Question about Dell S2500 Printer
Due to construction power was completely shut off to bldg. Power now restored and printer will not turn on?
    President:
  • 2,185 Answers
Does it still flashes the led light on the printer? If not anymore, then I guess the printer's fuse went down along with the power failure. Try to unplug the printer overnight. If this does not work, then you need to have the power supply of the printer checked or replaced.
Posted on Sep 14, 2010
My oven is about 10-15 years old and I cannot reset the clock after the power has been disconnected.
Hello. I need the model number to help you accurately and provide part numbers for your particular unit. Was the power turned off by you or was it a power outage(caused by lightning, construction, etc). If the power went out due to an outage, the main board might very well have been damaged. Power interruptions are notorious for blowing out or damaging circuit boards in ovens, microwaves, dishwashers, washers, dryers...the list is almost endless. Normally, the power going out doesn't do the damage--it's the restoring of the power(and the accompanying current surge) that is the culprit. If a board has been damaged by a current surge, if it wasn't knocked out completely immediately, 3-4 weeks after the event is the usual time when symptoms start appearing--caused by weakened electronic chips on the circuit boards starting to fail.
Sep 18, 2015 | Fisher and Paykel Ovens
When I turn on my Kindle, I can't go to my apps carosel
To turn off the Kindle Fire HD completely, hold the power button down for 2-3 seconds and release. A "Shut Down" button will appear (opposite "Cancel"). Touch that button. Allow the unit to cycle off completely. Wait one minute, then power up again. Your functionality should be restored.
Feb 08, 2015 | Amazon Kindle Fire HD
Laser printer shuts down immediately
A laser printer that shuts itself down immediately after turning it on indicates either a loose power cable which can be fixed by pushing the power cable in properly or something internal to the printer is causing it to shut down.
If it is shutting down due to something internal, one possability is it has the wrong power going into it. a 110 volt power supply going into a 220 volt printer or the other way round change the supply or find a converter for it. Another possibility is some other component in the machine is failing such as the power regulator board or format board. If it is something internal like this. Replace the printer is really your only option unless it is still under warrantee as replacing parts in most machines nowdays is more expensive than buying a new printer.
Aug 19, 2014 | Brother HL Office Equipment & Supplies
Lexmark X5150 Printer will not work sometimes. Printer will not print, but save the info in the queue. After I shut my pc down and come back next day, it prints out as soon as I turn on the pc. If...
I would try completely uninstalling the printer from my PC, then downloading the most current printer driver from the Lexmark site and reinstalling it. Also possible that a Windows update messed up your driver. You could check that by doing a System Restore to a date before this problem appeared. Click on the Start icon (or use the Windows key), and type system restore in the search box. What that will do is restore your system to the installed programs as of the restore date. Your files, email, etc. will not be changed or lost due to System Restore.
Feb 19, 2018 | Lexmark Office Equipment & Supplies
Need recovery disc for Toshiba A105.
Instructions1 Click "Start" then "Turn off" or "Shut down" and click the prompt to shut your computer off completely. Let the computer remain off for a few seconds.
2 Hold down the "0" (zero) key on your keyboard and press the power button.
3 Release the power button but hold the "0" until the system restore screen loads.
4 Select "Restore the original factory image" by pressing "1" on your keyboard. In some models, you may be able to click the appropriate restore setting. Press "Yes" or "Next" to continue.
5 Restart the computer when the recovery is complete by pressing any key. The computer will let you know when it is safe to do so.
Thanks
Apr 02, 2012 | Toshiba Computers & Internet
I cannot exit safe mode on my lenovo G550 laptop. I have system restored. booted, and failed booting. Also I restarted the computer many times completely.
Symptons like these usually are due to corrupted data file that is why you Operating System is not loading correctly. Normally an OS reinstallation is the fix. You can shut down the computer and press the OKR button next to the power with an arched arrow sign from the computer turned off and it will restore the system to the default, however everything is gonna be wiped out but guaranteed you system will be error free.
Cheers!
Apr 03, 2011 | Lenovo G550 Notebook
Por que me sale an internal error in the initialization stage
Initialing stage is indication that the computer is undergoing restore to system default. First, at which stage where the computer stops performing restore is indication that disk is either scatched or dusty requiring cleaning. Power shut the computer completely from the shut off button because attempting to press the disk button instantly would cause impact that may damage the restore disk. Power on the computer from the power on button area. Immediately press the disk button to before the computer attempts to capture the media in disk driver. The computer disk driver should pop open immediately to make available the disk. At which point, inspect the restore disk for scratches or dust by simply cleaning with clean tissue paper. Also, observe the disk for compartibility with the computer systems. For example a computer performing on windows XP would least require update restore with disks that are Windows 7. Discontinue restore if realised that the computer is inconpartible to the disk attempting to derive restoration from. If the condition was due to dusty or scratches, simply cleaning the disk should make commenceable the restore process.
Feb 08, 2011 | HP Pavilion dv6000z Notebook
Hello. i have the hp Photosmart C6150 printer. for
Press the button on the printer, to turn the printer off.
Then, press the switch on the power-bar, to completely cut the power to the printer.
Turn the power-bar on.
Turn the printer on.
Jul 06, 2010 | HP Photosmart C6180 All-In-One InkJet...
Computer will not completely read cd.
When you say it will not install do you mean the software stopped during install? Did windows not see the printer? With your computer running. Connecting everything for the printer. Connect the usb cable to pc & printer. Last thing to connect should be the power. When you connect the power cord & turn on the printer. Windows should show an icon by the clock. This icon is windows found new hardware. If this does not come up than your printer is either not connected correctly, you have a bad usb cable or usb port is not seeing the connection. Try another usb port. Each company has their own way to install printer software. Most want the printer shut off. During the install of printer software, a window will open and ask you to connect the printers usb or serial connector to pc & turn on power. The software will finish. Others want you to install the software completely into windows. When you shut down windows than you hook up the printer & power. If everything above failed you can try connecting the printer to another computer & you can try another printer for your Dell. I know, who has something extra like a printer you pc but this is all about trial and error.
Hope one of these suggestions work for you! Lastly, new Dell! You should have free support through dell even for things like this. Luck!!
Please vote...
map
Jan 30, 2008 | Lexmark X1150 All-In-One InkJet Printer
PRINTER SAYS NO CARTRIDGE CARTRIDGES HAVE BEEN CHANGED
Unplug machine from power outlet. take all carts out. leave cover open. wait 5 min. plug machine to power and close cover. machine will demand carts. reinsert carts and answer question given on display.
If you still have trouble this might be due to the generic carts which have not the right construction. use original carts.
Dec 17, 2007 | Brother MFC 420CN All-In-One InkJet...
Dell S2500 Printer Logo
42 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
