LG Art Cool LA121HNP Split System Air...
Control board on a weatherking package unit (gas) is coding with 5 flashes. What does it mean?
I think that is not detecting a flame code. There should be a code listing on the inside of panel.
Nov 14, 2009 | Heating & Cooling
Looking for LED flashing light Error codes for FUjitsu AC
communications error
try resetting the breaker
this should clear the eprom
Dec 13, 2008 | Fujitsu 18C1 Air Conditioner
Kenmore HE2 Plus Front Load Washer; Error Code F12
Is this a model 110.47512601 HE2 Plus? If it is, I do not see an F12 error code listed. I have a tech sheet for an HE2 Plus, but I only see an F21 error code.
There is a tech sheet inside your washer that explains all the error codes. You will have to remove the lower panel under the door to access it. Its usually mounted to the inside of the lower panel on along the interior walls of the cabinet. There will be instructions on how to enter diagnostics mode and a full list of error codes, followed by procedures to follow on how to correct. If you require further assistance in determining the source of the error, please let me know.
PS Don't tell Sears I told you where they keep their "secret" error code list. Don't you find that irritating? The repairman would have come to your home, opened the washer, and read the tech sheet right in front of you - then charged you for it. Good luck.
Jul 13, 2008 | Washing Machines
LG LS240CE Split System Air Conditioner Logo
1,096 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
