Question about Baby Gear
The Lion-XT HARF Engine
My HARF is running low, how do I advance the clock cycle
  • very
  • carefully
Posted on May 22, 2008
My clock is running fast and I can't figure out why?
With the new digital clocks, there is really nothing you can do to fix this. The clock running fast is due to a faulty electronic or electric component that is out of tolerance. US electricity runs at 60Hz, which is 1 cycle per second. Clocks use this to advance the seconds on a clock. Too fast means the 60Hz on the AC power input is not being properly used and is running the clock at something less than 1 cycle per second.
Jan 27, 2015 | Audio Players & Recorders
Maytag centennial top load washer control know tics but does not advance through teh cycles
The cycle dial runs like a clock and advances through each cycle and opens and closes each stage by contacts so I would say that the 1st cycle contact has burnt out which would prevent or in some cases a short will burn out the lot, usually from a power surge so if you don't have the knowledge i'm afraid it is the serviceman. But be assured that you make sure he makes that one of the first points of checking.
Jul 11, 2014 | Maytag Centennial 3.2 cu. ft. SuperSize...
Can I integrate Apple's new Mountain Lion with Twitter?
You can add your Twitter account, by visiting the System Preferences and the selecting Mail, Contacts, & Calendars. Once viewing this screen click the small + at the bottom of the left column. This will show you what types of accounts you can add.
Twitter is an option, just click, enter your twitter credentials and you should be off to the races and tweeting from Mountain Lion!
Hope that helps!
Aug 01, 2012 | Apple OS X 10.8 Mountain Lion
The dial stops at 3 different spots and the machine continues to run until the dial is advanced a little. It does not always stop at the three usual areas but always the first. Is there a way to clean...
The clock motor on the timer is failing to advance through the cycle. If you can hear a hum, you might be able to take the clock motor off the timer and clean it up and lube it.
May 12, 2011 | Maytag Dishwasher
My washer runs non stop on the wash cycle...it washes the clothes but doesn't past the wash cycle...doesn't drain, rinse or spins. What can I do?
Can you manually rotate the timer control to the next steps?
Will it proceed thru the cycles when you rotate the timer manually?
If so, then you can complete the cycle manually for the time being...
If so-- then the clock motor that drives the timer.control is not advancing it.
If yours is a newer machine with all digital controls, then I suspect something wrong in that controller, too-- But I do not have any idea of how to 'advance it manually!
(The blessings of modern controllers!-- Give me the old clock motor driven drum controllers! :-) )
Mack B
Dec 28, 2010 | Washing Machines
How do i reset clock on yamaha xt 125
Hi, Blade_3 for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
XT 125 speedo
How do you adjust the digital clock on the 09 XT How You Do That XT225 250...
http://gigi600.altervista.org/immagini/xt125r/XT%20125%202005_service.pdf
OEM parts for Yamaha
Yamaha XT 125R 2005 Service Information
Sep 02, 2010 | Yamaha XT 125 X Motorcycles
I recently moved and had my washer in storage. My problem is that when I put it on the wash cycle the machine just washes. It never advance to the spin or rinse cycle. I would have to turn it and plaace it...
Sounds like it has clock-drive / brain box issues.
It's usually more cost effective to buy a new machine verses the parts and labor. The clock drive is not a low cost part like a bulb or interlock switch.
But anything is possible.
Unplug it, take the back off, and look for anything obvious like loose connectors, bugs living in the brain box/clock drive, etc. My guess the clock box motor is stuck.
Dec 02, 2017 | Whirlpool WTW5100S Top Load Washer
Is the ge tbx19 defrost clock continious or cumulative?
The timer will advance whenever the cold control is on. (when the compressor is running, or the timer has advanced into a defrost cycle) When the refrig is cold enough (and the timer has not advanced into defrost) the timer will not be advancing. A typical defrost timer will count up 8 hours of compressor run time before going into a 30 minute defrost cycle. (the run time and defrost time can vary greatly from model to model)
Jun 16, 2010 | GE Profile 19.0 cu. ft. Top Freezer...
Hi ! I have xt 125 x and problem with speed on the clock
i have an xt125r and i had the same problem. try disconnecting the battery for a few minutes then when u reconnect it the screen will flash endr/mtrd and select your model(mtrd for xt125x) by turning the ignition key and pressing the blue button(the one u set your lcd with)
when it's on mtrd. the battery is under the seat:p. hope it solves your problem, and make sure it's an x(much smaller front wheel)
Jun 03, 2010 | 2006 Yamaha XT 125 X
'98 Ford Explorer Sport - 1) Heat/AC only runs on the highest setting. 2)When the Heat/AC is turned on the compressor cycles on and off. When it cycles on the idle drops almost shuts the engine off if I...
1)sensor in your setting switch is bad
2)low C fluid in your system will cause the compressor to constantly cycle on & off
3)related to #2 and if it's been doing it for awhile you will need to replace the compressor....(used one at local junkyard sells for about 50 bucks)
4)clock light would simply be a worn or weak display. Only solution would be to replace it or better still, ignore it.
Nov 19, 2009 | 1998 Ford Explorer
Baby Gear Logo
23 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
